TPF141-TR
TPF141-TR
    3PEAK(思瑞浦)
    SOT23-6
    全高清复合视频滤波驱动器
TPF141-TR 数据手册
TPF141 Full-HD Composite Video Filter Driver Features Description   Single FHD Video Filter Support HDCVI-1080p /1080i/720p, VGA/SVGA/XGA Optimized 6th-order Butterworth Video reconstruction filter: FHD Channel: -3dB ≥ 72MHz Support Multiple Input Biasing: - Provide 80-mV Level-Shift when DC-Coupled - Transparent Input Clamping when AC-Coupled - Support External DC Biasing when AC-Coupled Very Low Quiescent Current: 11.5 mA(at 3.3V, Typical) 6dB Gain(2V/V), Rail TO Rail Output AC- or DC-Coupled Output Driving Dual Video Loads (75Ω) Wide Power Supply: +3.0V to +5.5V Single Supply Robust ESD Protection:  Robust 8kV – HBM and 2kV – CDM ESD Rating Green Product, SOT23-6 Package       Applications      Video Signal Amplification Set-Top Box Video Driver PVR、DVD Player Video Buffer Video Buffer for Portable or USB-Powered Video Devices HDTV TPF141 is a specially designed for consumer applications, high-performance, low-cost video reconstruction filter, it combine excellent video performance and low power consumption perfectly. It incorporates one Full high-definition (FHD) filter channels. The filter feature sixth-order Butterworth characteristics that are useful as digital-to-analog converter (DAC) reconstruction filters or as analog-to-digital converter (ADC) anti-aliasing filters. The FHD filters can be bypassed to support filters. The FHD filters can be bypassed to support 1080p60 video or up to quad extended graphics array (QXGA) RGB video. As part of the TP141 flexibility, the input can be configured for ac- or dc-coupled inputs. The 84-mV output level shift allows for a full sync dynamic range at the output with 0-V input. The ac-coupled modes include a transparent sync-tip clamp option for Y', and G'B'R' signals. AC- coupled biasing for C'/P'B/P'R channels can easily be achieved by adding an external resistor to VS+. The TP141 rail-to-rail output stage with 6-dB gain allows for both ac and dc line driving. The ability to drive two lines, or 75-Ω loads, allows for maximum flexibility as a video line driver. The 11.5-mA total quiescent current at 3.3 V makes it an excellent choice for power-sensitive video applications. TPF141 is available in SOT23-6 package. Its operation temperature range is from −40°C to +85°C. Related Resources AN-1201: Application notes of TPF1xx Function Block Figure 1. Rev. A www.3peakic.com ©2013 3PEAK INCORPORATED TPF141 Full-HD Composite Video Filter Driver Order Information Operating Order Number Temperature Package Range TPF141-TR -40 to 85°C SOT23-6 Marking Transport Media, Information Quantity F41 Tape and Reel, 3000 Pin configuration (Top View) Pin Name FHD IN Pin Function Full-HD video input, LPF = 72 MHz +VS Positive Power Supply GND Ground FHD OUT Full-HD video output, LPF = 72 MHz NC No Connection Figure 2. Absolute Maximum Ratings* VIN IO TJ TA TSTG TL * Note: Parameters Power Supply, VDD to GND Input Voltage Output Current Maximum Junction Temperature Operating Temperature Range Storage Temperature Range Lead Temperature (Soldering 10 sec) Value Units 6.0 V VDD + 0.3V to GND - 0.3V 65 IO 150 TJ –45 to 85 TA –65 to 150 TSTG 300 TL Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (1) This data was taken with the JEDEC low effective thermal conductivity test board. (2) This data was taken with the JEDEC standard multilayer test boards. ESD, Electrostatic Discharge Protection Symbol Parameter Condition HBM Human Body Model ESD CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E ©2014 3PEAK INCORPORATED MIL-STD-883H Method 3015.8 ~ 2 ~ Minimum Level Unit 8 kV 2 kV Rev. A www.3peakic.com TPF141 Full-HD Composite Video Filter Driver Electrical Characteristics All test condition is VDD = 3.3V, TA = +25°C, RL = 150Ω to GND, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS 5.5 V Input Electrical Specifications VDD Supply Voltage Range 3.0 ICC Quiescent current (IQ) VOLS Output Level Shift Voltage VIN = 0V, no load, input referred ICLAMP-DOWN Clamp Discharge Current ICLAMP-UP VDD = 3.3V, VIN = 500mV, no load 11.5 14.27 mA VDD = 5.0V, VIN = 500mV, no load 15 18.53 mA 53 80 124 mV VIN=300mV, measure current 1.1 2.0 5.3 μA Clamp Charge Current VY = -0.2V -1.5 -1.7 VCLAMP Input Voltage Clamp IY = -100μA -40 0 +40 mV AV Voltage Gain 5.9 6.01 6.03 dB PSRR Power Supply Rejection Ratio VOL Output Voltage Low Swing VIN = -0.3V, RL =75Ω VOH Output Voltage High Swing VIN = 3V, RL =75Ω to GND (dual load) 3 ISC Short-circuit current VIN = 2V, 10Ω, output to GND 65 mA VIN =0.1V, output short to VDD 65 mA VIN=0.5V,1V or 2V RL=150Ω to GND ΔVDD = 3.3V to 3.6V ΔVDD = 5.0V to 5.5V, 50Hz mA 61 dB 67 dB 0.05 0.1 V 3.05 3.1 V AC Electrical Specifications f-1dB -1dB Bandwidth RL=150Ω 53.1 63.2 72.9 MHz f-3dB -3dB Bandwidth RL=150Ω 63.7 71.5 80.1 MHz Att148MHz Stop Band Attenuation f =148MHz 34 39 dB SR Slew Rate 2V output step, 80% to 20% 300 V/μs dG Differential Gain Video input range 1V 0.1 1 % dP Differential Phase Video input range 1V 0.3 0.6 ° THD Total Harmonic Distortion f=10MHz, VOUT=1.4VPP 0.15 % f=22MHz, VOUT=1.4VPP 0.6 % D/DT Group Delay Variation f = 100kHz to 27MHz 2.5 ns 6.0 ns tPD Propagation Delay XTALK Channel Crosstalk f = 100kHz to 60MHz Maximum delay from input to output: (100kHz to 60MHz) f = 1MHz, VOUT=1.4VPP SNR Signal-to-Noise Ration ROUT_AC Output Impedance Rev. A www.3peakic.com 11.0 ns -74 dB f= 100kHz to 60MHz 64 dB f = 10MHz 0.5 Ω ~3~ -68 18.0 ©2014 3PEAK INCORPORATED TPF141 Full-HD Composite Video Filter Driver Typical Performance Characteristics All test condition is VDD = 3.3V, TA = +25°C, RL = 1 5 0.8 4 NORMALIZED GAIN (dB) NORMALIZED GAIN (dB) 150Ω to GND, unless otherwise noted. 0.6 0.4 0.2 0 -0.2 -0.1dB@50MHz -0.4 VDD =3.3V RL =150Ω CL =15pF -0.6 -0.8 -1 100k 3 2 1 0 -1 -3dB@72MHz -2 VDD =3.3V RL =150Ω CL =15pF -3 -4 1M 10M FREQUENCY (Hz) -5 100k 100M Figure3. Small-Scale Frequency Response 1M 10M FREQUENCY (Hz) 100M Figure4. Large-Scale Frequency Response 0 5 -100 3 2 CL =15pF 1 CL =5pF PHASE (O) NORMALIZED GAIN (dB) 4 0 -1 CL =20p -2 -3 -4 -300 -400 VDD =3.3V RL =150Ω CL =15pF -500 VDD =3.3V RL =150Ω -5 100k -200 1M 10M FREQUENCY (Hz) -600 100k 100M 40.0 10 NORMALIZED GAIN (dB) GROUP DELAY (ns) 35.0 30.0 25.0 20.0 15.0 10.0 0.0 -5.0 100M Figure6. Gain Vs. Frequency Figure5. Gain Vs. Frequency With CLOAD 5.0 1M 10M FREQUENCY (Hz) VDD =3.3V RL =150Ω CL =15pF 0 -10 -20 148MHz, -39dB -30 -40 -50 VDD =3.3V RL =150Ω CL =15pF -60 -10.0 1M 10M 100M FREQUENCY (Hz) 1M 1G Figure7. Group Delay vs Frequency ©2014 3PEAK INCORPORATED 10M 100M FREQUENCY (Hz) Figure8. Stop Band Attenuation ~ 4 ~ Rev. A www.3peakic.com 1G TPF141 Full-HD Composite Video Filter Driver 0 VDD =3.3V -10 45 40 CURRENT (mA) PSSR (dB) -20 -30 -40 -50 -60 35 30 25 20 15 10 -70 5 0 3.0 -80 1k 10k 100k 1M FREQUENCY (Hz) 10M 100M Figure9. PSRR Vs. Frequency 4.0 4.5 5.0 SUPPLY VOLTAGE (V) 5.5 Figure10. Current Vs. Supply Voltage 0.9 2.0 0.8 1.5 AMPLITUDE (V) AMPLITUDE (V) 3.5 VDD =+3.3V RL =100Ω VOUT=1VP-P 1.0 0.5 VDD =+3.3V RL =100Ω VOUT=200mVP-P 0.7 0.6 0.5 tRISE=7.75ns tRISE=3.25ns tFALL =7.41ns 0.0 tFALL =3.59ns 0.4 0 20 40 60 80 100 TIME (ns) 120 140 160 0 Figure11. Large-Signal Pulse Response Vs. Time Rev. A www.3peakic.com 20 40 60 80 100 TIME (ns) 120 140 160 Figure12. Small-Signal Pulse Response Vs. Time ~5~ ©2014 3PEAK INCORPORATED TPF141 Full-HD Composite Video Filter Driver Application Information The TPF141 is targeted for systems that require one full high-definition (FHD) video outputs. Although it can be used for numerous other applications, the needs and requirements of the video signal are the most important design parameters of the TPF141. The TPF141 incorporates many features not typically found in integrated video parts while consuming very low power. Internal Sync Clamp The typical embedded video DAC operates from a ground referenced single supply. This becomes an issue because the lower level of the sync pulse output may be at a 0V reference level to some positive level. The problem is presenting a 0V input to most single supply driven amplifiers will saturate the output stage of the amplifier resulting in a clipped sync tip and degrading the video image. A larger positive reference may offset the input above its positive range. The TPF141 features an internal sync clamp and offset function to level shift the entire video signal to the best level before it reaches the input of the amplifier stage. These features are also helpful to avoid saturation of the output stage of the amplifier by setting the signal closer to the best voltage range. The simplified block diagram of the TPF141 in Figure-1. The AC coupled video sync signal is pulled negative by a current source at the input of the comparator amplifier. When the sync tip goes below the comparator threshold the output comparator is driven negative, The PMOS device turns on clamping sync tip to near ground level. The network triggers on the sync tip of video signal. Droop Voltage and DC Restoration Selection of the input AC-coupling capacitance is based on the system requirements. A typical sync tip width of a 64μs NTSC line is 4μs during which clamp circuit restores its DC level. In the remaining 60μs period, the voltage droops because of a small constant 2.0μA sinking current. If the AC-coupling capacitance is 0.1μF, the maximum droop voltage is ©2014 3PEAK INCORPORATED about 1mV which is restored by the clamp circuit. The maximum pull-up current of the clamp circuit is 1.7mA. For a 4μs sync tip width and 0.1μF capacitor, the maximum restoration voltage is about 80mV. The line droop voltage will increase if a smaller AC-coupling capacitance is used. For the same reason, if larger capacitance is used the line droop voltage will decrease. Table 1 is droop voltage and maximum restoration voltage of the clamp for typical capacitance. Table 1. Maximum restoration voltage and droop voltage of Y signals for different capacitance CAP VALUE (nF) 100 1,000 DROOP IN 60μs (mV) 1.2 0.12 CHARGE IN 4μs (mV) 68 6.8 Low Pass Filter--Sallen Key The Sallen Key is a classic low pass configuration. This provides a very stable low pass function, and in the case of the TPF141, the six-pole roll-off at around 72MHz. The six-pole function is accomplished with an RC low pass network placed in series with and before the Sallen Key. Output Couple TPF141 output could support both “AC Couple” and “DC Couple”, if use “AC Couple”, this capacitor is typically between 220-μF and 1000-μF, although 470-μF is common. This value of this capacitor must be this large to minimize the line tilt (droop) and/or field tilt associated with ac-coupling as described previously in this document. The TPF141 internal sync clamp makes it possible to DC couple the output to a video load, eliminating the need for any AC coupling capacitors, thereby saving board space and additional expense for capacitors. This makes the TPF141 extremely attractive for portable video applications. Additionally, this solution completely eliminates the issue of field tilt in the lower frequency. The trade off is greater demand of supply current. Typical load current for AC coupled is around 1mA, compared to typical 6.6mA used when DC ~ 6 ~ Rev. A www.3peakic.com TPF141 Full-HD Composite Video Filter Driver coupling. PDMAX =Vs  I SMAX +(Vs  VOUT) Output Drive Capability and Power Dissipation Where: VS = Supply voltage ISMAX = Maximum quiescent supply current VOUT = Maximum output voltage of the application RLOAD = Load resistance tied to ground With the high output drive capability of the TPF141, it is possible to exceed the +125°C absolute maximum junction temperature under certain load current conditions. Therefore, it is important to calculate the maximum junction temperature for an application to determine if load conditions or package types need to be modified to assure operation of the amplifier in a safe operating area. The maximum power dissipation allowed in a package is determined according to Equation: PDMAX = VOUT RL By setting the two PDMAX equations equal to each other, we can solve the output current and RLOAD to avoid the device overheat. Power Supply Bypassing Printed Circuit Board Layout As with any modern operational amplifier, a good printed circuit board layout is necessary for optimum performance. Lead lengths should be as short as possible. The power supply pin must be well bypassed to reduce the risk of oscillation. For normal single supply operation, a single 4.7μF tantalum capacitor in parallel with a 0.1μF ceramic capacitor from VS+ to GND will suffice. TJMAX  TAMAX  JA Where: TJMAX = Maximum junction temperature TAMAX = Maximum ambient temperature ΘJA = Thermal resistance of the package The maximum power dissipation actually produced by an IC is the total quiescent supply current times the total power supply voltage, plus the power in the IC due to the load, or: for sourcing: VIDEO FILTER DRIVER SELECTION GUIDE P/N Product Description TPF110 /TPF110L Low power, enable function and Channel -3dB Bandwidth Package 1-SD 9MHz SC70-5 SOT23-6 3-SD 9MHz SO-8 4-SD 9MHz MSOP-10 TSSOP-14 6-SD 9MHz TSSOP-14 3-ED 13.5MHz SO-8 3-HD 36MHz SO-8 1-SD& 3-SD 9MHz 36MHz MSOP-10 TSSOP-14 th SAG correction, 1 channel 6 order 9MHz TPF113 Low power 3 channel, 6th-order 9MHz SD video filter TPF114 Low power 4 channel, 6th-order 9MHz SD video filter TPF116 Low power 4 channel, 6th-order 9MHz SD video filter for CVBS, SVIDEO TPF123 3 channel 6th-order 13.5MHz, 960H/720H-CVBS video filter or Y’Pb’Pr 480P/576P video filter TPF133 Low power 3 channel, 6th-order 36MHz HD video filter TPF134 Low power 3 channel, 6th-order 36MHz HD video filter and 1 channel Rev. A www.3peakic.com ~7~ ©2014 3PEAK INCORPORATED TPF141 Full-HD Composite Video Filter Driver SD video filter TPF136 Low power 3 channel, 6th-order 36MHz HD video filter and 3 channel 3-SD& 3-HD 9MHz 36MHz TSSOP-20 3-FHD 72MHz SO-8 1-SD& 3-FHD 9MHz 72MHz MSOP-10 TSSOP-14 3-SD& 3-FHD 9MHz 72MHz TSSOP-20 3-CH 220MHz SO-8 SD video filter TPF143 Low power 3 channel, 6th-order 72MHz Full HD video filter TPF144 Low power 3 channel, 6th-order 72MHz Full HD video filter and 1 channel SD video filter TPF146 Low power 3 channel, 6th-order 72MHz Full HD video filter and3 channel SD video filter TPF153 Low power 3 channel, 6th-order 220MHz Full HD video filter ©2014 3PEAK INCORPORATED ~ 8 ~ Rev. A www.3peakic.com TPF141 Full-HD Composite Video Filter Driver Package Outline Dimensions SOT23-6 Symbol Dimensions Dimensions In Millimeters In Inches Min Max Min Max A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e Rev. A www.3peakic.com ~9~ 0.950TYP 0.037TYP e1 1.800 2.000 0.071 0.079 L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° ©2014 3PEAK INCORPORATED TPF141 Full-HD Composite Video Filter Driver IMPORTANT NOTICE "PRELIMINARY" PRODUCT INFORMATION DESCRIBES PRODUCTS THAT ARE IN PRODUCTION, BUT FOR WHICH FULL CHARACTERIZATION DATA IS NOT YET AVAILABLE. 3PEAKIC MICROELECTRONICS CO. LTD BELIEVES THAT THE INFORMATION CONTAINED IN THIS DOCUMENT IS ACCURATE AND RELIABLE. HOWEVER, THE INFORMATION IS SUBJECT TO CHANGE WITHOUT NOTICE AND IS PROVIDED “AS IS” WITHOUT WARRANTY OF ANY KIND (EXPRESS OR IMPLIED). CUSTOMERS ARE ADVISED TO OBTAIN THE LATEST VERSION OF RELEVANT INFORMATION TO VERIFY, BEFORE PLACING ORDERS, THAT INFORMATION BEING RELIED ON IS CURRENT AND COMPLETE. ALL PRODUCTS ARE SOLD SUBJECT TO THE TERMS AND CONDITIONS OF SALE SUPPLIED AT THE TIME OF ORDER ACKNOWLEDGMENT, INCLUDING THOSE PERTAINING TO WARRANTY, INDEMNIFICATION, AND LIMITATION OF LIABILITY. NO RESPONSIBILITY IS ASSUMED BY 3PEAKIC MICROELECTRONICS CO. LTD FOR THE USE OF THIS INFORMATION, INCLUDING USE OF THIS INFORMATION AS THE BASIS FOR MANUFACTURE OR SALE OF ANY ITEMS, OR FOR INFRINGEMENT OF PATENTS OR OTHER RIGHTS OF THIRD PARTIES. THIS DOCUMENT IS THE PROPERTY OF 3PEAKIC MICROELECTRONICS CO. LTD AND BY FURNISHING THIS INFORMATION, 3PEAKIC MICROELECTRONICS CO. LTD GRANTS NO LICENSE, EXPRESS OR IMPLIED UNDER ANY PATENTS, MASK WORK RIGHTS, COPYRIGHTS, TRADEMARKS, TRADE SECRETS OR OTHER INTELLECTUAL PROPERTY RIGHTS. 3PEAKIC MICROELECTRONICS CO. LTD OWNS THE COPYRIGHTS ASSOCIATED WITH THE INFORMATION CONTAINED HEREIN AND GIVES CONSENT FOR COPIES TO BE MADE OF THE INFORMATION ONLY FOR USE WITHIN YOUR ORGANIZATION WITH RESPECT TO 3PEAKIC MICROELECTRONICS CO. LTD INTEGRATED CIRCUITS OR OTHER PRODUCTS OF 3PEAKIC MICROELECTRONICS CO. LTD. THIS CONSENT DOES NOT EXTEND TO OTHER COPYING SUCH AS COPYING FOR GENERAL DISTRIBUTION, ADVERTISING OR PROMOTIONAL PURPOSES, OR FOR CREATING ANY WORK FOR RESALE. CERTAIN APPLICATIONS USING SEMICONDUCTOR PRODUCTS MAY INVOLVE POTENTIAL RISKS OF DEATH, PERSONAL INJURY, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE (“CRITICAL APPLICATIONS”). 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS ARE NOT DESIGNED, AUTHORIZED OR WARRANTED FOR USE IN AIRCRAFT SYSTEMS, MILITARY APPLICATIONS, PRODUCTS SURGICALLY IMPLANTED INTO THE BODY, AUTOMOTIVE SAFETY OR SECURITY DEVICES, LIFE SUPPORT PRODUCTS OR OTHER CRITICAL APPLICATIONS. INCLUSION OF 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS IN SUCH APPLICATIONS IS UNDERSTOOD TO BE FULLY AT THE CUSTOMER'S RISK AND INCLUSION DISCLAIMS AND MAKES NO WARRANTY, EXPRESS, STATUTORY OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR PARTICULAR PURPOSE, WITH REGARD TO ANY DISCLAIMS PRODUCT THAT IS USED IN SUCH A MANNER. IF THE CUSTOMER OR CUSTOMER'S CUSTOMER USES OR PERMITS THE USE OF 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS IN CRITICAL APPLICATIONS, CUSTOMER AGREES, BY SUCH USE, TO FULLY INDEMNIFY 3PEAKIC MICROELECTRONICS CO. LTD, ITS OFFICERS, DIRECTORS, EMPLOYEES, DISTRIBUTORS AND OTHER AGENTS FROM ANY AND ALL LIABILITY, INCLUDING ATTORNEYS' FEES AND COSTS, THAT MAY RESULT FROM OR ARISE IN CONNECTION WITH THESE USES. THE LOGO DESIGNS OF 3PEAKIC MICROELECTRONICS CO. LTD ARE TRADEMARKS OF DESIGNS. ALL OTHER BRAND AND PRODUCT NAMES IN THIS DOCUMENT MAY BE TRADEMARKS OR SERVICE MARKS OF THEIR RESPECTIVE OWNERS. Contact information: USA: 635 W. Alma School Road, Suite102 Chandler, USA. AZ 85234 Shanghai-China: Room 401-407 No.1278 Keyuan Road, Zhangjiang High-tech Park, Pudong New District, Shanghai, China Zip Code: 201203 Suzhou-China: Suite 304, Building B2, Creative Industrial Park, No.328 Xinghu Street, Industrial Park, Suzhou, Jiangsu Province, China Zip Code: 215123 ©2014 3PEAK INCORPORATED ~ 10 ~ Rev. A www.3peakic.com
TPF141-TR 价格&库存
很抱歉,暂时无法提供与“TPF141-TR”相匹配的价格&库存,您可以联系我们找货
TPF141-TR
  • 10+0.54854
  • 100+0.42412
  • 300+0.36191
库存:2417
TPF141-TR
    • 1+0.32211
    库存:86
    TPF141-TR
      • 3000+0.29700
      库存:150000
      TPF141-TR
        • 1+0.58764
        • 200+0.37848
        • 1500+0.32868
        • 3000+0.29050
        库存:1968
        TPF141-TR
        • 1+0.34580
        库存:480
