XNIRP-03V-A-S
XNIRP-03V-A-S
    JST
    P=2.5mm
    1X3P 2.5MM
XNIRP-03V-A-S 数据手册
XNI CONNECTOR 2.5mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– This connector is 2.5mm pitch wire-to-board connector that has a mechanism to prevent an incomplete mating by utilizing the inertial force when mating connector. In all circuits of connector, controlled key for preventing mismatching of mating is added, and two type connectors can be used in the same model. (See table below.) • Current rating: 3A AC, DC (AWG#22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10mΩ max. After environmental testing/20mΩ max. • Insulation resistance: 1,000MΩ min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: AWG #30 to #22 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 • Inertial lock structure • Finger-friendly design • Secure locking structure Recognized E 60389 1 Certified LR20812 2 J50148340 PC board layout (viewed from component side) and Assembly layout List of combinations (7.95) A ±0.05 1.7 ±0.05 Natural Red Polarizing key pattern A Polarizing key pattern B Housing Model No. Header Model No. XNIRP-( )V-A-S B( )B-XNI S K-A-1 XNIRP-( )V-B-R B( )B-XNI R K-B-2 ±0.05 (12.6) 2.6 ±0.05 2.5 Resin color (Header/Housing) Key pattern φ0.9 φ1.3 +0.1 0 +0.1 0 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire AWG# mm2 Model No. SXNI-001T-P0.6 SXNI-003T-P0.6 0.13 ∼ 0.33 26 ∼ 22 1.0 ∼ 1.7 7,000 0.05 ∼ 0.08 30 ∼ 28 0.65∼ 0.9 10,000 8.4 Material and Finish 2 Phosphor bronze, tin-plated (reflow treatment) 1.6 RoHS compliance 1.7 2.9 Q’ty / reel Insulation O.D. (mm) Contact SXNI-001T-P0.6 SXNI-003T-P0.6 Applicator Dies Crimp applicator with dies MKS-L MK/SXNI-001-06 APLMK SXNI001-06 – – – MKS-L MK/SXNI-003-06 APLMK SXNI003-06 – – – Crimping machine Crimp applicator AP-K2N AP-K2N 1 XNI CONNECTOR Housing B A 2.5 (4 to 11 circuits) Dimensions (mm) A B Q’ty / bag XNIRP-02V-A-S 2.5 7.5 1,000 XNIRP-03V-A-S 5.0 10.0 1,000 4 XNIRP-04V-A-S 7.5 12.5 1,000 5 XNIRP-05V-A-S 10.0 15.0 1,000 6 XNIRP-06V-A-S 12.5 17.5 1,000 7 XNIRP-07V-A-S 15.0 20.0 1,000 8 XNIRP-08V-A-S 17.5 22.5 1,000 9 XNIRP-09V-A-S 20.0 25.0 1,000 10 XNIRP-10V-A-S 22.5 27.5 1,000 11 XNIRP-11V-A-S 25.0 30.0 500 15 XNIRP-15V-A-S 35.0 40.0 500 Circuits Model No. 2 3 7.75 10.1 (2, 3 circuits) B A 7.75 10.1 2.5 Material (15 circuits) B A Glass-filled PBT, UL94V-0, natural (white) 7.75 2.5 10.1 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. XNIRP-02V-A-S S...natural (white) R...red Shrouded header (2 to 11 circuits) B A 6.8 3.4 10.6 2.5 1.7 (15 circuits) 2.6 B A 2 B02B-XNISK-A-1 2.5 7.5 500 3 B03B-XNISK-A-1 5.0 10.0 500 4 B04B-XNISK-A-1 7.5 12.5 250 5 B05B-XNISK-A-1 10.0 15.0 250 6 B06B-XNISK-A-1 12.5 17.5 250 7 B07B-XNISK-A-1 15.0 20.0 200 8 B08B-XNISK-A-1 17.5 22.5 200 9 B09B-XNISK-A-1 20.0 25.0 200 10 B10B-XNISK-A-1 22.5 27.5 150 11 B11B-XNISK-A-1 25.0 30.0 150 15 B15B-XNISK-A-1 35.0 40.0 100 Material and Finish 10.6 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) 3.4 RoHS compliance 1.7 2.6 This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02B-XNISK-A-1 S...natural (ivory) 2 Q’ty / box Model No. 6.8 2.5 Dimensions (mm) A B Circuits R...red
XNIRP-03V-A-S 价格&库存
很抱歉,暂时无法提供与“XNIRP-03V-A-S”相匹配的价格&库存,您可以联系我们找货
XNIRP-03V-A-S
  • 1000+1.059611000+0.13749
XNIRP-03V-A-S
    • 1000+0.39600
    库存:11000
    XNIRP-03V-A-S
      • 1000+0.45100
      库存:19000
      XNIRP-03V-A-S
        库存:1000
