ADTSM644SVTR
ADTSM644SVTR
    APEM(埃斐)
    轻触开关 立贴
ADTSM644SVTR 数据手册
ADTS6, ADTSM & AKTSC6 SERIES (SQUARE STEM WITH CAP OPTIONS) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MECHANICAL CONTACT STYLE FEATURES Positive tactile feedback. Ultraminiature structure suitable for high density mounting. Economic but high reliability. Insert molded terminals prevent flux build-up during soldering. MATERIALS COVER: BASE: STEM: CONTACT DISC: TERMINAL: CAP: Stainless steel. UL94V-0 Nylon Thermoplastic. Color: Black UL94V-0 Nylon Thermoplastic. Color: Black(100gf), Brown(160gf), Red(260gf), Salmon(320gf),Yellow(520gf) Silicone rubber Color: Red(300gf) Phosphor bronze with silver cladding. Brass with silver plating. Termoplastic ABS. GENERAL SPECIFICATIONS ELECTRICALS Electrical life: Rating: Contact resistance: Insulation resistance: Dielectric Strength: Contact Arrangement: 100,000 cycles for 320gf, 520gf. 100,000 cycles for 260gf. 200,000 cycles for 100gf, 160gf. 50 mA,12 VDC. 100 milliohms max. 100 megohms min. 500 VDC. 250 VAC /1 minute. 1 pole 1 throw. MECHANICALS Operational Force: 520 + 130gf Brown 320 + 80gf Brown 260 + 50gf Red 160 + 50gf Brown 100 + 50gf Black Stop Strength: Max 3kgf vertical static load continuously for 15 seconds. Stoke: (12x12) 0.35 + 0.1mm (6x6) 0.25 + 0.2 mm - 0.1 mm (Y) (S) (R) (N) (K) Operating Temperature Range: Storage Temperature Range: Vibration resistance: -25ºC to + 70ºC -30ºC to + 80ºC MIL-STD-202F METHOD 201A. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. Shock resistance: MIL-STD-202F METHOD 213B. Frequency: 10-55-10Hz/1minute. Directions: X,Y,Z, three mutually perpendicular directions. Time: 2 hours each direction. High reliability. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M SOLDERING PROCESSES WAVE SOLDERING: Recommended solder temperature at 500ºF (260ºC) max. 5 seconds subject to PCB 1.6mm thickness. (For through hole type) HAND SOLDERING: Use a soldering iron of 30 watts, controlled at 350ºC approximately 5 seconds while applying solder. HOW TO ORDER V ADTS Package Style: = Bulk Pack * B = Tube * Except ADTS-63, 644, 648, 65, 66 Soldering: V = Lead Free M Color Of Stem For Operating Force: K= Black, 100gf N = Brown, 160gf R = Red, 260gf S = Salmon, 320gf Y = Yellow, 520gf N/K = Black, 160gf < 12 x 12, K, Y Unavailable> Dimension H: 6 x 6mm: 12 x 12mm: 1 = 4.3mm 1 = 4.3mm 2 = 5.0mm 4 = 7.3mm (SQ.) x 3.8mm 3 = 7.0mm 5 = 8.5mm 44= 7.3mm (SQ.) x 2.4mm 48= 7.3mm (SQ.) x 2.8mm 5 = 9.5mm 6 = 13mm Prod. Size 6 = 6.6mm 2 = 12 x 12mm = None Post M = Surface Mount APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. CIRCUIT SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTS6**V ADTS64**V PRODUCT NO. LOC. MM. INCH ADTS644*V A B 2.4 1.6 [.095] [.063] ADTS648* V A B 2.8 2.0 [.110] [.079] M ADTS2**V ADTS24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com PART NUMBER. DIM. I ADTSM62~66* .024 MAX. ADTSM61* .020 MAX. ADTSM64**V PART NUMBER. DIM. A DIM. B ADTSM644*V* ADTSM648*V* .094 [2.4] .100 [2.8] .063 [1.6] .079 [2.0] M ADTSM2**V ADTSM24*V APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ADTSM6**V SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. AKTSC CAPS CAP PART NO. AKTSC Cap Type: 1 = Square 2 = Round Prod. Size: ( Tactile Switch ) 6 = 6 x 6mm 2 = 12 x 12mm AKTSC61 AKTSC21 Cap Color: Y= Yellow B = Blue R = Red I = Ivory K = Black G = Green S = Salmon AKTSC62 AKTSC22 PACKAGING ADTS-6 Series: 1000 pcs/bag ADTS(P)-2 series: 500 pcs/bag or 40pcs/tube APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: ADTS63RV ADTS63SV ADTS63YV ADTS644KV ADTS644NV ADTS644RV ADTS644SV ADTS644YV ADTS648KV ADTS648NV ADTS648RV ADTS648SV ADTS648YV ADTS65KV ADTS65NV ADTS65RV ADTS65SV ADTS65YV ADTS66KV ADTS66NV ADTS66RV ADTS66SV ADTS66YV ADTSF60KV ADTSF60KVTR ADTSF60NV ADTSF60NVTR ADTSF60RV ADTSF60RVTR ADTSF61KV ADTSF61KVTR ADTSF61NV ADTSF61NVTR ADTSF61RV ADTSF61RVTR ADTSF62KV ADTSF62KVTR ADTSF62NV ADTSF62NVTR ADTSF62RV ADTSF62RVTR ADTSG61KV ADTSG61NV ADTSG61RV ADTSG62KV ADTSG62NV ADTSG62RV ADTSG63KV ADTSG63NV ADTSG63RV ADTSG644KV ADTSG644NV ADTSG644RV ADTSG648KV ADTSG648NV ADTSG648RV ADTSG65KV ADTSG65NV ADTSG65RV ADTSG66KV ADTSG66NV ADTSG66RV ADTSGF60KVTR ADTSGF60NVTR ADTSGF60RVTR ADTSGF61KVTR ADTSGF61RVTR ADTSGF62RVTR ADTSGL60KVTR ADTSGL60NVTR ADTSGL60RVTR ADTSGL60SVTR ADTSGL61KVTR ADTSGL61NVTR ADTSGL61RVTR ADTSGL61SVTR ADTSGL62KVTR ADTSGL62NVTR ADTSGL62RVTR ADTSGL62SVTR ADTSGZM61NVTR ADTSL60KVTR ADTSL60RVTR ADTSL60SVTR ADTSL61KVTR ADTSL61NVTR ADTSL61RVTR ADTSL61SVTR ADTSL61YVTR ADTSL62KVTR ADTSL62NSVTR ADTSL62NVTR ADTSL62RVTR ADTSL62SVTR ADTSM21NV ADTSM21NVTR ADTSM21RV ADTSM21RVTR ADTSM24NV ADTSM24NVTR
ADTSM644SVTR 价格&库存
很抱歉,暂时无法提供与“ADTSM644SVTR”相匹配的价格&库存,您可以联系我们找货
