USB3065-30-00-A
USB3065-30-00-A
    GCT
USB3065-30-00-A 数据手册
H NO TR FO E R N CO EW MM E DE ND SIG ED NS 7.68±0.30 Designed to comply with physical, electrical and environmental requirements of Micro USB Standard (USB2.0). 2.70 4.00 PCB Mount Orientation 4.00 Pin 5 1.45 F 1.90 5.49 2.25 2.30 3.45 7.40 0.40 Pin 1 1.20 Ø0 .65 1.40 G 0.65 PCB Edge Specifications 规格 0.50 5.20 7.50 9.80 0.49 E Material 物料 Plastic Housing 塑胶外壳: LCP, UL94V-0, Black Contact Terminal 接触端子: Copper Alloy Metallic Shell 金属外壳: Stainless Steel SUS 304, T = 0.25mm Plating 电镀 Underplating 底层电镀: 50µ" Nickel Finish表面处理:Contact Area 接触面积: 30µ" Gold plating Solder Tails 焊接末端: Gold Flash Metallic Shell 金属外壳: Matte Tin 1.80 4.75 6.20 7.78±0.30 Recommended PCB Layout As viewed from component side General Tolerance: ±0.05 Pin 1 2.70+0.05 -0.08 2.40 0.05 Electrical 电气 Voltage Rating电压额定值: 30 V AC Current Rating电流额定值: Signal (Pins 2,3,4):1.0A. Power (Pins1,5):1.8A. Operating Temperature 工作温度: -30°C to +85°C Contact Resistance接触电阻值: 30mΩ max. Insulating Resistance绝缘电阻值: 1000MΩ min. Dielectric Withstand Voltage耐电压: 500V AC/Minute 0.60 2.73±0.30 0.38 0.65 Component Outline 3.50±0.10 2.35 3.50Max. 0.35±0.05 D Solder Area 1.85+0.04 -0.02 6.90+0.04 -0.02 Section A:A 4.40 Ø0.45 Pin 5 5.40+0.04 -0.02 C A 2.15 Ordering Grid 5.00 USB3065 A Contact Plating 30 = 30u" Gold A A Request Samples and Quotation (1.5K per Reel) 0.28±0.03 0.65±0.05 Part Number Product Description USB3065 Micro USB Receptacle, Type B, 5 Pin, SMT, Horizontal, Bottom Mount (Standard), Optional Plastic Locating Peg Drawing Date 4th April 2011 2.60±0.08 By Detail 1 2 Mechanical & Environmental 机械 & 环境 Mating Force插入力: 35N max. Unmating Force拨出力: 10N min. Durability耐久性: 10,000 Cycles Packing Options A = Tape & Reel Plastic Locating Peg 00 = Without (Standard) 01 = With Ø 0. 0.60 45 0.90 2.85 B XX 30 3 4 Revision Date 5 CC Tolerances (Except as Noted) USB3065 E PCN E2 13/12/16 X.X° ± 2° X.X ± 0.2 X.XX° ± 1° X.XX ± 0.10 X.XXX ± 0.05 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By ASE 8 Sheet No. 1/2 NO TR FO E R N CO EW MM E DE ND SIG ED NS FIRST APPROXIMATELY 15PCS EMPTY CARRIER H 4.0 FIRST APPROXIMATELY 15PCS EMPTY CARRIER 12.0 16.0 4.0 G I/O Direction 卷盘绕逆时针方向转动 Peel of Angle 剥离角度 10° Cover Tape 盖带 F Carrier Tape 载带 ø330 ° 120 Ø2 3 Ø13.5 120° E Notes注意: 1. Peeling off force of top tape: 0.1-1.3N 2. Part Conforms to EIA-481-C Standards产品符合EIA-481-C标准 3. All dimensions in millimeters 所有尺寸均是毫米 4. 10 sprocket hole pitch cumulative tolerance±0.2mm Detail F 6 P S Detail F D Cardboard 纸板 Reel 卷筒 Waterproof bag 防水袋 Label 标签 Protection Tape 保护胶带 296mm C Carton 纸箱 Triangle Liner 三角形班轮 4 Reels 4 卷轴 1500 pieces/reel 1500 件/卷 B Products P/N 35 0m m 700x600x0.08 PCS/Reel Reels/Carton PCS/Carton USB3065-30-XX-A 1500 4 6000 Part Number Product Description USB3065 Micro USB Receptacle, Type B, 5 Pin, SMT, Horizontal, Bottom Mount (Standard), Optional Plastic Locating Peg Drawing Date A 4th April 2011 By Detail 1 m 0m 35 2 3 4 Revision Date 5 CC USB3065 E PCN E2 13/12/16 Tolerances (Except as Noted) Length Angle Units: Metric (mm) - - C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By ASE 8 Sheet No. 2/2
USB3065-30-00-A 价格&库存
很抱歉,暂时无法提供与“USB3065-30-00-A”相匹配的价格&库存,您可以联系我们找货
