1N4004
1N4004
    HL(豪林)
    DO-41(DO-204AL)
1N4004 数据手册
1N4001 THRU 1N4007 DO-41 FEATURES • • • • • Low coat construction Low forward voltage drop Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 260℃/10 secods/.375”(9.5mm)lead length at 5 lbs(2.3kg) tension 1.0(25.4) MIN. .205(5.2) .166(4.2) .107(2.7) DIA. .080(2.0) MECHANICAL DATA • • • • • • 1.0(25.4) MIN. Case: Transfer molded plastic Epoxy: UL94V-O rate flame retardant Polarity: Color band denotes cathode end Lead: Plated axial lead, solderable per MIL-STD-202E method 208C Mounting position: Any Weight: 0.012 ounce, 0.33 grams .034(0.9) .028(0.7) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS • • • Ratings at 25OC ambient temperature unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load For capacitive load derate current by 20% SYMBOLS VRRM VRMS VDC Maximum Repetitive Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 0.375”(9.5mm) lead length at T A= 25℃ Peak Forward Surge Current 8.3mS single half sine wave superimposed on rated load (JEDEC method) 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007 UNIT 50 100 200 400 600 800 1000 Volts 35 70 140 280 420 560 700 Volts 50 100 200 400 600 800 1000 Volts I(AV) 1.0 Amps IFSM 30 Amps VF 1.1 5.0 50 Volts IR(AV) 30 µA CJ 13 pF Typical Thermal Resistance (Note 2) RθJA 50 ℃/W Operating Junction Temperature Range TJ TSTG -55 to +150 -55 to +150 ℃ Maximum Instantaneous Forward Voltage @ 1.0A Maximum DC Reverse Current at Rated DC Blocking Voltage per element TA = 25℃ TA = 100℃ Maximum Full Load Reverse Current, full cycle average 0.375”(9.5mm)lead length at TL=75℃ Typical Junction Capacitance (Note 1) Storage Temperature Range IR Notes: 1. Measured at 1.0MHz and Applied Reverse Voltage of 4.0V DC. 2. Thermal Resistance from junction to terminal 6.0mm2 copper pads to each terminal. 3. The chip size is 40mil×40mil µA ℃ RATING AND CHRACTERISTIC CURVES 1N4001 Thur 1N4007 FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 0.8 0.6 0.4 Single Phase Half Wave 60Hz 0.2 Resistive or Inductive Load 0 25 0 100 75 50 150 125 25 CURRENT, (A) PEAK FORWARD SURGE 1.0 (A) AVERAGE FORWARD CURRENT, 1.2 10 0 175 8.3ms Single Half Sine-Wave (JEDEC Method) =T T j jmax 20 5 2 1 FIG.3-TYPICAL INSTANTANEOUS INSTANTANEOUS REVERSE CURRENT, (mA) (A) 1 0.1 T =25° C j Pulse Width=300us 1% Duty Cycle 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 INSTANTANEOUS FORWARD VOLTAGE,(V) 1.0 0.1 Tj =25° C 0.01 0 20 40 60 80 PERCENT OF RATED PEAK FIG.5-TYPICAL JUNCTION CAPACITANCE 100 CAPACITANCE,(pF) 100 Tj =100° C REVERSE VOLTAGE,(%) 10 TJ=25° C F=1MHz 10 0.1 50 10 10 INSTANTANEOUS FORWARD CURRENT, 20 10 FIG.4-TYPICAL REVERSE CHARACTERISTICS FORWARD CHARACTERISTICS 0.01 8 NUMBER OF CYCLES AT 60 Hz AMBIENT TEMPERATURE, (° C) 1.0 4.0 REVERSE VOLTAGE,(VOLTS) 10.0 100 100 120 140
1N4004 价格&库存
很抱歉,暂时无法提供与“1N4004”相匹配的价格&库存,您可以联系我们找货
1N4004
    • 50+0.15120
    • 500+0.12496
    • 1500+0.11038
    库存:230
