13.10.2016
RAFIX 22 FS+ - USB feedthrough, round collar, frontring
metallized
1.30.279.021/0700
General information
Form of lens
Color of lens
Color of front ring
Form of collar
flat lens
opaque slate-grey
metallized
round
Dimensions
Dimensions of collar
Overall height
Mounting depth
Mounting hole
Key grid
Diameter of collar
ø 29.8 mm
11.3 mm
27,7 mm
22.3 mm
30 x 30 mm
29.8 mm
Mechanical design
Mounting
Front connection
Rear connection
Torque for nut ring
ring nut
USB Type A
USB Type B
1.2 Nm
Other specifications
Ambient temp. operating min.
Ambient temp. operating max.
Storage temperature min.
Storage temperature max.
Operating life
Degree of protection from front side
-25 °C
+70 °C
-40 °C
+80 °C
1500 operations cycle
IP65 (DIN EN 60529) with closed sealing cap
Relative humidity
Shock resistance to
IEC 60068-2-27 (EN 61131-2)
Vibration resistance according to IEC 600
68-2-6 (EN 61131-2)
ROHS compliant
REACH compliant
5 bis 95% (non condensed)
50 g at 11 ms half sine amplitude
5 g at 10...500 Hz
yes
yes
Technical data are approximate and intended solely for general orientation in the selection of a product.
Subject to modifications and errors. Images and other graphics may only be similar.
For more information, refer to www.rafi.de chapter Imprint / Data Protection.
13.10.2016
Panel cut-out to IEC 60947-5-1
很抱歉,暂时无法提供与“1.30.279.021/0700”相匹配的价格&库存,您可以联系我们找货
