CONDUCTIVE PLASTIC 3 TURNS TYPE
MC
Basic construction
RoHS compliant
筐体
Case
抵抗体
Resistor
ワイパ
Wiper
端子
Terminal
ばね
Spring
軸
Shaft
取り付けねじ部
Mounting screw
シャフトアッシー
Shaft assy
プレート
Plate
抵抗体ホルダ
Resistor holder
ワイパホルダ
Wiper holder
Conductive plastic 3 turns type
■ FEATURES
● Compact size
● Fine setting is possible
● Long life
● High following characteristics
● High resolution (Essentially infinite)
● RoHS compliant
■ PART NUMBER DESIGNATION
MC1003-000-502
Series name
Nominal resistance value (Ω)
502: 5 k
103:10 k
203:20 k
■ LIST OF PART NUMBERS
Part number
5k
MC1003-000-502
10 k
MC1003-000-103
20 k
MC1003-000-203
※ Verify the above part numbers when placing orders.
The products indicated by
mark are manufactured upon receipt of order basis.
MC
POTENTIOMETERS
■ STANDARD SPECIFICATIONS
● Electrical characteristics
● Mechanical characteristics
5 kΩ, 10 kΩ, 20 kΩ
Resistance torelance
± 20 %
Resolution
Operating torque
0.19 W
Independent linearity
±1%
Effective electrical angle
1080°
Temp. coefficient of resistance
± 400 ppm/°C maximum
1 million cycles
Tighten screw torque
49 N·cm {5 kgf·cm} maximum
● Environmental characteristics
1000 MΩ (at DC250 V) minimum
JC, JP, M結線図
Dielectric strength
0.294 N·cm {30 gf·cm} maximum
Rotational life
JC/JCF/JCL 定格電力軽減曲線
Insulation resistance
4.41 N·cm {0.45 kgf·cm} maximum
Stop strength
Power rating
1080° ± 10°
Mechanical angle
Operating temp. range
−40 ~ 85 °C
Net weight
Approx. 2.5 g
Protection grade
500 V rms (1 min)
IP40
■ RATED POWER DERATING CURVE
Power rating ratio (%)
100
+ 40
– 40
+ 85
Ambient temperature (℃)
■ OUTLINE DIMENSIONS
6.5
MAX. 1
接着剤盛り上がり
Adhesive thickness
3–2
φ1
M
6 (P = 0.75)
付け根部分不完全ネジ部1以下
Unthreaded portion at base : 1 max.
回転止め部詳細
Anti-rotation details
1
0.8
回転止め
(溝深さ)
Anti-rotation groove depth
②
3.7 3.7
<付属品 Accessories>
<付属品 Accessories>
M6, P=0.75
M6, P=0.75φ
6.3
4.5
R
①
0.1
0.6
φ 3 –0.05
Mounting
face
0.5
結線図
Wiring diagram
(3.5)
φ 8-0.2
φ 10 +0.4
12.6
1.2
2
9
1. Nut
1
9
(M 6六角ナット)
(M 6 hex.nut)
φ1
1
③
3.7
10
(Unit: mm)
6.4
0.63
φ 6.4 with φteeth)
(内歯付座金 Washer
0.63
1.3
1.3
9 2 歯高さ:1、内歯数:9
φ 112
φ 11
Tooth height : 1, No. of teeth : 9
t = 0.63(座金厚み Washer thickness : 1.3)
2. Washer
CW
很抱歉,暂时无法提供与“MC1003-000-502”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+285.012331+37.05068
- 20+223.4542720+29.04834
- 40+211.1064440+27.44316
- 60+204.1874660+26.54371
- 100+195.78457100+25.45136
- 260+180.95414260+23.52346
- 500+171.44670500+22.28752
- 国内价格
- 5+223.06856
- 25+212.93173
- 100+204.82143
- 国内价格
- 1+270.05163
- 2+253.85811
