SMBJ6.5CA
SMBJ6.5CA
    STARSEA(星海)
    SMB(DO-214AA)
    同SMBJ6.8CA相近,可替换使用,SMBJ6.5CA的印字有两种,一种是SMBJ6.5CA,一种是AK
SMBJ6.5CA 数据手册
SMBJ3.3(C)A - SMBJ440(C)A 600W SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR Features DO-214AA 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.077 (1.95) · · · · · · · 600W Peak Pulse Power Dissipation 5.0V - 170V Standoff Voltages Glass Passivated Die Construction Uni- and Bi-Directional Versions Available Excellent Clamping Capability Fast Response Time Plastic Material - UL Flammability Classification Rating 94V-0 Mechanical Data 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) · · · 0.096(2.44) 0.086(2.18) · 0.060(1.52) 0.008(0.203)MAX. 0.030(0.76) · 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) Maximum Ratings · · Case: SMB, Transfer Molded Epoxy Terminals: Solderable per MIL-STD-202, Method 208 Also Available in Lead Free Plating (Matte Tin Finish). Polarity Indicator: Cathode Band (Note: Bi-directional devices have no polarity indicator.) Marking: Date Code and Marking Code See Page 3 Weight: 0.1 grams (approx.) Ordering Info: See Page 3 @ TA = 25°C unless otherwise specified Characteristic Symbol Value Unit Peak Pulse Power Dissipation (Non repetitive current pulse derated above TA = 25°C) (Note 1) PPK 600 W Peak Forward Surge Current, 8.3ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Notes 1, 2, & 3) IFSM 100 A PM(AV) 5.0 W Tj 3.5 5.0 -55 to +150 V V °C TSTG -55 to +175 °C Steady State Power Dissipation @ TL = 75°C Instantaneous Forward Voltage @ IPP = 35A (Notes 1, 2, & 3) Operating Temperature Range Storage Temperature Range Notes: VBR
SMBJ6.5CA 价格&库存
很抱歉,暂时无法提供与“SMBJ6.5CA”相匹配的价格&库存,您可以联系我们找货
SMBJ6.5CA
  • 10+0.48784
  • 100+0.39075
  • 300+0.34215
  • 3000+0.30575
  • 6000+0.27659
  • 9000+0.26201
