MJTP1144
MJTP1144
    APEM(埃斐)
    SWITCH TACTILE SPST-NO 0.05A 12V
MJTP1144 数据手册
MJTP SERIES 6MM THRU-HOLE MTG. TACT SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MATERIALS FEATURES ● ● ● ● ● Numerous single pole-single throw momentary configurations. Excellent tactile feed-back (Snap dome). Ultra-compact size. Long operating life for high reliability. Molded-in terminals minimize wicking of flux or solder. Case: Thermoplastic, color black. Actuator: Thermoplastic, color black unless otherwise specfied. Cover/Bracket: PET film, tin plated brass or stainless steel. Terminals: Silver plated brass. Shorting Contact: Phosphor bronze or stainless steel with silver plating. L.E.D. rating: Forward voltage- 2.1 V (3.0 V Max.). Cont. fwd. current 20mA max.@ 25°C. Gold plating available on contacts & terminals - consult factory. GENERAL SPECIFICATIONS ELECTRICALS Contact rating: Insulation resistance: Dielectric withstanding voltage: Contact resistance: Electrical life: Contact bounce: 50 mA @ 12 VDC 100 megohms min. (100 VDC) 250 VAC for 1 minute 100 milliohms max. @ 5 VDC, 10 mA 100,000 cycles min. (except models MJTP1243 & 1250- 50,000 cycles) 1,000,000 cycles available - consult factory less than 10 msec. MECHANICALS, THERMALS, ENVIRONMENTALS Plunger travel: .010"+ .008", - .004" (0,25 +0,2, -0,1 mm) Actuation force: 160 grams ±30 grams Operating temperature range: -20°C to +70°C Storage temperature range: -30°C to +80°C for 96 hours Shock resistance: 30G per method 213, MIL-STD-202 Vibration resistance: passes method 201, MIL-STD-202 SOLDERING F (note - non-washable except for models indicated 'process compatible' below). IR reflow soldering: Wave soldering: Hand soldering: 240°C max. for 20 seconds max. 255°C max. for 5 seconds max. 320°C max. for 3.5 seconds max. (40 watt iron max.) MJTP1105T Right angle, grounding Caps available see end of section. Bulk packaged. MJTP1109 Process compatible, grounding Model No. MJTP1109 MJTP1109A MJTP1109B Dim. L (In./mm) .197 (5.0) .354 (9.0) .512 (13.0) Bulk packaged. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com F00-F16 5 10/3/00, 2:20 PM F3 MJTP1117 Right angle, grounding New! MJTP1119 Process compatible Model No. MJTP1119 MJTP1119A MJTP1119B Dim. L (in./mm) .197 (5.0) .354 (9.0) .512 (13.0) Bulk packaged. New! MJTP1129 Right angle, grounding, process compatible Model No. MJTP1129 MJTP1129A MJTP1129B F Dim. L (in./mm) .171 (4.35) .329 (8.35) .486 (12.35) Bulk packaged. MJTP1141 Long terminals Model No. MJTP1141 MJTP1141A Dim. L (in./mm) .169 (4.3) .197 (5.0) Packaged on tape. Note: other models available with this tape packaging - consult factory. MJTP1144 Long terminals, grounding Model No. MJTP1144 MJTP1144A Dim. L (in./mm) .169 (4.3) .197 (5.00) Caps available - see end of section. Bulk packaged. New! F4 F00-F16 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 6 10/3/00, 2:20 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. MJTP1145 Right angle, grounding Model Actuator No. Color MJTP1145 Black MJTP1145W Gray SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. New! MJTP1193 With L.E.D. Note: LED cathode is marked with a dot Model No. MJTP1193 MJTP11936 MJTP11935 MJTP11933 L.E.D. Color No L.E.D. Red Yellow Green Caps available with lens see end of section. Bulk packaged. New! MJTP1230 Model Dim. No. L (in./mm) MJTP1230 .170 (4,3) MJTP1230A .197 (5,0) MJTP1230B .374 (9,5) MJTP1230C .315 (8,0) MJTP1230D .512 (13,0) MJTP1230E .287 (7,3) MJTP1230F .335 (8,5) MJTP1230G .275 (7,0) Bulk packaged. MJTP1232 Grounding Model No. MJTP1232 MJTP1232A MJTP1232B MJTP1232C MJTP1232D MJTP1232E MJTP1232F MJTP1232G F Dim. L (in./mm) .170 (4,3) .197 (5,0) .374 (9,5) .315 (8,0) .512 (13,0) .287 (7,3) .335 (8,5) .275 (7,0) Bulk packaged. MJTP1234 Model No. MJTP1234 MJTP1234A Dim. L (in./mm) .094 (2,4) .110 (2,8) Caps available see end of section. Bulk packaged. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com F00-F16 7 10/3/00, 2:20 PM F5 Model No. MJTP1236 MJTP1236A MJTP1236B MJTP1236C MJTP1236D MJTP1236E MJTP1236F MJTP1236G Dim. L (in./mm) .124 (3,1) .152 (3,9) .329 (8,4) .270 (6,9) .466 (11,9) .244 (6,2) .289 (7,3) .230 (5,8) Bulk packaged. MJTP1243 & MJTP1250 Model Dim. Dim. No. L1(in./mm) MJTP1243 .169 (4,3) MJTP1250 .197 (5,0) L (in./mm) .307 (7,8) .335 (8,5) Bulk packaged. MJTP2205 2 switch vertical gang assembly, black actuators F Model No. MJTP2205 MJTP2205A MJTP2205B MJTP2205C MJTP2205D MJTP2205E Dim. L (in./mm) .124 (3,15) .152 (3,85) .329 (8,35) .270 (6,85) .466 (11,85) .242 (6,15) Bulk packaged. MJTP4102 4 switch horizontal gang assembly, black actuators Model No. MJTP4102 MJTP4102A MJTP4102B Dim. L (in./mm) .125 (3,2) .152 (3,85) .329 (8,35) Bulk packaged. MJTP5302 5 switch horizontal gang assembly, black actuators Model No. MJTP5302 MJTP5302A MJTP5302B Dim. L (in./mm) .125 (3,2) .152 (3,85) .329 (8,35) Bulk packaged. F6 F00-F16 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 8 10/3/00, 2:21 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MJTP1236 Right angle, grounding MJTPSHW Process compatible Model Dim. No. L (in./mm) MJTPSHW MJTPSHWA .122 (3,1) .091 (2,3) MJTPSHWB .146 (3,7) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. CAPS (for MJTP1105T and MJTP1234 only) MJ61 Square cap MJ62 Round cap CAPS (for MJTP1193 only) New! CAP COLORS MJ3 Square cap (w/clear lens in center for LED illumination) Note - add digit from table to cap part number for color. Example - MJ612 indicates square black cap. No. 1 2 3 5 6 7 Color blue black green yellow red ivory SCHEMATICS MJTP1109 MJTP1119 MJTP1193 MJTP1230 MJTP1232 MJTP1234 MJTP2205 MJTP4102 MJTP5302 MJTPSHW MJTP1105 MJTP1117 MJTP1129 MJTP1141 MJTP1144 MJTP1145 Note: LED is for MJTP1193 only. MJTP1236 MJTP1243 MJTP1250 MJTP2205 MJTP4102 MJTP5302 F PRINTED CIRCUIT BOARD LAYOUTS Layout tolerances; Linear: ± .004" ( ± 0,1MM) Holes: ± .002" ( ± 0,05MM) MJTP1105T MJTP1141, 44 & 45 MJTP1236 MJTP4102 MJTP1109 MJTP1117 MJTP1119 MJTP1129 MJTP1193 MJTP1230 MJTP1232 MJTP1234 MJTP1243 MJTP1250 MJTPSHW MJTP5302 MJTP2205 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com F00-F16 9 10/3/00, 2:21 PM F7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: MJTP1144 MJTP1144A
MJTP1144
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体(STMicroelectronics)生产的高性能微控制器,适用于广泛的嵌入式应用。
3. 引脚分配:该芯片有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为2.0V至3.6V,工作频率可达72MHz,内置64KB的闪存和20KB的RAM。
5. 功能详解:包括GPIO、定时器、ADC、通信接口(如UART、SPI、I2C)等。
6. 应用信息:适用于工业控制、消费电子、医疗设备等多种应用场景。
MJTP1144 价格&库存
很抱歉,暂时无法提供与“MJTP1144”相匹配的价格&库存,您可以联系我们找货
