AS201901
AS201901
    ZF
    ACTUATOR MAGNET FLANGE MNT
AS201901 数据手册
Magnetic Proximity Sensors (Reed) MP2019 Sensors Reed based magnetic proximity sensor in plastic flange-mount package Description The MP2 Series sensors are reed position sensors. Normally open or closed contacts change states when a magnetic field is applied. The sensors act as non-latching electrical switches. Typical Applications Features        Contacts hermetically sealed for long life Zero power consumption Suitable for DC and AC circuits Flange mount RoHS compliant IP65 Operate/Release Distances*: 10.16 mm – 22.86 mm (0.4” – 0.9”)      Door position & interlock Limit switch Flow/speed Home security Pedal switch Environmental Specifications 20 g 10 Hz to 1 kHz (MP201901), 20 g 10 Hz to 55 Hz (MP201902, M201903) -40 °C to 105 °C (-40 °F to 221 °F) -40 °C to 105 °C (-40 °F to 221 °F) IP65 Vibration Operating Temperature Storage Temperature Ingress Protection Electrical Specifications Typical Operating Time Breakdown Voltage Switching Voltage and Current Contact Resistance and Power rating: 1 ms 200 VDC min. See Products chart See Products chart Mechanical Specifications Housing Material Operate/Release Distances* *with AS201901 magnetic actuator Glass-reinforced plastic 10.16 mm – 22.86 mm (0.4” – 0.9”) Products Part Number MP201901 MP201902 MP201903 Contact Form SPST-NO Form A SPST-NC Form B SPST-NC Form C Maximum Power Rating 10 W Maximum Switching Volta ge 175 VAC/VDC Maximum Switching Current 0.5 A Maximum Contact Resistance 0.200 Ω 3W 30 VAC/VDC 0.2 A 0.100 Ω 3W 30 VAC/VDC 0.2 A 0.100 Ω All MP2019 sensors come with leads 24 AWG x 305 mm (12”) www.cherryswitches.com Page 1 of 2, last update 2014-12-12, Specifications subject to change without notice. Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, last update 2014-12-12, Specifications subject to change without notice.
AS201901 价格&库存
很抱歉,暂时无法提供与“AS201901”相匹配的价格&库存,您可以联系我们找货
