RV21D2BC00B-K4C
RV21D2BC00B-K4C
    CARLING
    RV21D2BC00B-K4C
RV21D2BC00B-K4C 数据手册
V-Series Contura Rotary Switches PROD UC T WE BP A GE request sample, configure part, watch video The V-Series Contura Rotary Switch was designed for maximum performance and reliability leveraging the features of the widely popular V-Series Contura Rocker Switches. Available in maintained and momentary circuit options, the V-Series Rotary features a sturdy knob construction, up to three separate LEDs, and fits in an industry standard panel opening. 2 Poles .4-20 12-28 IP67 Sealing Amps VDC Typical Applications ∙ On/Off-Highway ∙ Marine www.carlingtech.com ∙ Test & Measurement ∙ Instrumentation 860.793.9281 ∙ Speed Control ∙ Medical Equipment sales@carlingtech.com Above-Panel Design Features OPTIONAL PANEL SEAL Prevents water/dust ingress behind panel LEDS Up to three separate LEDs 2. SEALS LED and stem seals provide IP67 protection above panel PC BOARD Supports LEDs and surface mount resistors ROTARY & LINEAR ACTUATOR Patented mechanism that translates rotary to linear motion TERMINALS Same pinout as V-Series Rocker Switches, requiring no harness change SECONDARY CAM Provides definitive detent positions with ball & spring located in rotary actuator Tech Specs Electrical Environmental Rating Sealing IP67, for above-panel components of actual switch only. Dust Mil STD 810, Method 510.2 Air Velocity 300 Ft/Min Duration 16Hr Corrosion IEC 68-2-60 Mixed Flowing Gas (MFG) 14 Days Chemical Splash Gasoline, Diesel, Motor Oil, Brake Fluid, Ammonia, Armour All Salt Spray Mil STD 202G, Method 101, Test Condition A 96 Hr Vibration Random Mil STD 202G, Method 214 test Condition C 10G’s RMS Vibration Sinusoidal Mil STD 202G, Method 204D, Test Condition A 0.06DA or 10G’s 10500Hz Shock MIL-STD 202G, Method 213B Test Condition K, 30G’s Handling Shock 1 Meter Drop onto Hard Surface Thermal Shock MIL-STD 202G, Method 107G Test Condition A -55 C to 85 C Moisture Resistance MIL-STD 202G, Method 106F 10, 25 C to 65 C Cycles 95% RH Thermal Cycling 25 Cycles -40 C to 85 C Ignition Protection ISO 8846 with EC Directive 94/25/ EC for Marine Products UV Protection 300 hr Xenon Arc, 1.4W/m2 wavelength 420 nm ESD Human Static Discharge, +/- 15KV applied during normal operation Shipping/Handling, frequency range 200-2000 MHz applied voltage is +8KV to +15KV and -8KV to -15KV 3 discharge cycles Circuit Voltage Max Current Resistive 2 Position Maintain 12 20 2 Position Momentary 12 20 3 Position All 12 20 2 Position Maintain 24 15 2 Position Momentary 24 15 3 Position All 24 15 Dielectric Strength 1500 Volts RMS Insulation Resistance 50 Megohms Initial Contact Resistance 10 Milli Ohm max @ 4VDC Life 50,000 Cycles Two Position 25,000 Cycles Two Position Momentary and All Three position Terminals 0.250” (6.3mm) Quick Connect Physical 3. Function Circuits Double Pole Single Throw, DPST Double Pole Double Throw, DPDT Operation Two and Three Position Maintained and Momentary Knob Rotation Two Position 60 Degrees Three Position 30 Degrees from Center Illumination LED; Red, Green, Amber, Yellow, White, Blue Seals LED O-ring(s) – Silicone, Bezel gasket – Neoprene, Knob seal - NBR Flammability Exceeds FVMSS 302 Requirements, Exterior Components, UL 94 V-2 or Better Interior Components, UL 94 HB or Better Base Polyester, PBT Bracket Nylon 66, PA Knob Polybutylene Terephthalate, PBT 6.5%GF Lens Polycarbonate, PC Connector Nylon 66, PA Mounting Front Panel Snap In, 1.450” (36.83mm) X 0.830” (21.08mm) Panel Thickness, 0.030” – 0.187” (0.76 – 4.75mm) Mechanical Knob Impact *Manufacturer reserves the right to change product specification without prior notice. 50 Gram weight dropped from a height of 18 inches on Top & Sides Ordering Scheme Sample Part Number RV 21 D 2 B 6 0 0 B - K R C 1 Selection 2 3 4 5 6 1. SERIES RV Rotary Contura ( ) - momentary Terminal Connections as viewed from bottom of switch: 8 - - 7 DP - double pole uses 1, 2, 3 and 4, 5, 6. 1 - - 4 2 - - 5 3 - - 6 10 - - 9 Position: 1 2 3 DP 2 & 3, 5 & 6 Connected Terminals 1 & 2, 4 & 5 21 ON NONE OFF 22 (ON) NONE OFF 23 ON NONE (OFF) 24 ON NONE ON 26 ON OFF ON 28 (ON) OFF (ON) SPECIAL CIRCUITS 55 (ON) OFF ON 61 2 & 3, 5 & 6 2 & 3, 4 & 5 1 & 2, 4 & 5 62 2 & 3, 5 & 6 2 & 3 OFF 64 (2 & 3, 5 & 6) 2 & 3 OFF 3. RATING .4VA 28VDC Resistive 15A 24V D 20A 12V 9 10 11 12 Termination .250 TAB (QC) - no barriers .250 TAB (QC) - with barriers .250 TAB (QC) - no barriers Jumper No No Yes (T2 to T5) Notes: 1 Switch circuit uses terminals 1,2,3,4,5 & 6. Terminals 7,8,9 & 10 are for lamp circuit only. 2 Jumper between terminals 2 & 5 for Circuits 61, 62, & 64 to be specified in the Termination & Jumper selection. 3 Circuit 61 may be used for SP, OFF-ON-ON circuit. 4 Base will not have terminal insulating barriers when connector and/or jumpers are used. 5 Code J,K are optional for circuits 62 and 64. Customer may provide externally wired jumper to connect terminals 2 and 5. 6 Lamp #1 located at top end of switch, above terminal 4. Lamp #2 located at top end of switch between terminals 1 & 4. Lamp #3 located at top end of switch, above terminal Positive (+) and negative (-) symbols apply to L.E.D. lamps only. 7 Mounting hole size is 1.450” (36.83mm) by 0.830” (21.08mm). To mount multiple switches in single panel cut-out order optional interlocking mounting panels. 8 Lens color for L.E.D.s must be clear, white, or match color of L.E.D. Configure Complete Part Number > Sealed S A B C D E F G H J K L M N P R T Lamps NONE # 1 # 1 # 1 & # 3 # 1 & # 3 # 1 # 2 # 3 # 1 # 2 # 3 # 1 # 3 # 2 # 1 # 2 # 1 # 2 # 1 # 2 # 2 # 3 # 2 # 3 # 2 # 3 # 3 # 3 when illuminated Terminals Independent Dependent Independent Independent Dependent Dependent Independent Independent Independent Dependent Independent Dependent Dependent Independent Independent Independent Independent Dependent Dependent Dependent Independent Independent Independent Dependent Dependent Independent Dependent Independent Dependent 8+ 3+ 8+ 10+ 3+ 1+ 8+ 9+ 10+ 3+ 9+ 1+ 3+ 8+ 8+ 8+ 10+ 3+ 1+ 3+ 8+ 8+ 10+ 3+ 1+ 10+ 1+ 8+ 1+ 77777777777777777777777777777- 6, 7, 8. LAMP #1, 2 AND OR LAMP #3 4. TERMINATION / BASE STYLE 8 Term 10 Term 1 2 A B J 4, 5 K 4, 5 8 5. ILLUMINATION 2. CIRCUIT 1 B 7 Selection 6: above terminal 7; Selection 8: above terminal 8 No lamp 0 LED Red Amber Green Blue White 12VDC C N H E 6 24VDC D P J K 8 9. BRACKET COLOR & PANEL SEAL Color Black Gray White No Gasket 1 Gasket 2 Gasket B C D G H J W Y Z 10. ACTUATOR STYLE K Rotary Knob (Standard) ACTUATOR ORIENTATION ABOVE TERMINALS 4 1 Browse Standard Parts > 11. LENS COLOR No Lens Z Clear White Amber Green Red Blue 4 9 E K R W 12. KNOB COLOR Black Gray Red White C H S Y 4. *Manufacturer reserves the right to change product specification without prior notice. Dimensional Specs inches [millimeters] 1.400 [35.56] 1.700 [43.18] .845 [21.47] 1.079 [27.40] 1.550 [39.37] 10 TERMINAL BASE W/BARRIERS .960 [24.38] 1.126 [29.24] .250 [6.35] X .031[.78] .353 [8.64] .820 [20.83] .960 [24.38] 10 TERMINAL BASE W/OBARRIERS 8 1 7 4 2 5 3 6 10 9 BOTTOM VIEW TERMINAL ARRANGEMENT 10 TERMINAL BASE 5. *Manufacturer reserves the right to change product specification without prior notice. SWITCH SHOWN WITH VC1 CONNECTOR 10 TERMINAL 1.266 [32.16] 1.318 [33.48] Circuits Diagrams CIRCUIT DIAGRAM CIRCUIT CODE 3 KNOB POSITION CIRCUIT DIAGRAM CIRCUIT CODE 3 6 1 1 KNOB POSITION 6 4 3 21 1 2 3 1 2 3 1 2 3 1 2 3 55 2 5 3 2 6 3 1 5 1 6 4 3 22 61 2 2 5 3 3 6 1 5 6 3 23 62 2 3 5 1 6 2 4 3 1 5 6 3 24 64 2 3 2 5 1 6 4 1 26 3 2 1 6 5 5 3 LEGEND SYMBOL 4 1 28 2 2 DEFINITION TERMINAL LOCATION 3 MAINTAINED CIRCUIT 2 MOMENTARY CIRCUIT 5 INTERNAL CONNECTION (JUMPER TERMINAL) 2 POSITION CONNECTION 2 POSITION CONNECTION P1 P3 2 POSITION P1 P2 P3 3 POSITION 6. *Manufacturer reserves the right to change product specification without prior notice. Lamp Circuit Diagrams LAMP CIRCUIT CODE LAMP CIRCUIT CODE CIRCUIT DIAGRAM +8 A L 1 -7 +10 1 3 N 3 P +8 +9 +10 1 2 3 2 3 +8 R 3 -7 2 1 +1 +9 3 3 1 -7 +8 H 2 -7 +8 +10 2 1 -7 +3 +1 1 T 3 -7 +8 +3 2 -7 7. +10 -7 -7 K 3 +1 1 +3 +1 J 2 -7 -7 G 3 +3 +1 -7 F 2 -7 +8 +3 +1 E +10 M 1 -7 D 2 +8 -7 C 1 -7 +3 B CIRCUIT DIAGRAM +8 +3 *Manufacturer reserves the right to change product specification without prior notice. Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 8. © Carling Technologies, Inc. Carling, Contura are registered trademarks of Carling Technologies, Inc. in the U.S. and other countries.
RV21D2BC00B-K4C 价格&库存
很抱歉,暂时无法提供与“RV21D2BC00B-K4C”相匹配的价格&库存,您可以联系我们找货
RV21D2BC00B-K4C
    • 1+430.00200
    • 200+171.57960
    • 500+165.84480
    • 1000+163.00440
