9000 series
Subminiature momentary pushbutton switches
Distinctive features and pecifications
❑ Panel and PC mount models, horizontal or vertical
❑ Self-cleaning and butt action contacts
❑ Several plunger options
B
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 100mA 30VDC
• Initial contact resistance : 30 mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength :
500 Vrms 50 Hz min. between terminals
1.000 Vrms 50 Hz min. between terminals and frame
• Electrical life at full load :
9100 - 9200N and 9500N : 250.000 cycles
9200 - 9500 : 100.000 cycles
MATERIALS
• Case : Pa6T
• Actuator : polyamide, glass
filled
• Bushing : brass, nickel plated
• Contacts :
CD : brass, gold plated
• Terminal seal : epoxy
APEM
GENERAL SPECIFICATIONS
• Torque : 0,5 Nm (.590 Ft.lb) max. applied to nut
• Operating temperature : -30°C to +65°C
• Panel thickness : 1,50 mm (.059) max.
• Travels : see table below
Tolerance : +/- 0,3 mm (.011)
9533-9233
9532-9232
9533N
9233N-9133
Total travel
1,10 (.043)
1,80 (.070)
1 (.039)
Pre-travel
0,80 (.031)
1,00 (.039)
Over travel
0,30 (.011)
0,75 (.029)
www.apem.com
B-13
9000 series
Overview
9
Number of poles
SERIES
3
Single pole
Electrical functions
2
3
Normally closed (NC)
Normally open (NO)
Terminals, case and bushing
B
Case height 8 (.314)
2
Straight terminals - threaded bushing
2..Y
Tall bracket - plain bushing
2..WW Right angle terminals - plain bushing
5
Solder lugs - threaded bushing
Case height 6,1 (.240)
1
Straight terminals - threaded bushing - 7,10 (.279) PCB to panel
1..Y
Short bracket - plain bushing
1..WW Right angle terminals - plain bushing
2..N
Straight terminals - threaded bushing - 8,90 (.350) PCB to panel
2..NY
5..N
Contact materials
CD
Gold plated brass
(standard)
Sealing
Plunger
Blank Epoxy sealed
terminals standard
K
Front panel sealing
by two O-rings
Blank Standard
-0
Flush
-4
Long
Caps
For plunger -4
U4310 Height 4 (.157)
U4320 Height 3,9 (.153)
Mounting bezel
U4922
For 9500 model
only.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- their options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Sealing boots are available to protect the switches. They are presented in section H.
Mounting accessories : standard hardware supplied with all threaded bushing models : 1 nickel plated hex nut 5 (.196)
across flats, part number U544. This nut is presented after model structure of switches.
Packaging unit : 100 pieces.
B-14
www.apem.com
APEM
9000 series
Solder lug or straight PC terminals : 9500 - 9200 - 9200Y
• Case height 8 (.314)
• With over travel
• Self-cleaning contacts
• Epoxy sealed terminals standard
NO
(function 3)
4.00
(.157)
0.60
(.023)
2.00
(.078)
0.80
(.031)
NC
(function 2)
5.00
(.196)
1.00
(.039)
3.00
(.118)
1.00
(.039)
MODEL
STRUCTURE
B
Threaded bushing - solder lugs : 9500
3.50
(.137)
Ø2.45
(.096 DIA)
8.00
(.314)
Normally Open
Ø6.50
(.255 DIA)
0.20
(.008)
2.00
(.078)
3.00
(.118)
9533
Normally Closed
3.00
(.118)
9532
Ø4.00 X 0.70 SI
(.157 DIA X 0.70 IS)
2.54
(.100)
EPOXY
Threaded bushing - straight PC terminals : 9200
3.50
(.137)
Ø2.45
(.096 DIA)
8.00
(.314)
Normally Open
Ø6.50
(.255 DIA)
Ø1.10
(.043 DIA)
0.20
(.008)
5.00
(.196)
2.54
(.100)
EPOXY
0.60
(.023)
2.54
(.100)
9233
Normally Closed
3.00
(.118)
9232
Ø4.00 X 0.70 SI
9.30
(.366)
0.60
(.023)
5.08
(.200)
Ø1.10
(.043 DIA)
EPOXY
0.20
(.008)
0.40
(.015)
2.54
(.100)
7.62
(.300)
APEM
www.apem.com
5.08
(.200)
7.62
(.300)
Normally Open
Ø3.00
(.118 DIA)
2.54
(.100)
9233Y
Normally Closed
Ø2.45
(.096 DIA)
4.00
(.157)
9232Y
2.60
(.102)
3.50
(.137)
Straight PC terminals - bracket mounting : 9200Y
B-15
9000 series
Right angle terminals : 9200WW
2.70
(.106)
0.60
(.023)
0.60
(.023)
Ø1.10
(.043 DIA)
0.60
(.023)
10.16
(.400)
5.08
(.200)
2.54
(.100)
2.54
(.100)
5.08
(.200)
10.16
(.400)
Ø3.00
(.118 DIA)
9.50
(.374)
5.08
(.200)
Normally Open
3.00
(.118)
9233WW
Normally Closed
Ø2.45
(.096 DIA)
0.20
(.008)
9232WW
Ø6.5
(.255)
EPOXY
3.25
(.127)
3.50
(.137)
B
PANEL CUT-OUT
STANDARD HARDWARE
9500 - 9200
5.00
(.196)
1.50
(.059)
Ø4.20
(.165 DIA)
M4 X 0.70 SI
For threaded bushing models.
B-16
www.apem.com
U544 (nickel plated)
APEM
9000 series
Solder lug or straight PC terminals : 9500N - 9200N - 9100
• Case height 6,1 (.240)
• Butt action contacts
0.60
(.023)
0.80
(.031)
NO
(function 3)
4.00
(.157)
1.00
(.039)
3.00
(.118)
1.00
(.039)
2.00
(.078)
MODEL
STRUCTURE
B
Threaded bushing - solder lugs : 9500N
Ø4.00 X 0.70 SI
6.10
(.240)
3.50
(.137)
Ø2.45
(.096 DIA)
Ø6.50
(.255 DIA)
0.40
(.015)
2.00
(.078)
EPOXY
3.00
(.118)
Normally Open
3.00
(.118)
9533N
2.54
(.100)
Threaded bushing - straight PC terminals - 8,90 (.350) PCB to panel
3.50
(.137)
Ø4.00 X 0.70 SI
6.10
(.240)
Ø2.45
(.096 DIA)
8.90
(.350)
Normally Open
Ø1.10
(.043 DIA)
0.60
(.023)
2.54
(.100)
EPOXY
0.40
(.015)
4.00
(.157)
9233N
3.00
(.118)
Ø6.50
(.255 DIA)
2.54
(.100)
Threaded bushing - straight PC terminals - 7,10 (.279) PCB to panel
3.25
(.127)
Ø4.00 X 0.70 SI
6.10
(.240)
Ø2.45
(.096 DIA)
2.54
(.100)
www.apem.com
EPOXY
0.60
(.023)
Ø1.10
(.043 DIA)
2.54
(.100)
0.20
(.008)
APEM
7.10
(.279)
Ø6.50
(.255 DIA)
4.00
(.157)
Normally Open
3.00
(.118)
9133
B-17
9000 series
Subminiature momentary puhsbutton switches
Straight PC or right angle terminals : 9200NY - 9100Y - 9100WW
Straight PC terminals - tall bracket : 9200NY
Normally Open
9.30
(.366)
2.60
(.102)
9233NY
Ø3.00
(.118 DIA)
3.50
(.137)
Ø2.45
(.096 DIA)
Ø1.10
(.043 DIA)
5.08
(.200)
0.40
(.015)
2.54
(.100)
0.60
(.023)
7.62
(.300)
7.62
(.300)
0.60
(.023)
2.54
(.100)
0.40
(.015)
4.00
(.157)
EPOXY
5.08
(.200)
B
3.50
(.137)
Ø3.00
(.118 DIA)
2.60
(.102)
Normally Open
EPOXY
0.40
(.015)
Ø1.10
(.043 DIA)
0.60
(.023)
0.20
(.008)
2.54
(.100)
5.08
(.200)
4.00
(.157)
0.60
(.023)
5.08
(.200)
2.54
(.100)
7.62
(.300)
7.62
(.300)
9133Y
Ø2.45
(.096 DIA)
7.70
(.303)
Straight PC terminals - short bracket : 9100Y
Right angle terminals - vertical : 9100WW
Ø6.5
(.255)
EPOXY
0.60
(.023)
7.60
(.299)
0.60
(.023)
10.16
(.400)
Ø3.00
(.118 DIA)
3.25
(.127)
0.40
(.015)
5.08
(.200)
Normally Open
2.70
(.106)
3.00
(.118)
9133WW
Ø2.45
(.096 DIA)
3.50
(.137)
Ø1.10
(.043 DIA)
0.60
(.023)
10.16
(.400)
5.08
(.200)
2.54
(.100)
5.08
(.200)
2.54
(.100)
PANEL CUT-OUT
STANDARD HARDWARE
5.00
(.196)
Ø4.20
(.165 DIA)
1.50
(.059)
M4 X 0.70 SI
B-18
www.apem.com
APEM
9000 series
CONTACT MATERIALS
CD
Gold plated brass (standard)
SEALING
B
Blank
K
Front panel sealing by two O-rings. Protects the switch against
water and dust.
Panel seal withstands 0,1 bar pressure.
1
Option K for models 9533N, 9233N and 9133 only.
➀ O-rings
PLUNGERS
Ø2.45
(.096 DIA)
Ø2.45
(.096 DIA)
4.70
(.185)
3.50
(.137)
Ø2.5
(.098 DIA)
Blank
-4
-0
Standard
Long
Flush
APEM
www.apem.com
B-19
9000 series
CAPS
+ U...
Cap colours
Replace "0" by
number
Ø5.00
(.196 DIA)
1
1/4
2
3
4
5
6
7
7/1
9
U4310
U4320
For use with plunger -4 only
blue
dark blue
black
green
grey
yellow
red
ivory
white
orange
MOUNTING BEZEL
+ U...
ø11.00
(.433)
15.60
(.614)
2.30
(.090)
For 9500 model (case height 8 mm) only
0.90
(.035)
B
3.00
(.118)
4.00
(.157)
3.00
(.118)
3.90
(.153)
Ø6.50
(.255)
The mounting bezel U4922 has been
designed to facilitate the mounting of the
9500 series pushbutton switch onto a panel.
The switch + bezel assembly is snapped into
the equipment through the front of the panel,
then electrically connected by solder lug
terminals.
Panel cut-out : Ø 8,15 mm ± 0,05
(.320 DIA ± .002)
Shown with cap U570.
B-20
www.apem.com
APEM
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
U4922
很抱歉,暂时无法提供与“U4922”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+43.13520
- 200+17.21520
- 500+16.64280
