NJM4558C
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM4558C integrated circuit is a dual high-gain operational
amplifier internally compensated and constructed on a single
silicon chip.
Combining the features of the NJM741 with the close parameter
matching and tracking of a dual device on a monolithic chip results
in unique performance characteristics. Excellent channel
separation allows the use of the dual device in single NJM741
operational amplifier applications providing density. It is especially
well suited for applications in differential-in, differential-out as well
as in potentiometric amplifiers and where gain and phase
matched channels are mandatory.
■ PACKAGE OUTLINE
■ FEATURES
● Operating Voltage
±4V~±18V
● High Voltage Gain
100dB typ.
● High Input Resistance
5MΩ typ.
● Bipolar Technology
● Package Outline
SOP8,SSOP8
● Internal ESD protection
Human body model (HBM) ±2000V typ.
■ PIN CONFIGURATION
NJM4558CG
(SOP8)
NJM4558CV
(SSOP8)
(Top View)
1
2
3
8
A
7
B
4
6
5
PIN FUNCTION
1.A OUTPUT
2.A -INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B -INPUT
7.B OUTPUT
8.V
NJM4558CG
NJM4558CV
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
V+
-INPUT
+INPUT
OUTPUT
V-
ver. 06
-1-
NJM4558C
■ ABSOLUTE MAXIMUM RATINGS (Ta=25˚C, unless otherwise noted.)
PARAMETER
SYMBOL
RATING
UNIT
V /V
±18
V
Differential Input Voltage (Note1) (Note2)
VID
±36
V
Input Voltage (Note2)
VIC
±18
V
Power Dissipation
PD
Supply Voltage
SOP :
SSOP :
550 (Note3)
350 (Note3)
820(Note4)
440(Note4)
mW
Operating Temperature Range
Topr
- 40~+85
ºC
Storage Temperature Range
Tstg
- 65~+125
ºC
(Note1) Differential voltage is the voltage difference between +INPUT and -INPUT.
(Note2) For supply voltage less than ±15V, the absolute maximum rating is equal to the supply voltage.
The normal operation will establish when any input is within the Common Mode Input Voltage Range of electrical characteristics.
( Note3) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting
( Note4) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting
■ RECOMMENDED OPERATING CONDITIONS (Ta=25ºC)
PARAMETER
Supply Voltage
SYMBOL
CONDITION
V /V
MIN.
TYP.
MAX.
UNIT
±4
±18
V
MIN.
TYP.
MAX.
UNIT
0.5
6
mV
■ ELECTRICAL CHARACTERISTICS (V+/V =±15V, Ta=25ºC, unless otherwise noted.)
PARAMETER
SYMBOL
TEST CONDITION
Input Offset Voltage
VIO
RS≤10kΩ
Input Offset Current
IIO
5
200
nA
Input Bias Current
IB
25
500
nA
Input Resistance
RIN
3
MΩ
Large Signal Voltage Gain
AV
86
100
dB
RL≥2kΩ, VO=±10V
Maximum Output Voltage Swing 1
VOM1
RL≥10kΩ
± 12
± 14
V
Maximum Output Voltage Swing 2
VOM2
RL≥2kΩ
± 10
± 13
V
Input Common Mode Voltage Range
VICM
± 12
± 14
V
Common Mode Rejection Ratio
CMR
RS≤10kΩ
70
95
dB
Supply Voltage Rejection Ratio
SVR
RS≤10kΩ
76.5
100
dB
Operating Current
ICC
3.5
5.7
mA
Slew Rate
SR
1.5
V/μs
f=10kHz
3.5
MHz
Gain Bandwidth Product
GBP
Equivalent Input Noise Voltage1
VNI
RIAA, RS=2.2kΩ, 30kHz LPF
1.4
μVrms
Equivalent Input Noise Voltage2
en
f=1kHz
12
nV/√ Hz
-2-
ver. 06
NJM4558C
TYPICAL CHARACTERISTICS
Large Signal Voltage Gain vs. Frequency
100
80
60
40
10
5
10
100
1k
10k 100k
Frequency [Hz]
1M
10M
1k
vs. Load Resistance
10k
100k
1M
Frequency [Hz]
10M
Maximum Output Voltage vs. Load Resistance
V /V =±15V, Ta=25ºC
30
V /V =±15V, Gv=open
15
+VOM
10
Maximum Output Voltage [V]
VOPP [VPP]
V+/V-=±15V, RL=2kΩ, Ta=25ºC
30
VOPP [V]
120
Large Signal Voltage Gain [dB]
Maximum Output Voltage Swing vs. Frequency
25
10
5
-VOM
-15
100
1k
10k
Load Resistance [Ω]
100
100k
100k
V /V =±15V,GV=20dB,RG=10kΩ,RS=200Ω,RF=2kΩ,Ta=25°C
V /V =±15V, Gv=20dB, RF=500Ω, RS=50Ω, Ta=25ºC
50
1k
10k
Load Resistance [Ω]
THD+N vs. Output Voltage
Voltage Noise vs. Frequency
1
45
40
0.1
35
30
THD+N [%]
[nV/Hz]
Ta=85ºC
Ta=25ºC
Ta=-40ºC
-10
5
25
15
0.001
10
5
ver. 06
Ta=-40ºC
Ta=25ºC
Ta=85ºC
10
100
1k
Frequency [Hz]
10k
100k
0.0001
0.01
20Hz
1kHz
10kHz
20kHz
0.1
1
10
100
Output Voltage [Vrms]
-3-
NJM4558C
■ TYPICAL CHARACTERISTICS
Supply Current vs. Temperature
Supply Current vs. Supply Voltage
Ta=25ºC
7
6
5
Supply Current [mA]
Supply Current [mA]
6
Ta=25ºC
Ta=-40ºC
4
3
Ta=85ºC
2
1
5
V+/V-=±18V
V+/V-=±15V
4
3
V /V =±4V
2
1
±2
±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18
Supply Voltage V+/V- [V]
-50
Input Offset Voltage vs. Temperature
2.0
Input Offset Voltage [mV]
1.0
0.0
25 50 75 100 125 150
Ambient Temperature [ºC]
Ta=25ºC
3.0
V+/V-=±4V
V /V =±15V
-25
Input Offset Voltage vs. Supply Voltage
V+/V-=±15V
3.0
V /V =±15V
7
V /V =±18V
-1.0
-2.0
-3.0
2.0
Ta=-40ºC
1.0
0.0
Ta=25ºC
Ta=85ºC
-1.0
-2.0
-3.0
-50
-25
Ambient Temperature Ta [ºC]
±2
vs. Common-Mode Input Voltage
3.0
V+/V-=±15V
2.0
1.0
Ta=-40ºC
0.0
-1.0
Ta=85ºC
Ta=25ºC
-2.0
-3.0
-15
-4-
-10
-5
10
Common-Mode Input Voltage [V]
15
ver. 06
NJM4558C
3.0
2.0
Ta=-40ºC
1.0
0.0
-1.0
Ta=85ºC
V+/V-=±15V
50
Input Bias Current [nA]
Input Bias Current vs. Temperature
V+/V-=±4V
Ta=25ºC
-2.0
40
30
-4
-3
-2
-1
2
3
-50
4
50
75 100 125 150
vs. Supply Voltage
Maximum Output Voltage Swing vs. Temperature
V+/V-=±15V, RL=10kΩ
15
-25
RL=2kΩ, Ta=25ºC
18
5
-10
-VOM
-15
12
+VOM
6
-VOM
-12
-18
-50
ver. 06
+VOM
10
-25
±2
-5-
NJM4558C
■PACKAGE OUTLINE UNIT : mm
SOP8
6.0±0.2
3.9±0.1
4.9±0.1
0.1 S
0.42±0.07
0.25 M
0.175±0.075
0.22±0.03
1.55±0.2
1.27
0.825±0.425 0°~ 7°
S
SSOP8
+0.3
3.50 -0.1
0 ~ 10º
0.5±0.2
4.4±0.2
6.4±0.3
5
8
1
4
0.65
+0.1
0.15 -0.05
0.1±0.1
1.15±0.1
0.9MAX
0.1
0.22±0.1
-6-
0.1
M
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
ver. 06
很抱歉,暂时无法提供与“NJM4558CG-TE2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07255
- 50+0.84402
- 150+0.74596
- 500+0.62381
- 2500+0.56938
- 5000+0.53666
