AS1130-BTST
AS1130-BTST
    AMSOSRAM(艾迈斯半导体)
    TSSOP28
    AS1130-BTST
AS1130-BTST 数据手册
Product Document Published by ams OSRAM Group AS1130 132-LED Cross-Plexing Driver with Scrolling Function General Description The AS1130 is a compact LED driver for 132 single LEDs. The devices can be programmed via an I²C compatible interface. The AS1130 offers a 12x11 LED-matrix with 1/12 cycle rate. The required lines to drive all 132 LEDs are reduced to 12 by using the cross-plexing feature optimizing space on the PCB. The whole LED-matrix driving 132 LEDs can be analog dimmed from 0mA to 30mA in 256 steps (8 bit). Additionally each of the 132 LEDs can be dimmed individually with 8-bit allowing 256 steps of linear dimming. To reduce CPU usage up to 6 frames can be stored with individual time delays between frames to play small animations automatically. The AS1130 operates from 2.7V to 5.5V and features a very low shutdown and operational current. The device offers a programmable IRQ pin. Via a register it can be set on what event (CP_Request, Interface Timeout, Error-detection, POR, End of Frame or End of Movie) the IRQ is triggered. Also hardware scroll function is implemented in the AS1130. The device is available in an ultrasmall 20-Pin WL-CSP and an easy to solder 28-pin SSOP/TSSOP package. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS1130, 132-LED Cross-Plexing Driver with Scrolling Function are listed below: Figure 1: Added Value of Using AS1130 Benefits Features • Worlds lowest PCB real estate vs LED count • Up to 132 LEDs in a 12x11 matrix • 16.7M full color matrix with white balance • 8-bit PWM per LED and current control per line • Reduces MCU load and increases battery lifetime • 36 frames of memory with scrolling option • Identifies defect LEDs and “removes” them from the matrix • Error detection and correction ams Datasheet [v2-01] 2016-Oct-12 Page 1 Document Feedback AS1130 − General Description Applications The AS1130 is ideal for dot matrix displays in mobile phones, personal electronics and toys. Figure 2: AS1130- Typical Application Diagram 12 12 CS0 .. 11 CS0 .. 11 VDD 2.7V to 5.5V VDD CIN CIN ADDR R1 AS1130 SYNC_OUT ADDR R1 SYNC_IN AS1130 GND GND VDD SDA μP Page 2 Document Feedback SDA SCL RSTN IRQ SCL RSTN IRQ SDA SCL RSTN IRQ pull-up resistors ams Datasheet [v2-01] 2016-Oct-12 AS1130 − General Description Block Diagram The functional blocks of this device are shown below: Figure 3: AS1130 Block Diagram VDD SYNC_IN SYNC_OUT 1MHz SDA SCL IRQ Digital Control Logic RSTN I2C Interface Control ADDR R1 Control Registers DPRAM AS1130 ams Datasheet [v2-01] 2016-Oct-12 12 CS0 … 11 12 GND Current Sources with Error Detection Page 3 Document Feedback AS1130 − Pin Assignment Pin Assignment Figure 4: Pin Diagram (Top View) 28-pin SSOP/TSSOP 20-pin WL-CSP Figure 5: Pin Description Pin Number 20-Pin WL-CSP 28-Pin SSOP / TSSOP Pin Name A3 1, 7, 14, 22, 28 GND Ground C3 13 RSTN Reset Input. Pull this pin to logic low to reset all control registers (set to default values). For normal operation pull this pin to VDD. D1 17 ADDR I²C Address. Connect to external resistor for I²C address selection. Up to 8 devices can be connected on one bus. See Figure 30 D2 16 SDA Serial-Data I/O. Open drain digital I/O I²C data pin. D3 15 SCL Serial-Clock Input Page 4 Document Feedback Description ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Pin Assignment Pin Number 20-Pin WL-CSP 28-Pin SSOP / TSSOP Pin Name Description B3 3, 10, 18, 19, 26 VDD Positive Supply Voltage. Connect to a +2.7V to +5.5V supply. Bypass this pin with 10μF capacitance to GND. SYNC Synchronization Clock Input or Output. The SYNC frequency for Input and Output is 1MHz. For SYNC_OUT the frequency can be reduced to 32kHz. Interrupt Request. Programmable Open drain digital Output. It can be set via an register after which event (Interface Timeout, POR, CP_ Request, Error Detection, End of Frame or End of Movie) the pin triggers an Interrupt Request. D4 12 D5 11 IRQ A1, A2, A4, A5, B1, B2, B4, B5, C1, C2, C4, C5 25, 27, 2, 4, 23, 24, 5, 6, 21, 20, 9, 8 CS0, CS1, CS6, CS7, CS2, CS3, CS8, CS9, CS4, CS5, CS10, CS11 ams Datasheet [v2-01] 2016-Oct-12 Sinks and Sources for 132 LEDs. Page 5 Document Feedback AS1130 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 6: Absolute Maximum Ratings Parameter Min Max Units Comments Electrical Parameters VDD to GND -0.3 7 V All other pins to GND -0.3 7 or VDD + 0.3 V Sink Current 500 mA Segment Current 100 mA 100 mA Input Current (latch-up immunity) -100 JEDEC 78 Electrostatic Discharge Electrostatic Discharge (human body model) ±2 kV MIL 883 E method 3015 Temperature Ranges and Storage Conditions Junction Temperature Storage Temperature Range 150 ºC -55 125 ºC For 20-Pin WL-CSP -55 150 ºC For 28-pin SSOP/TSSOP 28-pin SSOP/ TSSOP IPC/JEDEC J-STD-020(1)The lead finish for Pb-free leaded packages is matte tin (100% Sn). 20-Pin WL-CSP IPC/JEDEC J-STD-020(1) 1 20-Pin WL-CSP Represents an unlimited floor life time 3 28-pin SSOP/ TSSOP Represents a max. floor life time of 168h Package Body Temperature Relative Humidity (non-condensing) 260 5 85 Moisture Sensitivity Level ºC % Note(s): 1. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices”. Page 6 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Electrical Characteristics Electrical Characteristics V DD = 2.7V to 5.5V, typ. values are at TAMB = 25ºC (unless otherwise specified). All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 7: Electrical Characteristics Symbol Parameter TAMB Operating Temperature Range TJ VDD Conditions Min Max Unit -40 85 °C Operating Junction Temperature Range -40 125 °C Operating Supply Voltage 2.7 5.5 V All current sources turned ON, @ VDD = 5.5V IDD 340 Operating Supply Current mA All current sources turned OFF, @ VDD = 5.5V 0.5 7 15 μA 0.1 1 μA 360 mA 32 mA IDDSSD Software Shutdown Supply Current All digital inputs at VDD or GND @ VDD = 5.5V IDDFSD Full Shutdown Supply Current Pin RSTN = 0V, TAMB = 25ºC IDIGIT Digit Drive Sink Current (drive capability of all sources of one digit(1)) ISEG Segment Drive Source Current LED(2) ΔISEG Typ Segment Drive Current Matching LED VOUT = 1.8V to VDD-400mV 28 30 1 % % Device to Device Current Matching LED VOUT = 1.8V, VDD = 3.3V 1 ILEAK Leakage Output Current All current sources OFF, VOUT = 0V, VDD = 5.5V, TAMB = 25ºC 0.005 ΔILNR Line Regulation VOUT = 1.8V 0.25 %/V ΔILDR Load Regulation VOUT = 1.8V to VDD-400mV 0.25 %/V VDSSAT Saturation Voltage Current = 30mA, VDD = 3.3V 200 mV RDSON(N) Resistance for NMOS ams Datasheet [v2-01] 2016-Oct-12 0.3 0.5 1 μA W Page 7 Document Feedback AS1130 − Electrical Characteristics Symbol Parameter Conditions Open Detection Level Threshold Min Typ VDD0.4 VDD0.1 Short Detection Level Threshold fOSC fREFRESH tRSTN Oscillator Frequency Display Scan Rate 12x11 matrix Reset Pulse Width Low Max Unit V 770 900 mV 0.9 1 1.1 MHz 0.29 0.33 0.36 kHz 500 ns Note(s): 1. Guaranteed by design. 2. I max – I min I SEG = --------------------------- × 100 I max + I min Figure 8: Logic Inputs/Outputs Characteristics Symbol IIH, IIL Parameter Logic Input Current VIH CMOS Logic High Input Voltage VIL CMOS Logic Low Input Voltage ΔVI CMOS Hysteresis Voltage VIH Mobile Logic High Input Voltage (1) VIL Mobile Logic Low Input Voltage(1) ΔVI Hysteresis Voltage (1) Conditions Min VIN = 0V or VDD -1 Typ Max Unit 1 μA 0.7 x VDD V 0.3 x VDD 0.3 V V 1.6 V 0.6 0.1 V V VOL(SDA) SDA Output Low Voltage ISINK = 3mA 0.4 V VOL(IRQ) IRQ Output Low Voltage ISINK = 3mA 0.4 V Sync Clock Output Low Voltage ISINK = 1mA 0.4 V Sync Clock Output High Voltage ISOURCE = 1mA VDD-0.4 V 400 pF VOL(SYNC_ OUT) VOH(SYNC_ OUT) Capacitive Load for Each Bus Line Note(s): 1. Available on request, see Ordering & Contact Information. Page 8 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Electrical Characteristics Figure 9: I²C Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 1000 kHz fSCL SCL Frequency 100 tBUF Bus Free Time Between STOP and START Conditions 1.3 μs Hold Time for Repeated START Condition 260 ns tLOW SCL Low Period 500 ns tHIGH SCL High Period 260 ns tSETUPSTART Setup Time for Repeated START Condition 260 ns tSETUPDATA Data Setup Time 100 ns tHOLDSTART tRISE(SCL) SCL Rise Time 120 ns tRISE(SCL1) SCL Rise Time after Repeated START Condition and After an ACK Bit 120 ns tFALL(SCL) SCL Fall Time 120 ns tRISE(SDA) SDA Rise Time 120 ns tFALL(SDA) SDA Fall Time 120 ns tSETUPSTOP STOP Condition Setup Time tSPIKESUP 260 ns Pulse Width of Spike Suppressed 6 ns Note(s): 1. The Min / Max values of the Timing Characteristics are guaranteed by design. Figure 10: Timing Diagram tBUF tR 70% 30% tHOLDDATA tSETU PDATA 70% 30% START STOP SCL ams Datasheet [v2-01] 2016-Oct-12 tLOW tHIGH tSETU PSTART tSPIKESUP tF tSETU PSTOP STOP tHOLDSTART Rep START SDA Page 9 Document Feedback AS1130 − Typical Operating Characteristics Figure 11: Segment Drive Current vs. Supply Voltage Segment Drive Source Current (mA) Typical Operating Characteristics 32 31.5 31 30.5 30 29.5 29 -45°C 28.5 +25°C +85°C 28 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Figure 12: Segment Drive Current vs. Temperature Segment Drive Source Current (mA) 32 31.5 31 30.5 30 29.5 Vdd = 2.7V 29 Vdd = 3.3V Vdd = 4.5V 28.5 Vdd = 5.5V 28 -45 -25 -5 15 35 55 75 Temperature (C) Page 10 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Typical Operating Characteristics Figure 13: Segment Drive Current vs. Output Voltage Segment Drive Source Current (mA) 32 Vdd = 2.7V 31.5 Vdd = 3.3V Vdd = 4.5V 31 Vdd = 5.5V 30.5 30 29.5 29 28.5 28 1.6 2 2.4 2.8 3.2 3.6 4 4.4 4.8 5.2 5.6 Output Voltage (V) Figure 14: RONNMOS vs. Supply Voltage 0.5 -45°C +25°C RNMOS (Ω) 0.4 +85°C 0.3 0.2 0.1 0 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) ams Datasheet [v2-01] 2016-Oct-12 Page 11 Document Feedback AS1130 − Typical Operating Characteristics Figure 15: Open Detection Level vs. Supply Voltage 300 Open Detection Level (mV) -45°C +25°C 250 +85°C 200 150 100 50 0 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Figure 16: Short Detection Level vs. Supply Voltage 0.9 Short Detection Level (V) 0.85 0.8 0.75 0.7 -45°C 0.65 +25°C +85°C 0.6 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Page 12 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Typical Operating Characteristics Figure 17: CMOS Logic Input Levels vs. Supply Voltage Logic Input Voltage Level (V) 4 3.5 3 2.5 2 1.5 1 Logic High 0.5 Logic Low 0 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Figure 18: CMOS Logic Input Levels vs. Temperature Logic Input Voltage Level (V) 4 3.5 3 2.5 2 1.5 1 Logic High 0.5 Logic Low 0 -45 -25 -5 15 35 55 75 Temperature (C) ams Datasheet [v2-01] 2016-Oct-12 Page 13 Document Feedback AS1130 − Typical Operating Characteristics Figure 19: MOBILE Logic Input Levels vs. Supply Voltage Logic Input Voltage Level (V) 2 1.5 1 0.5 Logic High Logic Low 0 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Figure 20: MOBILE Logic Input Levels vs. Temperature Logic Input Voltage Level (V) 2 1.5 1 0.5 Logic High Logic Low 0 -45 -25 -5 15 35 55 75 Temperature (C) Page 14 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Typical Operating Characteristics Figure 21: Oscillator Frequency vs. Supply Voltage 1.1 fOSC (kHz) 1.05 1 0.95 - 45°C + 25°C + 85°C 0.9 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 Supply Voltage (V) Figure 22: Oscillator Frequency vs. Temperature 1.1 fOSC (kHz) 1.05 1 0.95 Vdd = 2.7V Vdd = 3.3V Vdd = 4.5V Vdd = 5.5V 0.9 -45 -25 -5 15 35 55 75 Temperature (C) ams Datasheet [v2-01] 2016-Oct-12 Page 15 Document Feedback AS1130 − Detailed Description Detailed Description Cross-Plexing Theorem The cross-plexing theorem is using the fact that a LED has a forward and backward direction. A LED will only glow if there is a current flowing in forward direction. A parallel LED in backward direction will block the current flow. This effect is used in a cross-plexed matrix of LEDs. Each CSx pin (CS0 to CS11) can be switched to VDD via the internal current source (“high”), to GND (“low”) or not connected (“highZ”). The mode of operation which is controlled by an internal state machine looks like following. CS0 is switched to GND and all other CSx pins (CS1 to CS11) are controlled according to the settings in the On/Off Frame and Blink & PWM registers (see Figure 31). Than CS1 is switched to GND and all other CSx pins (CS0 and CS2 to CS11) are controlled according to the settings in the On/Off Frame and Blink & PWM registers. In this manner all LEDs in the matrix are scanned and turned on/off depending on the register settings. I²C Interface The AS1130 supports the I²C serial bus and data transmission protocol in fast mode at 1MHz. The AS1130 operates as a slave on the I²C bus. The bus must be controlled by a master device that generates the serial clock (SCLK), controls the bus access, and generates the START and STOP conditions. Connections to the bus are made via the open-drain I/O pins SCLK and SDA. Figure 23: I²C Interface Initialization 1 8 9 1 8 9 SCLK 0 SDA 1 1 0 AD2 AD1 AD0 R/W D15 D14 D13 D12 D11 D10 D9 D8 AD2, AD1 and AD0 are defined by the pin ADDR, see I²C Device Address Byte. Page 16 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Detailed Description Figure 24: Bus Protocol MSB SDI ACK from Receiver Slave Address R/W Direction Bit ACK from Receiver 1 SCLK 2 6 7 8 9 ACK START 1 2 3-7 8 9 ACK Repeat if More Bytes Transferred STOP or Repeated START The bus protocol (as shown in Figure 24) is defined as: • Data transfer may be initiated only when the bus is not busy. • During data transfer, the data line must remain stable whenever the clock line is HIGH. Changes in the data line while the clock line is HIGH will be interpreted as control signals. The bus conditions are defined as: • Bus Not Busy. Data and clock lines remain HIGH. • Start Data Transfer. A change in the state of the data line, from HIGH to LOW, while the clock is HIGH, defines a START condition. • Stop Data Transfer. A change in the state of the data line, from LOW to HIGH, while the clock line is HIGH, defines the STOP condition. • Data Valid. The state of the data line represents valid data, when, after a START condition, the data line is stable for the duration of the HIGH period of the clock signal. There is one clock pulse per bit of data. Each data transfer is initiated with a START condition and terminated with a STOP condition. The number of data bytes transferred between START and STOP conditions is not limited and is determined by the master device. The information is transferred byte-wise and each receiver acknowledges with a ninth-bit. Within the I²C bus specifications a high-speed mode (3.4MHz clock rate) is defined. ams Datasheet [v2-01] 2016-Oct-12 Page 17 Document Feedback AS1130 − Detailed Description • Acknowledge: Each receiving device, when addressed, is obliged to generate an acknowledge after the reception of each byte. The master device must generate an extra clock pulse that is associated with this acknowledge bit. A device that acknowledges must pull down the SDA line during the acknowledge clock pulse in such a way that the SDA line is stable LOW during the HIGH period of the acknowledge clock pulse. Of course, setup and hold times must be taken into account. A master must signal an end of data to the slave by not generating an acknowledge bit on the last byte that has been clocked out of the slave. In this case, the slave must leave the data line HIGH to enable the master to generate the STOP condition. • Figure 24 details how data transfer is accomplished on the I²C bus. Depending upon the state of the R/W bit, two types of data transfer are possible: • Master Transmitter to Slave Receiver. The first byte transmitted by the master is the slave address, followed by a number of data bytes. The slave returns an acknowledge bit after the slave address and each received byte. • Slave Transmitter to Master Receiver. The first byte, the slave address, is transmitted by the master. The slave then returns an acknowledge bit. Next, a number of data bytes are transmitted by the slave to the master. The master returns an acknowledge bit after all received bytes other than the last byte. At the end of the last received byte, a not-acknowledge is returned. The master device generates all of the serial clock pulses and the START and STOP conditions. A transfer is ended with a STOP condition or a repeated START condition. Since a repeated START condition is also the beginning of the next serial transfer, the bus will not be released. The AS1130 can operate in the following slave modes: • Slave Receiver Mode. Serial data and clock are received through SDA and SCL. After each byte is received, an acknowledge bit is transmitted. START and STOP conditions are recognized as the beginning and end of a serial transfer. Address recognition is performed by hardware after reception of the slave address and direction bit. • Slave Transmitter Mode. The first byte (the slave address) is received and handled as in the slave receiver mode. However, in this mode the direction bit will indicate that the transfer direction is reversed. Serial data is transmitted on SDA by the AS1130 while the serial clock is input on SCL. START and STOP conditions are recognized as the beginning and end of a serial transfer. Page 18 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Detailed Description Command Byte The AS1130 operation (see Figure 38) is determined by a command byte (see Figure 25). Figure 25: Command Byte MSB 6 5 4 3 2 1 LSB A7 A6 A5 A4 A3 A2 A1 A0 Figure 26: Command and Single Data Byte Received by AS1130 AS1130 Registers From Master to Slave From Slave to Master S 0 Slave Address A7 A6 R/W A A5 A4 A3 A2 A1 A0 D7 D6 A Command Byte D5 D4 D3 D2 D1 D0 A Data Byte P 1 Byte Acknowledge from AS1130 Acknowledge from AS1130 0 Acknowledge from AS1130 0 0 Autoincrement Memory Word Address Figure 27: Setting the Pointer to a Address Register to Select a Data Register for a Read Operation From Master to Slave AS1130 Registers From Slave to Master S 0 Slave Address R/W A Acknowledge from AS1130 ams Datasheet [v2-01] 2016-Oct-12 A7 0 A6 A5 A4 A3 A2 A1 A0 Command Byte Acknowledge from AS1130 A P 0 Page 19 Document Feedback AS1130 − Detailed Description Figure 28: Reading N Bytes from AS1130 Autoincrement Memory Word Address From Master to Slave From Slave to Master S Acknowledge from AS1130 Acknowledge from Master 0 R/W A Slave Address D7 D6 D5 D4 D3 D2 Not Acknowledge from Master 0 D1 1 n Bytes A First Data Byte 1 Stop reading D0 /A Second Data Byte D7 D6 D5 D4 D3 D2 D1 P D0 Autoincrement to next address AS1130 Registers I²C Device Address Byte The address byte (see Figure 29) is the first byte received following the START condition from the master device. Figure 29: I²C Device Address Byte address: MSB 6 5 4 3 2 1 LSB 0 1 1 0* AD2 AD1 AD0 R/W *) can be factory set to 1 The bit 1, 2 and 3 of the address byte are defined through the resistor @ the device select pin ADDR (see Figure 30). A maximum of 8 devices with the same pre-set code can be connected on the same bus at one time. • The last bit of the address byte (R/W) define the operation to be performed. When set to a 1 a read operation is selected; when set to a 0 a write operation is selected. • I²C Common address. All devices are responding on the address “0111111” if the function is enabled in the register AS1130 Config Register (0x06). Following the START condition, the AS1130 monitors the I²C bus, checking the device type identifier being transmitted. Upon receiving the address code, and the R/W bit, the slave device outputs an acknowledge signal on the SDA line. Page 20 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Detailed Description Figure 30: Device Address I2C Address Bit 3:1 Bit Name i2c_addr Default 000 Access Description R Defines the I²C address of one device via an external resistor on pin ADDR 000: 1MΩ or floating 001: 470kΩ 010: 220kΩ 011: 100kΩ 100: 47kΩ 101: 22kΩ 110: 10kΩ 111: 4.7kΩ or GND The pin ADDR is scanned after start up (POR) and defines the address for the device. The device reacts to this address until a hardware reset (low on pin RSTN) is performed or the power-on-reset (POR) triggers again. Note(s): The internal address decoder needs 5ms to identify the address and to set up the device for this address. ams Datasheet [v2-01] 2016-Oct-12 Page 21 Document Feedback AS1130 − Detailed Description Initial Power-Up On initial power-up, the AS1130 registers are reset to their default values, the display is blanked, and the device goes into shutdown mode. At this time, all registers should be programmed for normal operation. To bring the device into normal operation the following sequence needs to be performed. Start-Up Sequence • Power-up the AS1130 (connect VDD to a source), the devices is in shutdown; • After 5ms the address of the AS1130 is valid and the first I²C command can be send. • Define RAM Configuration; bit mem_conf in the AS1130 Config Register (see Figure 45) • On/Off Frames • Blink & PWM Sets • Dot Correction, if specified • Define Control Register (see Figure 38) • Current Source • Display options • Display picture / play movie • To light up the LEDs set the shdn bit to ‘1’ for normal operation mode (see Figure 48). Shutdown Mode The AS1130 device features two different shutdown modes. A software shutdown via shutdown register (see Shutdown & Open/Short Register (0x09)) and a hardware shutdown via the RSTN pin. The software shutdown disables all LEDs and stops the internal operation of the logic. A shutdown mode via the RSTN pin additionally powers down the power-on-reset (POR) of the device. In this shutdown mode the AS1130 consumes only 100nA (typ.). Page 22 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Register Description Register Selection Within this register the access to one of the RAM sections, the Dot Correction or to the Control register is selected. After one section is selected this section is valid as long as an other section is selected. Figure 31: Register Selection Address Map Address Register Section H E X Data H E X D D D D D D D D 7 6 5 4 3 2 1 0 NOP 0x 00 0 0 0 0 0 0 0 0 On/Off Frame 0 0x 01 0 0 0 0 0 0 0 1 On/Off Frame 1 0x 02 0 0 0 0 0 0 1 0 On/Off Frame 2 0x 03 0 0 0 0 0 0 1 1 A A A A A A A A 7 6 5 4 3 2 1 0 .... ..... Description No operation On/Off information for each frame (up to 36 frames) On/Off Frame 34 0x 23 0 0 1 0 0 0 1 1 On/Off Frame 35 0x 24 0 0 1 0 0 1 0 0 0x 40 0 1 0 0 0 0 0 0 Blink & PWM Set 1 0x 41 0 1 0 0 0 0 0 1 Blink & PWM Set 2 0x 42 0 1 0 0 0 0 1 0 Blink & PWM Set 3 0x 43 0 1 0 0 0 0 1 1 Blink & PWM Set 4 0x 44 0 1 0 0 0 1 0 0 Blink & PWM Set 5 0x 45 0 1 0 0 0 1 0 1 Dot Correction 0x 80 1 0 0 0 0 0 0 0 Selection of Dot Correction Register Control Register 0x C0 1 1 0 0 0 0 0 0 Selection of Control Register Blink & PWM Set 0 ams Datasheet [v2-01] 2016-Oct-12 0x FD 1 1 1 1 1 1 0 1 Blink & PWM Information Sets (up to 6 sets) Page 23 Document Feedback AS1130 − Register Description Data Definition of the Single Frames One frame consists of 2 datasets, the On/Off dataset and the Blink & PWM dataset. Where more On/Off frames can be linked to one PWM set. Depending on the used PWM sets more or less On/Off frames can be stored inside the AS1130 (see Figure 32). Each On/Off frame needs to define the used Blink & PWM dataset. Figure 32: RAM Configuration RAM Configuration Blink & PWM Set On/Off Frame On/Off Frame with Dot Correction 1 0 35..0 34..0 2 1,0 29..0 28..0 3 2,1,0 23..0 22..0 4 3..0 17..0 16..0 5 4..0 11..0 10..0 6 5..0 5..0 4..0 It is necessary to define the RAM configuration before data can be written to the frame datasets. The RAM configuration is defined in the AS1130 config register (see Figure 45) via bit 2:0 and bit 4 for Dot Correction. Note(s): After a first write of data to the frames, the configuration is locked in the AS1130 config register and can be changed only after a reset of the device. A change of the RAM configuration requires to re-write the frame datasets. Page 24 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description 12x11 LED Matrix The AS1130 is configured to control one big LED matrix. Figure 33: AS1130 - Dot Matrix Structure In Figure 34 it is described which databit represents which LED in the matrix. Per default all databits are ‘0’, meaning no LED is on. A ‘1’ puts the LED on. Each Current Segment of the LED Matrix consists of 11 LEDs, therefore 2 bytes of data are required for one Current Segment. CS0 is defined by the two bytes with address 0x00 and 0x01 and also includes the address of the used Blink & PWM dataset for this frame. ams Datasheet [v2-01] 2016-Oct-12 Page 25 Document Feedback A S 1 1 3 0 − Register Description Figure 34: LEDs On/Off Frame Register Format Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x00 0 0 0 0 0 0 0 0 LED 07 LED 06 LED 05 LED 04 LED 03 LED 02 LED 01 LED 00 0x01 0 0 0 0 0 0 0 1 PWM [2] PWM [1] PWM [0] X X LED 0A LED 09 LED 08 0x02 0 0 0 0 0 0 1 0 LED 17 LED 16 LED 15 LED 14 LED 13 LED 12 LED 11 LED 10 0x03 0 0 0 0 0 0 1 1 X X X X X LED 1A LED 19 LED 18 0x04 0 0 0 0 0 1 0 0 LED 27 LED 26 LED 25 LED 24 LED 23 LED 22 LED 21 LED 20 0x05 0 0 0 0 0 1 0 1 X X X X X LED 2A LED 29 LED 28 0x06 0 0 0 0 0 1 1 0 LED 37 LED 36 LED 35 LED 34 LED 33 LED 32 LED 31 LED 30 0x07 0 0 0 0 0 1 1 1 X X X X X LED 3A LED 39 LED 38 0x08 0 0 0 0 1 0 0 0 LED 47 LED 46 LED 45 LED 44 LED 43 LED 42 LED 41 LED 40 0x09 0 0 0 0 1 0 0 1 X X X X X LED 4A LED 49 LED 48 0 1 2 3 4 Page 26 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x0A 0 0 0 0 1 0 1 0 LED 57 LED 56 LED 55 LED 54 LED 53 LED 52 LED 51 LED 50 0x0B 0 0 0 0 1 0 1 1 X X X X X LED 5A LED 59 LED 58 0x0C 0 0 0 0 1 1 0 0 LED 67 LED 66 LED 65 LED 64 LED 63 LED 62 LED 61 LED 60 0x0D 0 0 0 0 1 1 0 1 X X X X X LED 6A LED 69 LED 68 0x0E 0 0 0 0 1 1 1 0 LED 77 LED 76 LED 75 LED 74 LED 73 LED 72 LED 71 LED 70 0x0F 0 0 0 0 1 1 1 1 X X X X X LED 7A LED 79 LED 78 0x10 0 0 0 1 0 0 0 0 LED 87 LED 86 LED 85 LED 84 LED 83 LED 82 LED 81 LED 80 0x11 0 0 0 1 0 0 0 1 X X X X X LED 8A LED 89 LED 88 0x12 0 0 0 1 0 0 1 0 LED 97 LED 96 LED 95 LED 94 LED 93 LED 92 LED 91 LED 90 0x13 0 0 0 1 0 0 1 1 X X X X X LED 9A LED 99 LED 98 0x14 0 0 0 1 0 1 0 0 LED A7 LED A6 LED A5 LED A4 LED A3 LED A2 LED A1 LED A0 0x15 0 0 0 1 0 1 0 1 X X X X X LED AA LED A9 LED A8 5 6 7 8 9 A ams Datasheet [v2-01] 2016-Oct-12 Page 27 Document Feedback A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x16 0 0 0 1 0 1 1 0 LED B7 LED B6 LED B5 LED B4 LED B3 LED B2 LED B1 LED B0 0x17 0 0 0 1 0 1 1 1 X X X X X LED BA LED B9 LED B8 B The Blink & PWM sets contain blink on/off and the digital PWM information for each LED in the matrix. The number of PWM datasets is flexible according to the defined RAM configuration (see Figure 32). In the blink register (see Figure 35) every single LED can be set to blink. The blink period is set in the display option register (see Display Option Register Format). Figure 35: LEDs Blink Frame Register Format Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x00 0 0 0 0 0 0 0 0 LED 07 LED 06 LED 05 LED 04 LED 03 LED 02 LED 01 LED 00 0x01 0 0 0 0 0 0 0 1 X X X X X LED 0A LED 09 LED 08 0x02 0 0 0 0 0 0 1 0 LED 17 LED 16 LED 15 LED 14 LED 13 LED 12 LED 11 LED 10 0x03 0 0 0 0 0 0 1 1 X X X X X LED 1A LED 19 LED 18 0 1 Page 28 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x04 0 0 0 0 0 1 0 0 LED 27 LED 26 LED 25 LED 24 LED 23 LED 22 LED 21 LED 20 0x05 0 0 0 0 0 1 0 1 X X X X X LED 2A LED 29 LED 28 0x06 0 0 0 0 0 1 1 0 LED 37 LED 36 LED 35 LED 34 LED 33 LED 32 LED 31 LED 30 0x07 0 0 0 0 0 1 1 1 X X X X X LED 3A LED 39 LED 38 0x08 0 0 0 0 1 0 0 0 LED 47 LED 46 LED 45 LED 44 LED 43 LED 42 LED 41 LED 40 0x09 0 0 0 0 1 0 0 1 X X X X X LED 4A LED 49 LED 48 0x0A 0 0 0 0 1 0 1 0 LED 57 LED 56 LED 55 LED 54 LED 53 LED 52 LED 51 LED 50 0x0B 0 0 0 0 1 0 1 1 X X X X X LED 5A LED 59 LED 58 0x0C 0 0 0 0 1 1 0 0 LED 67 LED 66 LED 65 LED 64 LED 63 LED 62 LED 61 LED 60 0x0D 0 0 0 0 1 1 0 1 X X X X X LED 6A LED 69 LED 68 0x0E 0 0 0 0 1 1 1 0 LED 77 LED 76 LED 75 LED 74 LED 73 LED 72 LED 71 LED 70 0x0F 0 0 0 0 1 1 1 1 X X X X X LED 7A LED 79 LED 78 2 3 4 5 6 7 ams Datasheet [v2-01] 2016-Oct-12 Page 29 Document Feedback A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x10 0 0 0 1 0 0 0 0 LED 87 LED 86 LED 85 LED 84 LED 83 LED 82 LED 81 LED 80 0x11 0 0 0 1 0 0 0 1 X X X X X LED 8A LED 89 LED 88 0x12 0 0 0 1 0 0 1 0 LED 97 LED 96 LED 95 LED 94 LED 93 LED 92 LED 91 LED 90 0x13 0 0 0 1 0 0 1 1 X X X X X LED 9A LED 99 LED 98 0x14 0 0 0 1 0 1 0 0 LED A7 LED A6 LED A5 LED A4 LED A3 LED A2 LED A1 LED A0 0x15 0 0 0 1 0 1 0 1 X X X X X LED AA LED A9 LED A8 0x16 0 0 0 1 0 1 1 0 LED B7 LED B6 LED B5 LED B4 LED B3 LED B2 LED B1 LED B0 0x17 0 0 0 1 0 1 1 1 X X X X X LED BA LED B9 LED B8 8 9 A B In the PWM register (see Figure 36) the brightness of every single LED can be set via a 8bit PWM (255 steps). Page 30 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Figure 36: LEDs PWM Register Format Address Segment 0 1 Data HE X A 7 A 6 A 5 A 4 A 3 A 2 A 1 A 0 LED00 0x18 0 0 0 1 1 0 0 0 LED01 0x19 0 0 0 1 1 0 0 1 LED02 0x1A 0 0 0 1 1 0 1 0 LED03 0x1B 0 0 0 1 1 0 1 1 LED04 0x1C 0 0 0 1 1 1 0 0 LED05 0x1D 0 0 0 1 1 1 0 1 LED06 0x1E 0 0 0 1 1 1 1 0 LED07 0x1F 0 0 0 1 1 1 1 1 LED08 0x20 0 0 1 0 0 0 0 0 LED09 0x21 0 0 1 0 0 0 0 1 LED0A 0x22 0 0 1 0 0 0 1 0 LED10 0x23 0 0 1 0 0 0 1 1 LED11 0x24 0 0 1 0 0 1 0 0 LED12 0x25 0 0 1 0 0 1 0 1 LED13 0x26 0 0 1 0 0 1 1 0 LED14 0x27 0 0 1 0 0 1 1 1 LED15 0x28 0 0 1 0 1 0 0 0 LED16 0x29 0 0 1 0 1 0 0 1 LED17 0x2A 0 0 1 0 1 0 1 0 LED18 0x2B 0 0 1 0 1 0 1 1 LED19 0x2C 0 0 1 0 1 1 0 0 LED1A 0x2D 0 0 1 0 1 1 0 1 ams Datasheet [v2-01] 2016-Oct-12 D 7 D 6 D 5 D 4 D 3 D 2 D 1 D 0 255 steps for intensity each single LED 255 steps for intensity each single LED Page 31 Document Feedback AS1130 − Register Description Address Segment 2 3 Data HE X A 7 A 6 A 5 A 4 A 3 A 2 A 1 A 0 LED20 0x2E 0 0 1 0 1 1 1 0 LED21 0x2F 0 0 1 0 1 1 1 1 LED22 0x30 0 0 1 1 0 0 0 0 LED23 0x31 0 0 1 1 0 0 0 1 LED24 0x32 0 0 1 1 0 0 1 0 LED25 0x33 0 0 1 1 0 0 1 1 LED26 0x34 0 0 1 1 0 1 0 0 LED27 0x35 0 0 1 1 0 1 0 1 LED28 0x36 0 0 1 1 0 1 1 0 LED29 0x37 0 0 1 1 0 1 1 1 LED2A 0x38 0 0 1 1 1 0 0 0 LED30 0x39 0 0 1 1 1 0 0 1 LED31 0x3A 0 0 1 1 1 0 1 0 LED32 0x3B 0 0 1 1 1 0 1 1 LED33 0x3C 0 0 1 1 1 1 0 0 LED34 0x3D 0 0 1 1 1 1 0 1 LED35 0x3E 0 0 1 1 1 1 1 0 LED36 0x3F 0 0 1 1 1 1 1 1 LED37 0x40 0 1 0 0 0 0 0 0 LED38 0x41 0 1 0 0 0 0 0 1 LED39 0x42 0 1 0 0 0 0 1 0 LED3A 0x43 0 1 0 0 0 0 1 1 Page 32 Document Feedback D 7 D 6 D 5 D 4 D 3 D 2 D 1 D 0 255 steps for intensity each single LED 255 steps for intensity each single LED ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Address Segment 4 5 Data HE X A 7 A 6 A 5 A 4 A 3 A 2 A 1 A 0 LED40 0x44 0 1 0 0 0 1 0 0 LED41 0x45 0 1 0 0 0 1 0 1 LED42 0x46 0 1 0 0 0 1 1 0 LED43 0x47 0 1 0 0 0 1 1 1 LED44 0x48 0 1 0 0 1 0 0 0 LED45 0x49 0 1 0 0 1 0 0 1 LED46 0x4A 0 1 0 0 1 0 1 0 LED47 0x4B 0 1 0 0 1 0 1 1 LED48 0x4C 0 1 0 0 1 1 0 0 LED49 0x4D 0 1 0 0 1 1 0 1 LED4A 0x4E 0 1 0 0 1 1 1 0 LED50 0x4F 0 1 0 0 1 1 1 1 LED51 0x50 0 1 0 1 0 0 0 0 LED52 0x51 0 1 0 1 0 0 0 1 LED53 0x52 0 1 0 1 0 0 1 0 LED54 0x53 0 1 0 1 0 0 1 1 LED55 0x54 0 1 0 1 0 1 0 0 LED56 0x55 0 1 0 1 0 1 0 1 LED57 0x56 0 1 0 1 0 1 1 0 LED58 0x57 0 1 0 1 0 1 1 1 LED59 0x58 0 1 0 1 1 0 0 0 LED5A 0x59 0 1 0 1 1 0 0 1 D 7 D 6 D 5 D 4 D 3 D 2 D 1 D 0 255 steps for intensity each single LED 255 steps for intensity each single LED ................ ams Datasheet [v2-01] 2016-Oct-12 Page 33 Document Feedback AS1130 − Register Description Address Segment A B Data HE X A 7 A 6 A 5 A 4 A 3 A 2 A 1 A 0 LEDA0 0x86 1 0 0 0 0 1 1 0 LEDA1 0x87 1 0 0 0 0 1 1 1 LEDA2 0x88 1 0 0 0 1 0 0 0 LEDA3 0x89 1 0 0 0 1 0 0 1 LEDA4 0x8A 1 0 0 0 1 0 1 0 LEDA5 0x8B 1 0 0 0 1 0 1 1 LEDA6 0x8C 1 0 0 0 1 1 0 0 LEDA7 0x8D 1 0 0 0 1 1 0 1 LEDA8 0x8E 1 0 0 0 1 1 1 0 LEDA9 0x8F 1 0 0 0 1 1 1 1 LEDA0 0x90 1 0 0 1 0 0 0 0 LEDB0 0x91 1 0 0 1 0 0 0 1 LEDB1 0x92 1 0 0 1 0 0 1 0 LEDB2 0x93 1 0 0 1 0 0 1 1 LEDB3 0x94 1 0 0 1 0 1 0 0 LEDB4 0x95 1 0 0 1 0 1 0 1 LEDB5 0x96 1 0 0 1 0 1 1 0 LEDB6 0x97 1 0 0 1 0 1 1 1 LEDB7 0x98 1 0 0 1 1 0 0 0 LEDB8 0x99 1 0 0 1 1 0 0 1 LEDB9 0x9A 1 0 0 1 1 0 1 0 LEDBA 0x9B 1 0 0 1 1 0 1 1 Page 34 Document Feedback D 7 D 6 D 5 D 4 D 3 D 2 D 1 D 0 255 steps for intensity each single LED 255 steps for intensity each single LED ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Dot Correction Register The AS1130 offers a feature to define a correction factor for the analog current for every segment. This correction factor is called Dot Correction and is defined in the Dot Correction register (see Figure 37). The Dot Correction Register is selected via data 128 on addr 253. Figure 37: Dot Correction Register Format Address Segment Data HEX A 7 A 6 A 5 A 4 A 3 A 2 A 1 A 0 0 0x00 0 0 0 0 0 0 0 0 8 bit Dot Correction 1 0x01 0 0 0 0 0 0 0 1 8 bit Dot Correction 2 0x02 0 0 0 0 0 0 1 0 8 bit Dot Correction 3 0x03 0 0 0 0 0 0 1 1 8 bit Dot Correction 4 0x04 0 0 0 0 0 1 0 0 8 bit Dot Correction 5 0x05 0 0 0 0 0 1 0 1 8 bit Dot Correction 6 0x06 0 0 0 0 0 1 1 0 8 bit Dot Correction 7 0x07 0 0 0 0 0 1 1 1 8 bit Dot Correction 8 0x08 0 0 0 0 1 0 0 0 8 bit Dot Correction 9 0x09 0 0 0 0 1 0 0 1 8 bit Dot Correction A 0x0A 0 0 0 0 1 0 1 0 8 bit Dot Correction B 0x0B 0 0 0 0 1 0 1 1 8 bit Dot Correction ams Datasheet [v2-01] 2016-Oct-12 D 7 D 6 D 5 D 4 D 3 D 2 D 1 D 0 Page 35 Document Feedback AS1130 − Register Description Control-Registers The AS1130 device contains 14 control registers which are listed in Figure 38. All registers are selected using a 8-bit address word, and communication is done via the serial interface. Select the Control Register via the Register Selection (see Figure 31). The Control Register is selected via data 192 on addr 253. Figure 38: Control Register Address Map Register Address Register Name Register Data HEX A7 A6 A5 A4 A3 A2 A1 A0 D7:D0 Picture 0x00 0 0 0 0 0 0 0 0 See Figure 39 Movie 0x01 0 0 0 0 0 0 0 1 See Figure 40 Movie Mode 0x02 0 0 0 0 0 0 1 0 See Figure 41 Frame Time / Scroll 0x03 0 0 0 0 0 0 1 1 See Figure 42 Display Option 0x04 0 0 0 0 0 1 0 0 See Figure 43 Current Source 0x05 0 0 0 0 0 1 0 1 See Figure 44 AS1130 Config 0x06 0 0 0 0 0 1 1 0 See Figure 45 Interrupt Mask 0x07 0 0 0 0 0 1 1 1 See Figure 46 Interrupt Frame Definition 0x08 0 0 0 0 1 0 0 0 See Figure 47 Shutdown & Open/Short 0x09 0 0 0 0 1 0 0 1 See Figure 48 I²C Interface Monitoring 0x0A 0 0 0 0 1 0 1 0 See Figure 49 CLK Synchronization 0x0B 0 0 0 0 1 0 1 1 See Figure 50 Interrupt Status 0x0E 0 0 0 0 1 1 0 0 See Figure 51 AS1130 Status 0x0F 0 0 0 0 1 1 0 1 See Figure 52 0x20 0 0 1 0 0 0 0 0 Open LED ........................ 0x37 Page 36 Document Feedback 0 0 1 1 See Figure 53 0 1 1 1 ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Picture Register (0x00) In this register it must be set if a picture is to display on the LED matrix or not. Also the address of the picture which should be displayed must be set within this register. The default setting of this register is 0x00. Figure 39: Picture Register Format 0x00 Picture Register Bit Bit Name Default Access 7 blink_pic 0 R/W All LEDs in blink mode during display picture 0: No blink 1: All LEDs blink 6 display_pic 0 R/W Display picture 0: No picture 1: Display picture R/W Address of picture 000000: Frame 0 000001: Frame 1 000010: Frame 2 000011: Frame 3 000100: Frame 4 000101: Frame 5 ............... 100000: Frame 32 100001: Frame 33 100010: Frame 34 100011: Frame 35 5:0 pic_addr 000000 Bit Description Note(s): 1. The display_pic bit (bit 6 in Picture Register) has lower priority than the display_movie bit (bit 6 in Movie Register). ams Datasheet [v2-01] 2016-Oct-12 Page 37 Document Feedback AS1130 − Register Description Movie Register (0x01) In this register it must be set if a movie is to display on the LED matrix or not. Also the address of the first frame in the movie needs be set within this register. The default setting of this register is 0x00. Figure 40: Movie Register Format 0x01 Movie Register Bit Bit Name Default Access 7 blink_movie 0 R/W All LEDs in blink mode during play movie 0: No blink 1: All LEDs blink 6 display_movie 0 R/W 0: No movie 1: Start movie R/W Address of first frame in movie 000000: Frame 0 000001: Frame 1 000010: Frame 2 000011: Frame 3 000100: Frame 4 000101: Frame 5 ............... 100000: Frame 32 100001: Frame 33 100010: Frame 34 100011: Frame 35 5:0 movie_addr 000000 Bit Description Note(s): 1. The display_movie bit (bit 6 in Movie Register) has higher priority than the display_pic bit (bit 6 in Picture Register). Page 38 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Movie Mode Register (0x02) Within this register two movie play options can be set. Per default this register is set to 0x00. • In scroll mode a movie can stop with the last frame of the movie or scroll endless • The number of frames to play in a movie Figure 41: Movie Mode Register Format 0x02 Movie Mode Register Bit Bit Name Default Access Bit Description 7 blink_en 0 R/W LED blink option(1) 0: Enabled 1: Disabled 6 end_last 0 R/W Defines at which frame a movie stops in scroll mode 0: Movie ends with 1st frame 1: Movie ends with last frame R/W Number of frames played in a movie, starting at movie_ addr defined in Movie Register 000001: Play 2 Frames 000010: Play 3 Frames 000011: Play 4 Frames 000100: Play 5 Frames 000101: Play 6 Frames ............... 100000: Play 33 Frames 100001: Play 34 Frames 100010: Play 35 Frames 100011: Play 36 Frames 5:0 movie_frames 000000 Note(s): 1. Disable blink option overrides any blink definition in PWM data definition or global blink definition in picture register & movie register bit 7. ams Datasheet [v2-01] 2016-Oct-12 Page 39 Document Feedback AS1130 − Register Description Frame Time/Scroll Register (0x03) Every single frame in a movie is displayed for a certain time before the next frame is displayed. This time can be set within this register with 4 bits. The stated values in Figure 42 are typical values. Also the scroll options are set within this register. Per default this register is set to 0x00. Figure 42: Frame Time/Scroll Register Format 0x03 Frame Time/Scroll Register Bit Bit Name Default Access Bit Description 7 frame_fad 0 R/W Fade frame option (not available in 5 LED block configuration) 0: No fading 1: Fading of a frame 6 scroll_dir 0 R/W Scroll Direction 0: Scroll to right 1: Scroll to left 5 block_size 0 R/W Define block size for scrolling 0: Scroll in full matrix 1: Scroll in 5 LED blocks (current sources split in 2 sections, see Scroll Function) 4 Enable Scrolling 0 R/W Scroll digits at play movie 0: No scrolling 1: Scrolling digits at play movie R/W Delay between frame change in a movie 0000: Play frame only one time 0001: 32.5ms 0010: 65ms 0011: 97.5ms 0100: 130ms 0101: 162.5ms 0110: 195ms 0111: 227.5ms 1000: 260ms 1001: 292.5ms 1010: 325ms 1011: 357.5ms 1100: 390ms 1101: 422.5ms 1110: 455ms 1111: 487.5ms 3:0 frame_delay Page 40 Document Feedback 0000 ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Display Option Register (0x04) In this register the number of loops in a movie are defined. With the scan-limit it can be controlled how many digits are displayed in each matrix. When all 12 digits in the matrix are displayed, the display scan rate is 430Hz (typ.). If the number of digits to display is reduced, the update frequency is increased. Per default this register is set to 0x20. Figure 43: Display Option Register Format 0x04 Display Option Register Bit Bit Name Default Access Bit Description 7:5 loops 001 R/W Number of loops played in one movie 000: Not valid 001: 1 loop 010: 2 loops 011: 3 loops 100: 4 loops 101: 5 loops 110: 6 loops 111: play movie endless (needs to be reset to 0-6 to stop movie); for scroll endless set bit end_last = ‘0’ 4 blink_freq 0 R/W Blink period 0: 1.5s 1: 3s R/W Number of displayed segments in one frame (scan-limit) 0000: CS0 0001: CS0 to CS1 0010: CS0 to CS2 0011: CS0 to CS3 0100: CS0 to CS4 0101: CS0 to CS5 0110: CS0 to CS6 0111: CS0 to CS7 1000: CS0 to CS8 1001: CS0 to CS9 1010: CS0 to CS10 1011: CS0 to CS11 3:0 scan_limit 0000 Note(s): 1. To stop a movie in play endless mode, bits D7:D5 have to be set to a value between 000 to 110. ams Datasheet [v2-01] 2016-Oct-12 Page 41 Document Feedback AS1130 − Register Description Current Source Register (0x05) Within this registers the current for every single LED can be set from 0mA to 30mA in 255 steps (8 bits). Per default this register is set to 0x00. Figure 44: Current Source Register Format 0x05 Current Source Register Bit Bit Name Default Access 7:0 current 00000000 R/W Bit Description 00000000: 0mA .......... 11111111: 30mA AS1130 Config Register (0x06) Per default this register is set to 0x00. Figure 45: AS1130 Config Register Format 0x06 AS1130 Config Register Bit 7 6 5 4 Bit Name low_vdd_rst low_vdd_stat led_error_ correction dot_corr Page 42 Document Feedback Default 0 0 0 0 Access Bit Description R/W 0: At the end of a movie or a display picture the “low_ VDD” flag is not changed 1: At the end of a movie or a display picture, the “low_ VDD” flag is set to “0” R/W This bit indicates the supply status 0: If low_VDD is detected, the Interrupt Status Register will be updated accordingly and pin IRQ is triggered. 1: The low_VDD bit is directly mapped to the pin IRQ. This can be used to control an external DC/DC Converter or Charge Pump. In this case pin IRQ cannot be used for interrupt functionality, the Interrupt Status Register will be updated accordingly. R/W This bit defines the LED open handling 0: Open LEDs which are detected at LED open test, are NOT disabled 1: Open LEDs which are detected at LED open test, are disabled R/W Analog current DotCorrection(1) 0: Disabled 1: Enabled ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description 0x06 AS1130 Config Register Bit 3 2:0 Bit Name Default common_addr mem_conf 0 000 Access Bit Description R/W I²C Common Address 0: Disabled 1: Enabled (all AS1130 are reacting on the same address “0111111”) R/W Define Memory Configuration(1) (see RAM Configuration) 000: Invalid Configuration (default value) 001: RAM Configuration 1 010: RAM Configuration 2 011: RAM Configuration 3 100: RAM Configuration 4 101: RAM Configuration 5 110: RAM Configuration 6 Note(s): 1. This configuration is locked after the first write access to ON/OFF, PWM od DotCorrection data section. Unlock can be performed only by a reset of the device. Interrupt Mask Register (0x07) Per default this register is set to 0x20. Figure 46: Interrupt Mask Register Format 0x07 Interrupt Mask Register Bit Bit Name Default Access Bit Description 7 selected_pic 0 R/W IRQ pin triggers if defined frame is displayed (see Interrupt Frame Definition Register (0x08)) 0: Disabled 1: Enabled 6 watchdog 0 R/W IRQ pin triggers if the I²C watchdog triggers 0: Disabled 1: Enabled 5 por 1 R/W IRQ pin triggers if POR is active 0: Disabled 1: Enabled R/W IRQ pin triggers if the overtemperature limit is reached 0: Disabled 1: Enabled R/W IRQ pin triggers if VDD is too low for used LEDs (low_VDD flag) 0: Disabled 1: Enabled 4 3 overtemp low_vdd ams Datasheet [v2-01] 2016-Oct-12 0 0 Page 43 Document Feedback AS1130 − Register Description 0x07 Interrupt Mask Register Bit Bit Name Default Access Bit Description 2 open_err 0 R/W IRQ pin triggers if an error on the open test occurs 0: Disabled 1: Enabled 1 short_err 0 R/W IRQ pin triggers if an error on the short test occurs 0: Disabled 1: Enabled 0 movie_fin 0 R/W IRQ pin triggers if a movie is finished 0: Disabled 1: Enabled Interrupt Frame Definition Register (0x08) Per default this register is set to 0x3F. Figure 47: Interrupt Frame Definition Register Format 0x08 Interrupt Frame Definition Register Bit Bit Name Default Access 7:6 - 00 n/a 5:0 last_frame Page 44 Document Feedback 111111 R/W Bit Description After this frame is displayed the last time (depending on the number of loops played in a movie) an interrupt will be triggered. 000000: Frame 0 000001: Frame 1 000010: Frame 2 000011: Frame 3 000100: Frame 4 000101: Frame 5 .................. 100000: Frame 32 100001: Frame 33 100010: Frame 34 100011: Frame 35 ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description Shutdown & Open/Short Register (0x09) Per default this register is set to 0x02. Figure 48: Shutdown & Open/Short Register Format 0x09 Shutdown & Open/Short Register Bit Bit Name Default Access 7:5 - 000 n/a 4 3 test_all auto_test 0 0 Bit Description R/W The LED open/short test is performed on all LED locations 0: Disabled (unassembled or disabled LEDs will be detected as open) 1: Enabled (unassembled LEDs will be detected as open) R/W The automatic LED open/short test is started when bit display_pic (0x00) or bit display_movie (0x01) is set to “1” 0: Disabled 1: Enabled 2 manual_test 0 R/W The manual LED open/short test is started after the update of Reg0x09 0: Disabled 1: Enabled 1 init 1 R/W 0: Initialise control logic (internal state machine is reset again) 1: Normal operation 0 shdn 0 R/W 0: Device is in shutdown mode (outputs are turned off, internal state machine stops) 1: Normal operation The scan limit (0x04) defines also the number of segments for the open/short detection. ams Datasheet [v2-01] 2016-Oct-12 Page 45 Document Feedback AS1130 − Register Description I²C Interface Monitoring Register (0x0A) This register is used to monitor the activity on the I²C bus. If a deadlock situation occurs (e.g. the bus SDA pin is pulled to low and no communication is possible) the chip will reset the I²C interface and the master is able to start the communication again. The time window for the reset of the interface of the AS1130 can be set via 7 bits from 256μs to 33ms. The default setting of this register is 0xFF. Figure 49: I²C Interface Monitoring Register Format 0x0A I²C Interface Monitoring Register Bit Bit Name Default Access 7 - 1 n/a Bit Description 6:1 Timeout window 11111 R/W Definition of the Timeout window (0 to 127 => 1 to 128 x 256μs) 0000000: 256μs ........ 1111111: 32.7ms 0 i2c_monitor 1 R/W 0: I²C monitoring off 1: I²C monitoring on CLK Synchronization Register (0x0B) The default setting of this register is 0x00. Figure 50: CLK Synchronization Register Format 0x0B CLK Synchronization Register Bit Bit Name Default Access 7:4 - 0000 n/a 3:2 1 clk_out sync_out Page 46 Document Feedback 00 0 Bit Description R/W Adjustable clock out frequency 00: 1MHz 01: 500kHz 10: 125kHz 11: 32kHz R/W The internal oscillator is used as system-clk. The selected clk frequency is available on pin D4 for synchronization. (Output)(1) 0: Disabled 1: Enabled ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Register Description 0x0B CLK Synchronization Register Bit 0 Bit Name Default sync_in 0 Access Bit Description R/W The internal oscillator is disabled. Pin D4 is used as clk input for system-clk.(1) 0: disabled 1: enabled Note(s): 1. CLK synchronization is done via the SYNC pin. Only one option can be activated (Input or Output). Interrupt Status Register (0x0E) This is a read only register. Within this register the cause of an interrupt can be read out. After power up or a reset the default setting of this register is 0x20. A read out command will set this register to default and the IRQ pin will be released again. Figure 51: Interrupt Status Register Format 0x0E Interrupt Status Register Bit Bit Name Default Access 7 frame_int 0 R 0: No interrupt 1: Defined Frame is displayed (see Interrupt Frame Definition Register (0x08)) 6 i2c_int 0 R 0: No interrupt 1: I²C watchdog reports a deadlock on the interface 5 por_int 1 R 0: No interrupt 1: POR was triggered 4 overtemp_int 0 R 0: No interrupt 1: Overtemperature limit is reached 3 low_vdd_int 0 R 0: No interrupt 1: VDD is too low to drive requested current through the LEDs 2 open_int 0 R 0: No interrupt 1: Error on open test 1 short_int 0 R 0: No interrupt 1: Error on short test 0 movie_int 0 R 0: No interrupt 1: Play movie is finished ams Datasheet [v2-01] 2016-Oct-12 Bit Description Page 47 Document Feedback AS1130 − Register Description AS1130 Status Register (0x0F) This is a read only register. From this register the actual status of the AS1130 can be read out. The default setting of this register is 0x00. Figure 52: AS1130 Status Register Format 0x0F AS1130 Status Register Bit Bit Name Default Access Bit Description 7:2 frame_on 000000 R Actual displayed frame 000000: Frame 0 000001: Frame 1 000010: Frame 2 000011: Frame 3 000100: Frame 4 000101: Frame 5 ............... 100000: Frame 32 100001: Frame 33 100010: Frame 34 100011: Frame 35 1 movie_on 0 R 0: No movie 1: Movie playing 0 test_on 0 R 0: No test is running 1: Open/short test ongoing Page 48 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 A S 1 1 3 0 − Register Description AS1130 Open LED Register (0x20 to 0x37) This is a read only register. From this register the LED’s which failed with an open error can be read out. A ‘1’ indicates LED okay, a ‘0’ stands for LED open. If a LED, which is physically not connected to the device is tested, the Open LED test will return a ‘0’. Figure 53: Open LED Register Format Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x20 0 0 1 0 0 0 0 0 LED 07 LED 06 LED 05 LED 04 LED 03 LED 02 LED 01 LED 00 0x21 0 0 1 0 0 0 0 1 0 0 0 0 0 LED 0A LED 09 LED 08 0x22 0 0 1 0 0 0 1 0 LED 17 LED 16 LED 15 LED 14 LED 13 LED 12 LED 11 LED 10 0x23 0 0 1 0 0 0 1 1 0 0 0 0 0 LED 1A LED 19 LED 18 0x24 0 0 1 0 0 1 0 0 LED 27 LED 26 LED 25 LED 24 LED 23 LED 22 LED 21 LED 20 0x25 0 0 1 0 0 1 0 1 0 0 0 0 0 LED 2A LED 29 LED 28 0x26 0 0 1 0 0 1 1 0 LED 37 LED 36 LED 35 LED 34 LED 33 LED 32 LED 31 LED 30 0x27 0 0 1 0 0 1 1 1 0 0 0 0 0 LED 3A LED 39 LED 38 0 1 2 3 ams Datasheet [v2-01] 2016-Oct-12 Page 49 Document Feedback A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x28 0 0 1 0 1 0 0 0 LED 47 LED 46 LED 45 LED 44 LED 43 LED 42 LED 41 LED 40 0x29 0 0 1 0 1 0 0 1 0 0 0 0 0 LED 4A LED 49 LED 48 0x2A 0 0 1 0 1 0 1 0 LED 57 LED 56 LED 55 LED 54 LED 53 LED 52 LED 51 LED 50 0x2B 0 0 1 0 1 0 1 1 0 0 0 0 0 LED 5A LED 59 LED 58 0x2C 0 0 1 0 1 1 0 0 LED 67 LED 66 LED 65 LED 64 LED 63 LED 62 LED 61 LED 60 0x2D 0 0 1 0 1 1 0 1 0 0 0 0 0 LED 6A LED 69 LED 68 0x2E 0 0 1 0 1 1 1 0 LED 77 LED 76 LED 75 LED 74 LED 73 LED 72 LED 71 LED 70 0x2F 0 0 1 0 1 1 1 1 0 0 0 0 0 LED 7A LED 79 LED 78 0x30 0 0 1 1 0 0 0 0 LED 87 LED 86 LED 85 LED 84 LED 83 LED 82 LED 81 LED 80 0x31 0 0 1 1 0 0 0 1 0 0 0 0 0 LED 8A LED 89 LED 88 0x32 0 0 1 1 0 0 1 0 LED 97 LED 96 LED 95 LED 94 LED 93 LED 92 LED 91 LED 90 0x33 0 0 1 1 0 0 1 1 0 0 0 0 0 LED 9A LED 99 LED 98 4 5 6 7 8 9 Page 50 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 A S 1 1 3 0 − Register Description Address Data Segment HEX A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 0x34 0 0 1 1 0 1 0 0 LED A7 LED A6 LED A5 LED A4 LED A3 LED A2 LED A1 LED A0 0x35 0 0 1 1 0 1 0 1 0 0 0 0 0 LED AA LED A9 LED A8 0x36 0 0 1 1 0 1 1 0 LED B7 LED B6 LED B5 LED B4 LED B3 LED B2 LED B1 LED B0 0x37 0 0 1 1 0 1 1 1 0 0 0 0 0 LED BA LED B9 LED B8 A B ams Datasheet [v2-01] 2016-Oct-12 Page 51 Document Feedback AS1130 − Typical Application Typical Application Scroll Function The AS1130 offers a feature for scrolling a picture through the matrix without the need of communication via a μP. The scrolling can be done in the whole matrix (12x11) or optimized for a ticker in a 5x24 matrix (see Figure 54). Figure 54: LED Configuration for 5LED Block Scroll Function   /  9 8 < = >        In the movie display mode the frame is shown in the matrix at once. On the contrary in the scroll function the frame is shifted through the matrix segment after segment (CS0 to CS1 to CS2 to CS3...). Page 52 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Typical Application Figure 55: Scrolling Figure 56: Ticker Application with 5x96 LED Matrix CS0 .. 11 SYNC_OUT VDD 2.7V to 5.5V CS0 .. 11 2.7V to 5.5V CIN SYNC_IN VDD CIN ADDR AS1130 ADDR GND R1 AS1130 GND R1 SDA SCL RSTN SDA 12 SCL RSTN 12 12 12 scroll directions CS0 .. 11 2.7V to 5.5V SYNC_IN VDD CIN SYNC_IN VDD CIN ADDR AS1130 ADDR GND R1 AS1130 GND R1 SDA ams Datasheet [v2-01] 2016-Oct-12 CS0 .. 11 2.7V to 5.5V SCL RSTN SDA SCL RSTN Page 53 Document Feedback AS1130 − Typical Application LED Current Calculation The current through a LED in the matrix is set via three registers (Current Source Register, Dot Correction and PWM). The resulting current through the single LED can be calculated as shown in the following. First it is necessary to calculate the time how long one LED will be ON. (EQ1) PWM t LEDon = --------------f OSC Where: t LEDon: Time where the LED is ON PWM:. Value set in the register (0 - 256), see Figure 36 f OSC: Frequency set in the CLK Synchronization Register, see Figure 50. The refresh rate is defined by the scan-limit and f OSC. (EQ2) ( scanlimit + 1 ) × 256 t REFRESH = -----------------------------------------------------f OSC Where: t REFRESH : Time needed to refresh the matrix scan-limit. is set via the Display Option Register (0 - 11), see Figure 43 f OSC: frequency set in the CLK Synchronization Register, see Figure 50 With the LED on-time and the refresh rate an average LED ON factor can be calculated. (EQ3) t LEDon PWM LEDon avg = ------------------------ = -----------------------------------------------------t REFRESH ( scanlimit + 1 ) × 256 The resulting current is then the Segment Current (set in the Current Source Register) times the average LED ON factor. (EQ4) PWM I LEDavg = I SEG × LEDon avg = I SEG × -----------------------------------------------------( scanlimit + 1 ) × 256 Where: I SEG : Segment Current set via register Figure 44 Example: Assume that following conditions are set in the registers: PWM = 256, scan-limit = 5 (half filled matrix, 66 LEDs), I SEG = 30mA (EQ5) Page 54 Document Feedback 256 I LEDavg = 30mA × -------------------------------- = 5mA ( 5 + 1 ) × 256 ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Package Drawings & Markings Package Drawings & Markings Figure 57: 20-Pin WL-CSP Package RoHS Green Note(s): 1. Pin1= A1 2. ccc coplanarity 3. All dimensions are in μm. ams Datasheet [v2-01] 2016-Oct-12 Page 55 Document Feedback AS1130 − Package Drawings & Mark ings Figure 58: 28-Pin SSOP Package REF MIN NOM MAX REF MIN A A1 A2 b c D E 1.73 0.05 1.68 0.22 0.09 9.90 7.40 1.86 0.13 1.73 0.30 0.17 10.20 7.80 1.99 0.21 1.78 0.38 0.25 10.50 8.20 E1 e L L1 L2 R Θ N 5.00 RoHS 0.55 0.09 0° NOM 5.30 0.65 BSC 0.75 1.25 REF 0.25 BSC 4° 28 MAX 5.60 0.95 8° Green Note(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters, angles in degrees. 3. N is the total number of terminals. Page 56 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Package Drawings & Markings Figure 59: 28-Pin TSSOP Package REF MIN A A1 A2 b c D E E1 e L L1 0.05 0.80 0.19 0.09 9.60 4.30 0.45 NOM 1.00 9.70 6.40 BSC 4.40 0.65 BSC 0.60 1.00 REF MAX REF MIN 1.20 0.15 1.05 0.30 0.20 9.80 R R1 S Θ1 Θ2 Θ3 aaa bbb ccc ddd N 0.09 0.09 0.20 0° 4.50 0.75 - NOM 12 REF 12 REF 0.10 0.10 0.05 0.20 28 RoHS MAX 8° - Green Note(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters, angles in degrees. 3. N is the total number of terminals. ams Datasheet [v2-01] 2016-Oct-12 Page 57 Document Feedback AS1130 − Package Drawings & Mark ings Figure 60: 20-Pin WL-CSP Marking AS1130 XXXX 1130B XXXX Figure 61: Packaging Code XXXX XXXX Tracecode Figure 62: 28-Pin SSOP Marking AS1130 YYWWRZZ @ Page 58 Document Feedback AS1130B YYWWRZZ @ ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Package Drawings & Markings Figure 63: 28-Pin TSSOP Marking AS1130 YYWWRZZ @ Figure 64: Packaging Code YYWWRZZ YY Last two digits of the manufacturing year ams Datasheet [v2-01] 2016-Oct-12 WW Manufacturing week R Plant identifier ZZ @ Free choice / traceability code Sublot identifier Page 59 Document Feedback AS1130 − Ordering & Contact Information Ordering & Contact Information The devices are available as the standard products shown in Figure 65. Figure 65: Ordering Information Ordering Code Marking Description Logic Levels AS1130 132-LED Cross-Plexing Driver with Scrolling Function CMOS AS1130B 132-LED Cross-Plexing Driver with Scrolling Function Mobile Tape and Reel AS1130C 132-LED Cross-Plexing Driver with Scrolling Function CMOS Tape and Reel AS1130D-BSST(1) AS1130D 132-LED Cross-Plexing Driver with Scrolling Function Mobile Tape and Reel AS1130-BTST AS1130 132-LED Cross-Plexing Driver with scrolling Function CMOS Tape and Reel AS1130B 132-LED Cross-Plexing Driver with scrolling Function Mobile Tape and Reel AS1130C 132-LED Cross-Plexing Driver with scrolling Function CMOS Tape and Reel AS1130D-BTST(1) AS1130D 132-LED Cross-Plexing Driver with scrolling Function Mobile Tape and Reel AS1130-BWLT AS1130 132-LED Cross-Plexing Driver with Scrolling Function CMOS Tape and Reel AS1130B 132-LED Cross-Plexing Driver with Scrolling Function Mobile Tape and Reel tbd 132-LED Cross-Plexing Driver with Scrolling Function CMOS Tape and Reel tbd 132-LED Cross-Plexing Driver with Scrolling Function Package AS1130-BSST Address Delivery Form Tape and Reel 0x30 - 0x37 AS1130B-BSST(1) 28-pin SSOP AS1130C-BSST(1) 0x38 - 0x3E 0x30 - 0x37 AS1130B-BTST(1) 28-pin TSSOP AS1130C-BTST(1) 0x38 - 0x3E 0x30 - 0x37 AS1130B-BWLT 20-Pin WL-CSP AS1130C-BWLT(1) 0x38 - 0x3E AS1130D-BWLT(1) Mobile Tape and Reel Note(s): 1. On request Page 60 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Ordering & Contact Information Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v2-01] 2016-Oct-12 Page 61 Document Feedback AS1130 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 62 Document Feedback ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v2-01] 2016-Oct-12 Page 63 Document Feedback AS1130 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 64 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v2-01] 2016-Oct-12 AS1130 − Revision Information Revision Information Changes from 2-00 (2016-Sep-21) to current revision 2-01 (2016-Oct-12) Updated Figure 60 Page 58 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v2-01] 2016-Oct-12 Page 65 Document Feedback AS1130 − Content Guide Content Guide Page 66 Document Feedback 1 1 2 3 General Description Key Benefits & Features Applications Block Diagram 4 6 7 10 Pin Assignment Absolute Maximum Ratings Electrical Characteristics Typical Operating Characteristics 16 16 16 19 20 22 22 22 Detailed Description Cross-Plexing Theorem I²C Interface Command Byte I²C Device Address Byte Initial Power-Up Start-Up Sequence Shutdown Mode 23 23 24 25 35 36 37 38 39 40 41 42 42 43 44 45 46 46 47 48 49 Register Description Register Selection Data Definition of the Single Frames 12x11 LED Matrix Dot Correction Register Control-Registers Picture Register (0x00) Movie Register (0x01) Movie Mode Register (0x02) Frame Time/Scroll Register (0x03) Display Option Register (0x04) Current Source Register (0x05) AS1130 Config Register (0x06) Interrupt Mask Register (0x07) Interrupt Frame Definition Register (0x08) Shutdown & Open/Short Register (0x09) I²C Interface Monitoring Register (0x0A) CLK Synchronization Register (0x0B) Interrupt Status Register (0x0E) AS1130 Status Register (0x0F) AS1130 Open LED Register (0x20 to 0x37) 52 52 54 Typical Application Scroll Function LED Current Calculation 55 60 62 63 64 65 Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet [v2-01] 2016-Oct-12
AS1130-BTST 价格&库存
很抱歉,暂时无法提供与“AS1130-BTST”相匹配的价格&库存,您可以联系我们找货
