Technical Data Sheet
R2CT PLUG
PAGE 1/6
ISSUE 04-01-19C
SERIES R2CT
PART NUMBER R2CT115000
All dimensions are in mm. Tolerances according ISO 2768 m-H
DESCRIPTION
REP
1
2
3
4
5
6
7
8
9
COMPONENT
COUPLING NUT
NUT TAIL OF PIG
TIGHTENING CONE
CLAMP NUT ELASTIC SHELL
CLAMP SPLIT GASKET
O-RING BODY GASKET
PLUG BODY
GASKET SEALING CAP
PLUG PROTECTION CAP
MATERIALS
ALUMINIUM
PA6.6 GF
PA6.6
PA6.6
NITRILE (NBR)
SILICONE
ZAMAK
SILICONE
PBT GF
PLATING
NONE
NA
NA
NA
NA
NA
NICKEL
NA
NA
This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written
agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R2CT PLUG
PAGE 2/6
ISSUE 04-01-19C
SERIES R2CT
GENERAL CHARACTERISTICS
Mechanical
Mating endurance
Tensile load
Vibration
IEC 61300-2-2
IEC 61300-2-4
100 cycles
200N
compliant
Environmental
Protection class
Operating temperature
RoHS
IEC 60529
IEC 61300-2-22
IP65
-40°C to +85°C
Compliant
All types of optical cable assemblies with field cable : LC duplex, multimode or
singlemode
Diameter of field cable: 4,8 to 7 mm.
For other cable diameter, contact us.
Compatibility
Unitary plastic bag 180mm*130mm
Packaging
FAN OUT DIMENSIONS
VALIDATION PLAN
Parameter
Specification
OPTICAL
Insertion Loss
Return Loss
IEC 61300-3-4
IEC 61300-3-6
MECHANICAL
Mating Endurance
Vibrations
Shocks
IEC 61300-2-2
IEC 61300-2-1
IEC 61300-2-9
ENVIRONMENTAL
Ingress Protection
Temperature cycling
Salt Mist
IEC 60529
IEC 61300-2-22
IEC 61300-2-26
R2CT PLUG
PAGE 3/6
ISSUE 04-01-19C
SERIES R2CT
R2CT PLUG
PAGE 4/6
ISSUE 04-01-19C
SERIES R2CT
R2CT PLUG
PAGE 5/6
ISSUE 04-01-19C
SERIES R2CT
R2CT PLUG
PAGE 6/6
ISSUE 04-01-19C
SERIES R2CT
很抱歉,暂时无法提供与“R2CT115000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+409.16880
- 200+163.26360
- 500+157.80960
- 1000+155.10960
