70500840
70500840
    CROUZET(高诺斯)
    Q ACT FOR SW-83101-112 154 R=
70500840 数据手册
Standard Switches (Double Break) Series 83 106 / 83 109 / 83 112 / 83 154 Types General specifications Layout 83 106 0 - The NO and NC circuits must both be of the same polarity. Components Material - Case : polyamide (83 106 to 83 112) - Case : Diallyl-Phthalate (83 154) - Contacts : nickel silver Actuators - passivated mild steel - roller : nylon - adjustable screws : self-retaining - plates : passivated mild steel (zinc) Note : Fixing holes for these switches have metal ferrules. Approvals: UL - cUL Features Standard Electrical characteristics Nominal c Nominal a Thermal Current rating at 250 V A — A 10 17.5 N (oz.) N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) mm (in.) °C (°C) Operations mm (in.) g (oz.) 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25(11.45+0.2 -0.25) 0.5 ±0.2 (0.02 ±.008) 0.7 (.28) -20 +85 (-4 +185) 107 0.4 x 2 8 Mechanical characteristics Operating force - max. Release force - min. Permitted overtravel force - max. Maximum rest position Tripping point Differential travel Overtravel - min. Ambient operating temperature Mechanical durability Contact gap Weight Contact type C (Form C) SPDT B (Form B) SPNC A (Form A) SPNO Operating curve Number of operations Connections Resistive circuit: Inductive circuit { L = 5 ms R cos ϕ = 0,8 Mechanical life Rating in Amps 83 154 C Actuators and mounting positions Part numbers for standard actuators A 70 500 888 Actuators-Length mm (in.) Flat R49 (1.92) Operating force - max. Release force - min. Pre-travel - max. Differential travel Total travel max. N (oz.) N (oz.) mm (in.) mm (in.) mm (in.) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 7.5 (.3) ) ±.035 Except where otherwise indicated, the flat and roller actuators are mounted as shown in the dimensional drawings (mounted on the left). Assemblies Other information For other forces, actuators, connections and temperatures, please consult us. Normally stocked items Catalog products produced to order Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/20 1 83 109 0 83 112 0 83 106 4 83 106 7 83 111 0 83 111 5 83 154 0 Face terminals Enclosed screws Bistable, 2 actuator positions Bistable, 2 push button positions Base mounting by screws Base mounting by clips Magnetic blow-out switch — — — — — — 5 10 17.5 10 17.5 10 17.5 10 17.5 10 17.5 10 17.5 17.5 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) 4 (14.1) 1 (3.5) 20 (70.5) 12.75 (.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 14.5 (.3) 0.45 (1.62) 2 (7.19) 4 (14.1) 1 (3.5) 20 (70.5) 4 (14.1) 1 (3.5) 20 (70.5) 4 (14.1) 1 (3.5) 20 (70.5) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) 11.45+0.2 -0.25 (.45+.008) 0.65 ±0.25 (.02 ±.008) 0.7 (.29) -40 +125 (-4 +257) 107 0.5 x 2 (.016 x .08) 11 (.3) C B A C B A -20 +85 (-4 +185) 106 0.4 x 2 (.016 x .08) 9 (.32) -20 +85 (-4 +185) 106 0.4 x 2 (.016 x .08) 8 (.3) 11.45+0.2 -0.25 (.45+.008) 0.5 ±0.2 (.02 ±.008) 0.7 (.29) -20 +85 (-4 +185) 107 0.4 x 2 (.016 x .08) 8 (.3) C B A C B A C B A — 2 Contact type C C 3 2 solder 3 for 1/4˝ Quick Connects 1 screw 4 B 70 500 828 E 70 500 813 R49 (1.92) Flat R47 (1.85) Lever R26 (1.02) R15.5 (.61) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 8.4 (.33) 1.2 (4.2) 0.25 (.9) 6.2 (.24) 2.1 ±0.9 (.083 7.5 (.31) 2.8 (9.9) 0.45 (1.6) 3.2 (.125) 1.05 ±0.4 (.041 4.5 (.18) 4 (14.1) 0.8 (2.8) 1.45 (.057) 0.5 ±0.2 (.02 ±.008) 1.9 (.075) ) ±.035 Q 70 500 840 ) ±.035 T 70 500 870 ) ±.016 B9 21 416 364 Operation B9 Plate Mounting Screw 4 (14.1) 1 (3.5) 1.5 (.059) 0.5 ±0,2 (.02 ±.008) 1.9 (.075) Y 70 500 206 H 70 500 208 O2 70 500 218 Y Side plate H Horizontal single-pole mounting plate O2 2-pole side mounting plate K2 2-pole vertical mounting plate To order, specify : 1 Switch Type 831060 831090 831120 831540 2 Contact Type C B A 3 Connection 1 2 3 Example : 831810 C 2 • Ø 4 To order actuators separately, use the 8 digit P/N Actuators A B E Q 5 T B9 Ø = No actuator Actuator Position L - Left (Standard) R - Right Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/21 3 Standard Switches Dimensions 24 (.94) 2Ø 2.5± 0.1 (.1±.004) Ø 7.5 (.3) 13 ± 0.1(.51±.004) Ø2 L –0 + 0.01 + 0.65 1.9 (.07) 8 (.31) 1 (.04) 10.5 (.41) 3) .9 (1 7.8 (.31) 16.6 (.65) (.1) 8± 0.1 (.31±.004) 12.8 (.5) 2.4 (.1) 2.4 OL=10.65 (.42) 4 (.16) 83 106 7 7.5 (.3) 83 106 4 6 (.24) 6.4 (.25) 83 106 - 83 109 - 83 154 Prof. 1.2 +0 Products 83 106 / 109 / 111 83 154 L 32 (1.26) 40 (1.57) 4.6 (.18) 4 (.16) Ø8 (.31) 6 (.24) 16.6 (.65) 8.15 (.32) 7.6 (.30) 6.5 (.26) 8.8 (.35) 1.6 (.06) 23 (.91) 15.9 (.63) 83 112 83 111 5 2 (.08) 7.6 (.30) 83 111 0 13.6 (.54) 12.6 (.5) 7.2 (.28) Ø 2 – 0.05 (.08 + .002 ) 39.2 (1.54) 12.6 (.5) 46.4 (1.83) 13.6 (.54) 23 (.91) mm (in) 36 (1.42) Connections 6 (.24) (.11) 8 (.315) (Ø.125) (Ø.06) (Ø.06) mm (in) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/22 (.206) (.32) (.315) (.032) 2.8 (.11) (.25) 23.6 (.93) 6.2 (.24) (.45) 8 (.315) (.315) 8 (.315) (.24) 3 2 (83 109) 0.8 (.032) 2 (83 106) (.032) 1 Standard Switches Actuators Cross-section of actuators 1 x 6.4 mm (.039 x .252 in.) A R Ø8 (.315) x5 (.2) 47 (1 .85 ) ) 93 (1. 49 F 3 (.12) R 3 (.12) 6x (.24) 8.5 (.33) 12.2 (.48) 8 11.5 (.45) M 2.5x12 7.5 (.3) 3) 1.9 9( R4 E (.32) 7.5 (.3) B Q B9 T 6x8.5 (.24x.33) 19.4 (.76) Ø8x5 (.315x.2) (.315x.2) R 26 .5 15 R .61) ( (1.0 2) (.24x.33) 3 mm (in.) Assemblies 02 Y K2 20 (.78) 52 (2.05) 20 (.787) 62 (2.44) 5.9 17.2 (.68) (.23) 34.2 (1.35) 17.2 (.68) 4.6 (.18) H 29.4 (1.16) ép. 1.5 (.059) M2 2.1 (.08) Ø 4.2 (.165) 33 (1.30) 25 (.98) Ø 4.2 (.165) 5.5 (.22) 13 (.51) 22.4 (.88) 4.7 7.3 (.185) (.29) 25 (.98) Ø 4.2 (.165) 33 (1.30) Unless indicated, the thickness of plates is 1.5 mm (.059 in). mm (in.) Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/23
70500840 价格&库存
很抱歉,暂时无法提供与“70500840”相匹配的价格&库存,您可以联系我们找货
