ADTST62RV
ADTST62RV
    APEM(埃斐)
    SWITCH TACTILE SPST-NO 0.05A 12V
ADTST62RV 数据手册
ADTS6, ADTSM & AKTSC6 SERIES (SQUARE STEM WITH CAP OPTIONS) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MECHANICAL CONTACT STYLE FEATURES Positive tactile feedback. Ultraminiature structure suitable for high density mounting. Economic but high reliability. Insert molded terminals prevent flux build-up during soldering. MATERIALS COVER: BASE: STEM: CONTACT DISC: TERMINAL: CAP: Stainless steel. UL94V-0 Nylon Thermoplastic. Color: Black UL94V-0 Nylon Thermoplastic. Color: Black(100gf), Brown(160gf), Red(260gf), Salmon(320gf),Yellow(520gf) Silicone rubber Color: Red(300gf) Phosphor bronze with silver cladding. Brass with silver plating. Termoplastic ABS. GENERAL SPECIFICATIONS ELECTRICALS Electrical life: Rating: Contact resistance: Insulation resistance: Dielectric Strength: Contact Arrangement: 100,000 cycles for 320gf, 520gf. 100,000 cycles for 260gf. 200,000 cycles for 100gf, 160gf. 50 mA,12 VDC. 100 milliohms max. 100 megohms min. 500 VDC. 250 VAC /1 minute. 1 pole 1 throw. MECHANICALS Operational Force: 520 + 130gf Brown 320 + 80gf Brown 260 + 50gf Red 160 + 50gf Brown 100 + 50gf Black Stop Strength: Max 3kgf vertical static load continuously for 15 seconds. Stoke: (12x12) 0.35 + 0.1mm (6x6) 0.25 + 0.2 mm - 0.1 mm (Y) (S) (R) (N) (K) Operating Temperature Range: Storage Temperature Range: Vibration resistance: -25ºC to + 70ºC -30ºC to + 80ºC MIL-STD-202F METHOD 201A. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. Shock resistance: MIL-STD-202F METHOD 213B. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M SOLDERING PROCESSES WAVE SOLDERING: Recommended solder temperature at 500ºF (260ºC) max. 5 seconds subject to PCB 1.6mm thickness. (For through hole type) HAND SOLDERING: Use a soldering iron of 30 watts, controlled at 350ºC approximately 5 seconds while applying solder. HOW TO ORDER V ADTS Package Style: = Bulk Pack * B = Tube * Except ADTS-63, 644, 648, 65, 66 Soldering: V = Lead Free M Color Of Stem For Operating Force: K= Black, 100gf N = Brown, 160gf R = Red, 260gf S = Salmon, 320gf Y = Yellow, 520gf N/K = Black, 160gf < 12 x 12, K, Y Unavailable> Dimension H: 6 x 6mm: 12 x 12mm: 1 = 4.3mm 1 = 4.3mm 2 = 5.0mm 4 = 7.3mm (SQ.) x 3.8mm 3 = 7.0mm 5 = 8.5mm 44= 7.3mm (SQ.) x 2.4mm 48= 7.3mm (SQ.) x 2.8mm 5 = 9.5mm 6 = 13mm Prod. Size 6 = 6.6mm 2 = 12 x 12mm = None Post M = Surface Mount APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. CIRCUIT SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTS6**V ADTS64**V PRODUCT NO. LOC. MM. INCH ADTS644*V A B 2.4 1.6 [.095] [.063] ADTS648* V A B 2.8 2.0 [.110] [.079] M ADTS2**V ADTS24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com PART NUMBER. DIM. I ADTSM62~66* .024 MAX. ADTSM61* .020 MAX. ADTSM64**V PART NUMBER. DIM. A DIM. B ADTSM644*V* ADTSM648*V* .094 [2.4] .100 [2.8] .063 [1.6] .079 [2.0] M ADTSM2**V ADTSM24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSM6**V SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. AKTSC CAPS CAP PART NO. AKTSC Cap Type: 1 = Square 2 = Round Prod. Size: ( Tactile Switch ) 6 = 6 x 6mm 2 = 12 x 12mm AKTSC61 AKTSC21 Cap Color: Y= Yellow B = Blue R = Red I = Ivory K = Black G = Green S = Salmon AKTSC62 AKTSC22 PACKAGING ADTS-6 Series: 1000 pcs/bag ADTS(P)-2 series: 500 pcs/bag or 40pcs/tube APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: ADTS63RV ADTS63SV ADTS63YV ADTS644KV ADTS644NV ADTS644RV ADTS644SV ADTS644YV ADTS648KV ADTS648NV ADTS648RV ADTS648SV ADTS648YV ADTS65KV ADTS65NV ADTS65RV ADTS65SV ADTS65YV ADTS66KV ADTS66NV ADTS66RV ADTS66SV ADTS66YV ADTSF60KV ADTSF60KVTR ADTSF60NV ADTSF60NVTR ADTSF60RV ADTSF60RVTR ADTSF61KV ADTSF61KVTR ADTSF61NV ADTSF61NVTR ADTSF61RV ADTSF61RVTR ADTSF62KV ADTSF62KVTR ADTSF62NV ADTSF62NVTR ADTSF62RV ADTSF62RVTR ADTSGF60KVTR ADTSGF60NVTR ADTSGF60RVTR ADTSGF61KVTR ADTSGF61RVTR ADTSGF62RVTR ADTSGL62NVTR ADTSM21NV ADTSM21NVTR ADTSM21RV ADTSM21RVTR ADTSM24NV ADTSM24NVTR ADTSM24RV ADTSM24RVTR ADTSM25NV ADTSM25NVTR ADTSM25RV ADTSM25RVTR ADTSM61KV ADTSM61KVTR ADTSM61NV ADTSM61NVTR ADTSM61RV ADTSM61RVTR ADTSM61SV ADTSM61SVTR ADTSM61YV ADTSM61YVTR ADTSM62KV ADTSM62KVTR ADTSM62NV ADTSM62NVTR ADTSM62RV ADTSM62RVTR ADTSM62SV ADTSM62SVTR ADTSM62YV ADTSM62YVB ADTSM62YVTR ADTSM63KV ADTSM63KVTR ADTSM63NV ADTSM63NVTR ADTSM63RV ADTSM63RVTR ADTSM63SV ADTSM63SVTR ADTSM63YV ADTSM63YVTR ADTSM644KV ADTSM644KVTR ADTSM644NBV ADTSM644NV ADTSM644NVTR ADTSM644RV ADTSM644RVTR ADTSM644SV ADTSM644SVTR
ADTST62RV 价格&库存
很抱歉,暂时无法提供与“ADTST62RV”相匹配的价格&库存,您可以联系我们找货
