15-Serie 1200-A_20-Serie 1200-A 04/11/14 15:01 Page107
1200 series
Momentary pushbutton switches - round plunger
Distinctive features and specifications
UG1410A
❑ Butt action contacts, double break
❑ NF (EN 61058-1), UL and CSA approved
B2
ELECTRICAL SPECIFICATIONS
MATERIALS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 4A 250VAC - 8A 125VAC - 4A 24VDC - 8A 12VDC
- silver plated copper contacts (C) : 2A 250VAC - 3A 125VAC - 2A 24VDC 3A 12VDC
• Initial contact resistance : 10 mΩ
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
2.000 Vrms 50 Hz min. between terminals
3.000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 10.000 cycles at full load
GENERAL SPECIFICATIONS
• Torque : 1,50 Nm (1.10 Ft.lb)
max. applied to nut
• Panel thickness :
5 mm (.196) max.
• Total travel :
NO : 4,5 (.177) +/- 0,3 (.011)
NC : 3,5 (.137) +/- 0,3 (.011)
• Operating temperature :
-20°C to +55°C
• Case : polyamide
• Plunger : polyamide
• Bushing : brass, nickel plated
• Contacts :
A : silver
C : copper, silver plated
AGENCY APPROVALS
EN 61058-1
2A 250VAC or 4A 250VAC, T55/125°C
All models
All models function 3 (NO)
Models 1233X209 and 1233X209L are standard marked NF.
To order switches marked NF, UL or CSA, complete appropriate box of
ordering format.
ABOUT THIS SERIES
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
Sealing boots are available to protect the switches against dust and water. They are presented in section H.
Mounting accessories : standard hardware supplied :
- silver contact models : 1 hex nut U166 and 1 knurled nut U411
- copper contact models : 1 hex nut U42 and 1 knurled nut U411
Standard and special hardware are presented in section I.
Packaging unit : 40 pieces, except model 1200.L (50 pieces).
The company reserves the right to change specifications without notice.
APEM
www.apem.com
B2-107
15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page108
1200 series
Solder lug/quick-connect terminals - screw terminals
• Single pole configurations
• Approved models : see following pages
• Panel cut-out : Ø 12,2 (.480)
NC
(function 2)
121.
122.
9.20
(.362)
6.35x0.80
(.25x.031)
Ø3.00x0.50
(.118DIAx0.50)
0.80
(.031)
6.35
(.25)
120.
123.
MODEL
STRUCTURE
Plunger height : NO model : 7,50 mm, NC model : 5,80 mm
➞ Keyway
Ø8.00
(.315DIA)
Normally Open
12.00
(.472)
1213
17.00
(.669)
9.20
(.362)
Normally Closed
1.00
(.039)
1212
10.50
(.413)
7.50
(.295)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
13.20
(.519)
14.00
(.551)
6.35x0.80
(.25x0.031)
➞ Keyway
Screw terminals
Ø8.00
(.315DIA)
Normally Closed
1223
Normally Open
14.00
(.551)
8.00
(.315)
1.00
(.039)
13.20
(.519)
17.00
(.669)
➞ Keyway
ø12.00x0.75 SI
(.472DIAx0.75 IS)
Normally Open
10.50
(.413)
1233
17.00
(.669)
www.apem.com
12.00
(.472)
Normally Closed
1.00
(.039)
1232
ø8.00
(.315DIA)
13.20
(.519)
9.20
(.362)
Normalized quick-connect terminals
B2-108
12.00
(.472)
10.50
(.413)
1222
7.50
(.295)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
7.50
(.295)
B2
0.80
(.031)
6.35
(.25)
9.20
(.362)
6.35x0.80
(.25x.031)
4.50
(.177)
NO
(function 3)
Ø.50
(.059DIA)
Ø3.00x0.50
(.118DIAx0.50)
7.20
(.283)
9.20
(.362)
Ø3.10
(.122DIA)
4.50
(.177)
➞ Keyway
ø1.50
(.059DIA)
14.00
(.551)
6.35x0.80
(.25x0.031)
APEM
15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page109
1200 series
10.50
(.413)
Normally Open
6.35x0.80
(.25x.031)
13.20
(.519)
17.00
(.669)
➞ Keyway
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
14.00
(.551)
B2
Ø8.00
(.315DIA)
7.50
(.295)
Right angle screw terminals + clamp
12.00
(.472)
1203
7.20
(.283)
Normally Closed
Ø8.00
(.315DIA)
1.00
(.039)
1202
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
7.50
(.295)
➞ Keyway
Straight screw terminals + clamp
90˚
21.00
(.826)
6.35x0.80
(.25x.031)
14.00
(.551)
7.00
(.275)
12.00
(.472)
10.50
(.413)
Normally Open
1.00
(.039)
1203-7
CONTACT MATERIALS
A
C
Silver
Copper, silver plated
FINISH
LUXE
Chrome plated cap nut U117 instead of knurled nut U411
PLUNGER COLOURS
2 : Black - 3 : Green - 6 : Red - 7/1 : White
APEM
www.apem.com
B2-109
15-Serie 1200-A_20-Serie 1200-A 31/10/14 09:00 Page110
1200 series
SPECIAL MODELS
NF standard marked - Silver contacts
X209
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
9.20
(.362)
1.00
(.039)
Normally open
1233A•X209
B2
12.00
(.472)
10.50
(.413)
7.50
(.295)
➞ Keyway
13.20
(.519)
17.00
(.669)
Replace • with the desired plunger colour.
14.00
(.551)
6.35x0.80
(.25x0.031)
X209L
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
12.00
(.472)
Normally open
13.20
(.519)
17.00
(.669)
6.35x0.80
(.25x0.031)
9.20
(.362)
1.00
(.039)
1233A•X209L
10.50
(.413)
13.00
(.511)
➞ Keyway
14.00
(.551)
NOTE : Ground connector U187 compulsory on models X209 and X209L if the panel is not metallic or not connected
to ground. Order separately : see section I.
AGENCY APPROVALS
NF
All models
UL-CSA
All models function 3 (NO), including X209 and X209L
Marking : to order switches marked NF, UL or CSA, complete above box with desired approvals.
B2-110
www.apem.com
APEM
16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 04/11/14 15:03 Page111
1200M/MR series
Robust momentary pushbutton switches - metal plunger
UG1410A
❑ UL and CSA approved
B2
- silver plated copper contacts (C) : 2A 250VAC - 3A 125VAC - 2A 14VDC - 3A 12VDC
• Initial contact resistance : 10 mΩ max.
MATERIALS
• Case : polyamide
• Plunger : top chrome plated
brass on polyamide base
• Cap nut : brass, chrome plated
• Contacts : A : silver
• Torque : 1,50 Nm (1.10 Ft.lb) max. applied to nut
• Panel thickness : 4,5 mm (.177) max.
• Total travel :
NO : 4,5 mm (.177) +/- 0,3 (.011)
NC : 3,5 mm (.137) +/- 0,3 (.011)
• Operating temperature : -20°C to +55°C
AGENCY APPROVALS
Availability : approved models are 1213A and 1203A (M or MR)
(model 1223A is only UL approved).
Marking : to order switches marked UL or CSA, complete appropriate box of
ordering format.
ABOUT THIS SERIES
Mounting accessories : standard hardware supplied with all models : 1 hex nut U166 and 1 conic cap nut U1866-6.
Special cap nut U1874 is presented on the following pages.
APEM
www.apem.com
B2-111
16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 31/10/14 08:59 Page112
1200M/MR series
6.35x0.80
(.25x.031)
Ø3.00x0.50
(.118DIAx0.50)
Ø3.00x0.50
(.118DIAx0.50)
0.80
(.031)
6.35
(.25)
9.20
(.362)
9.20
(.362)
0.80
(.031)
6.35
(.25)
Keyway
Solder lug/quick-connect terminals 6,35 x 0,8 (.250 x .031) ➞
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
1213MR
1213M
NO
12.00
(.472)
NC
17.00
(.669)
9.20
(.362)
1212M
1.00
(.039)
1212MR
7.50
(.295)
Curved plunger Flat plunger
13.20
(.519)
6.35x0.80
(.25x0.031)
14.00
(.551)
1223MR
1223M
NO
12.00
(.472)
NC
13.20
(.519)
17.00
(.669)
14.00
(.551)
8.00
(.315)
1222M
1.00
(.039)
1222MR
7.50
(.295)
Ø8.00
(.315DIA)
5.00
(.196)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
5.00
(.196)
➞ Keyway
Screw terminals
5.00
(.196)
Ø12.00x0.75 SI
(.472DIAx0.75 IS)
Ø8.00
(.315DIA)
1203MR
1203M
NO
13.20
(.519)
17.00
(.669)
www.apem.com
12.00
(.472)
NC
6.35x0.80
(.25x.031)
14.00
(.551)
7.00
(.275)
1202M
1.00
(.039)
1202MR
7.50
(.295)
5.00
(.196)
➞ Keyway
Screw terminals + clamp
B2-112
5.00
(.196)
MODEL
STRUCTURE
5.00
(.196)
B2
NC
(function 2)
4.50
(.177)
NO
(function 3)
120.
122.
Ø3.10
(.122DIA)
7.20
(.283)
• Flat or curved plunger
• Panel cut-out Ø 12,2 (.480)
• Single pole
121.
➞ Keyway
APEM
16-Serie 1200M-MR-A_21-Serie 1200M-MR-A 31/10/14 09:00 Page113
1200M/MR series
CONTACT MATERIALS
Silver
A
C
AGENCY APPROVALS
B2
UL - CSA
Availability : approved models are 1213A and 1203A (M or MR) - model 1223A is only UL approved.
Marking : to order switches marked UL or CSA, complete above box with desired approvals.
SPECIAL CAP NUT
3.50
(.137)
Chrome plated cap nut Ø 16 (.629), flat and plain.
Can be supplied instead of standard cap nut U1866-6.
Order separately.
Ø16.00
(.629DIA)
U1874
APEM
www.apem.com
B2-113
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
U411A
很抱歉,暂时无法提供与“U411A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+9.7639925+1.25964
