SMDA05-6TR
SMDA05-6TR
    SMCDIODESOLUTIONS(桑德斯)
    SOIC8_150MIL
    SMDA05-6TR
SMDA05-6TR 数据手册
SMDA03-6 THRU SMDA24-6 Technical Data Data Sheet N0295, Rev. A SMDA03-6 THRU SMDA24-6 TVS ARRAY SERIES Description The SMDAXX-6 series of TVS array have been designed to provide unidirectional protection for sensitive electronics from damage due to voltage transients caused by electrostatic discharge (ESD), electrical fast transients (EFT), lightning and other voltage-induced transient events. The device can be used to protect combinations of six unidirectional lines. SO-8 Schematic & Pin Configuration Features          Mechanical Characteristics     Protects 3.3, 5, 12, 15, 24 V Components Unidirectional Provides Electrically Isolated Protection 300 W @ 8/20 us Protects 6 Lines SO-8 Packaging This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Application SO-8 Surface Mount Package Approximate Weight: 0.1 grams PIN #1 Indicator: DOT on top of package Packaging: Tubes or Tape & Reel per EIA Standard 481       RS-232 & RS-422 Data Lines Microprocessor Based Equipment Notebooks, Desktops, & Servers LAN/WAN Equipment Serial and Parallel Port Peripherals Absolute Maximum Ratings: Parameter Symbol Value Units Peak Pulse Power, 8/20 μs Wave shape P 300 W Operating Temperature TJ -55 to +125 C Storage Temperature Tstg -55 to +150 C Lead Soldering Temperature TL 260 (10 Sec.) C  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMDA03-6 THRU SMDA24-6 Technical Data Data Sheet N0295, Rev. A Electrical Characteristics@25°C Stand-off Voltage Vwm (V) Max Breakdown Voltage VBR @1mA (V) Min Clamping Voltage Vc @1A (V) Max Leakage Current IR @ Vwm (uA) Max Capacitance (f = 1MHz) C @ 0V (pF) Max Temperature Coefficient of VBR a(VBR) mv/°C Max SMDA03-6 3.3 4 7 200 800 -3 SMDA05-6 5.0 6 9.8 20 550 3 SMDA12-6 12.0 13.3 19 1 185 10 SMDA15-6 15.0 16.7 24 1 140 13 SMDA24-6 24.0 26.7 43 1 90 30 Part Number Ratings and Characteristics Curves Ordering Information Device Package SMDA03-6 THRU SMDA24-6 SO-8 (Pb-Free) Marking Diagram Shipping 2500pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Where XXXXX is YYWWL SMDA03-6 S YY WW L = Part Number =S = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMDA03-6 THRU SMDA24-6 Technical Data Data Sheet N0295, Rev. A Circuit Diagram The SMDAxx-6 is designed to protect up to 6 data or I/O lines operating at 5 volts. They are unidirectional devices and may be used on lines where the signal polarities are above ground (i.e. 0 to 5V). The devices are connected as follows: ✔ Pins 1, 2, 3, 4, 5 and 8 are connected to the lines that are to be protected. Pins 6 and 7 are connected to ground. The ground connections should be made directly to the ground plane for best results. The path length is kept as short as possible to reduce the effects of parasitic inductance in the board traces. Mechanical Dimensions SO-8 SYMBOL Millimeters Inches MIN. MAX. MIN. MAX. A A1 A2 b 1.350 0.100 1.350 0.330 1.750 0.250 1.550 0.510 0.053 0.004 0.053 0.013 0.069 0.010 0.061 0.020 c 0.170 0.250 0.007 0.010 D e E E1 L θ 4.800 5.000 1.270(BSC) 5.800 6.200 3.800 4.000 0.400 1.270 0° 8° Carrier Tape Specification SO-8  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  0.189 0.197 0.050(BSC) 0.228 0.244 0.150 0.157 0.016 0.031 0° 8° SMDA03-6 THRU SMDA24-6 Technical Data Data Sheet N0295, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SMDA05-6TR 价格&库存
很抱歉,暂时无法提供与“SMDA05-6TR”相匹配的价格&库存,您可以联系我们找货
