QMA6981
QMA6981
    QST(矽睿)
    QMA6981
QMA6981 数据手册
Single-Chip 3-Axis Accelerometer QMA6981 Advanced Information The QMA6981 is a single chip three-axis accelerometer. This surface-mount, small sized chip has an integrated acceleration transducer with signal conditioning ASIC, sensing tilt, motion, shock and vibration. It is targeted for applications such as screen rotation, step counting, sleep quality, gaming and personal navigation in mobile and wearable smart devices. The QMA6981 is based on our state-of-the-art, high resolution single crystal silicon MEMS technology. Along with custom-designed 10-bit ADC ASIC, it offers the advantages of low noise, high accuracy, low power consumption, and offset trimming. The I²C serial bus allows for easy interface. The QMA6981 is in a 2mmx2mmx0.95mm surface mount 12-pin land grid array (LGA) package. FEATURES BENEFIT 3  3-Axis Accelerometer in a 2x2x0.95 mm Land Grid Array Package (LGA), guaranteed to operate over a temperature range of -40 °C to +85 °C.  Small size for highly integrated products. Signals have been digitized and factory trimmed.  10-Bit ADC with low noise accelerometer sensor  High resolution allows for motion and tilt sensing 2  I C Interface with Standard and Fast modes.  High-Speed Interfaces for fast data communications.  Built-In Self-Test  Enables low-cost functionality test after assembly in production  Wide range operation voltage (2.4V To 3.6V) and low power consumption (27-50A low power conversion current) maintains sensor’s  Automatically sensitivity under wide operation voltage range and compatible with battery powered applications  Integrated FIFO with a depth of 32 frames  High Data-Read rate  RoHS compliant , halogen-free  Environmental applications  Built–in motion algorithm  Low power and easy applications including step counting, sleep quality, gaming and personal navigation protection and wide 矽睿 QMA6981 Datasheet Rev: C CONTENTS CONTENTS .................................................................................................................................................................................... 2  1  INTERNAL SCHEMATIC DIAGRAM ................................................................................................................................ 3  1.1  Internal Schematic Diagram................................................................................................................................... 3  2  SPECIFICATIONS AND I/O CHARACTERISTICS ........................................................................................................... 4  2.1   Product Specifications ........................................................................................................................................... 4  2.2   Absolute Maximum Ratings .................................................................................................................................. 5  2.3  I/O Characteristics ................................................................................................................................................. 5  3   PACKAGE PIN CONFIGURATIONS .................................................................................................................................. 5  3.1  Package 3-D View ................................................................................................................................................. 5  3.2  Package Outlines .................................................................................................................................................... 6  4   EXTERNAL CONNECTION ................................................................................................................................................ 9  4.1   Dual Supply Connection ........................................................................................................................................ 9  4.2   Single Supply connection....................................................................................................................................... 9  5  BASIC DEVICE OPERATION ........................................................................................................................................... 10  5.1 Acceleration Sensors ................................................................................................................................................ 10  5.2   Power Management ............................................................................................................................................. 10  5.3   Power On/Off Time ............................................................................................................................................. 10  5.4   Communication Bus Interface I2C and Its Addresses .......................................................................................... 11  6   MODES OF OPERATION................................................................................................................................................... 12  6.1   Modes Transition ................................................................................................................................................. 12  6.2  Description of Modes ........................................................................................................................................... 13  7  Functions and interrupts ....................................................................................................................................................... 14  7.1  POL_INT ............................................................................................................................................................. 14  7.2  FOB_INT ............................................................................................................................................................. 14  7.3  STEP/STEP_QUIT INT....................................................................................................................................... 15  7.4  TAP_INT ............................................................................................................................................................. 16  7.5  LOW-G_INT ....................................................................................................................................................... 18  7.6  HIGH-G_INT....................................................................................................................................................... 18  7.7  DRDY_INT ......................................................................................................................................................... 18  7.8  FIFO_INT ............................................................................................................................................................ 19  7.9  Interrupt configuration ......................................................................................................................................... 20  8   I2C COMMUNICATION PROTOCOL ............................................................................................................................... 22  8.1   I2C Timings .......................................................................................................................................................... 22  8.2   I2C R/W Operation ............................................................................................................................................... 22  9   REGISTERS ......................................................................................................................................................................... 23  9.1   Register Map ........................................................................................................................................................ 23  9.2   Register Definition ............................................................................................................................................... 25  The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 2 / 34 QMA6981 Datasheet 矽睿 1 Rev: C INTERNAL SCHEMATIC DIAGRAM 1.1 Internal Schematic Diagram Sinc OS GAIN SDM Transducer CVA INT1 Interrupt LPF INT2 VPM OSC AD0 BG FIFO I2C SDA SCL RESV0 FSM Reg File GND POWER NVM RESV1 POR RESV2 VDD GND VDDIO GNDIO Figure 1. Block Diagram Table 1. Block Function Block Transducer CVA Interrupt FIFO FSM I2C OSC Power Function 3-axis acceleration sensor Charge-to-Voltage amplifier for sensor signals Digital interrupt engine, to generate interrupt signal on data conversion, FIFO, and motion function Embedded 32-level FIFO Finite state machine, to control device in different mode Interface logic data I/O Internal oscillator for internal operation Power block, including LDO The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 3 / 34 QMA6981 Datasheet 矽睿 Rev: C 2 SPECIFICATIONS AND I/O CHARACTERISTICS 2.1 Product Specifications Table 2. Specifications (* Tested and specified at 25°C and 3.0V VDD except stated otherwise.) Parameter Supply voltage VDD I/O voltage VDDIO Standby current Low power current Low power current Low power current Low power current Low power current Full run current Sleep current Deep sleep current BW Data output rate (ODR) Conversion time Startup time Wakeup time Conditions VDD, for internal blocks VDDIO, for IO only VDD and VDDIO on BW=500 Hz, ODR=1 Hz BW=500 Hz, ODR=10 Hz BW=500 Hz, ODR=20 Hz BW=500 Hz, ODR=40 Hz BW=500 Hz, ODR=100 Hz All blocks on, device in run state For analog, AFE is off, BG, Transducer and oscillator are on or in low power mode For digital, only counter and FSM are on For analog, only BG and oscillator are on For digital, only counter and FSM are on Programmable bandwidth Typ 3.3 2 27 29 31 37 50 220 4*BW (ODRH=1) Max 3.6 VDD 300 From the time device enters into active mode to the time device is ready for conversion Unit V V μA μA μA μA μA μA μA 55 μA 26 μA 3.9~500 1/(4*BW) Hz Samples /sec ms 2 ms 1 ms 15.6~2000 in full speed From the time when VDD reaches to 90% of final value to the time when device is ready for conversion Operating temperature -40 85 ℃ ±2 ±4 ±8 256 128 64 LSB/g LSB/g LSB/g FS=±2g, Normal VDD Supplies ±0.02 %/℃ Gain accuracy FS=±2g, Normal VDD Supplies ±5 ±80 % mg FS=±2g, Normal VDD Supplies ±2 mg/℃ 600 ±0.5 μg/sqrtHz %FS Acceleration Full Range Sensitivity Sensitivity Sensitivity Sensitivity Temperature Drift Sensitivity tolerance Zero-g offset Zero-g offset Temperature Drift Noise density Nonlinearity Min 2.4 1.7 FS=±2g FS=±4g FS=±8g FS=±2g, run state FS=±2g, Best fit straight line, The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. g 4 / 34 QMA6981 Datasheet 矽睿 Parameter Cross Axis Sensitivity 2.2 Conditions Rev: C Min Typ Max Unit 1 % Absolute Maximum Ratings Table 3. Absolute Maximum Ratings (Tested at 25°C except stated otherwise.) Parameters VDD VDDIO ESD Shock Immunity Storage temperature Condition Min -0.3 -0.3 HBM Duration < 200μS -50 Max 5.4 5.4 2 10000 150 Units V V kV g ℃ 2.3 I/O Characteristics Table 4. I/O Characteristics Parameter Voltage Input High Level 1 Voltage Input Low Level 1 Voltage Output High Level Voltage Output Low Level Symbol VIH1 Pin SDA, SCL VIL1 SDA, SCL VOH INT1, INT2 VOL INT1, INT2, SDA Condition Output Current ≥-100μA Output Current ≤100μA(INT) Output Current ≤1mA (SDA) Min. 0.7*VD DIO -0.3 TYP. Max. VDDIO+ 0.3 0.3*VD DIO 0.8*VD DIO Unit V V V 0.2*VD DIO V 3 PACKAGE PIN CONFIGURATIONS 3.1 Package 3-D View Arrow indicates direction of g field that generates a positive output reading in normal measurement configuration. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 5 / 34 QMA6981 Datasheet 矽睿 Rev: C Z X QMA6981 1 AD0 VDD IO 4 RES V0 SCL RES V2 QMA6981 Y 11 Top View SDA 12 INT 1 INT 2 5 6 RES V1 10 GND GND IO 7 VDD Figure 2. Package View Table 5. Pin Configurations PIN No. 1 2 3 4 5 6 7 8 9 10 11 12 PIN NAME AD0 SDA VDDIO RESV0 INT1 INT2 VDD GNDIO GND RESV1 RESV2 SCL I/O I IO I O O IO IO I Power Supply VDDIO VDDIO VDDIO VDDIO VDDIO VDDIO VDD GND GND VDDIO VDDIO VDDIO TYPE Function CMOS CMOS Power CMOS CMOS CMOS Power Power Power CMOS CMOS CMOS LSB of I2C address Serial data for I2C Power supply to digital interface Reserved. Float or connect to GND Interrupt 1 Interrupt 2 Power supply to internal block Ground to digital interface Ground to internal block Reserved Reserved Serial clock for I2C 3.2 Package Outlines 3.2.1 Package Type LGA (Land Grid Array) 3.2.2 Package Outline Drawing: 2.0mm (Length)*2.0mm (Width)*0.95mm (Height) The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 6 / 34 QMA6981 Datasheet 矽睿 TOP VIEW Rev: C DETAIL A SIDE VIEW BOTTOM VIEW DETAIL B The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 7 / 34 QMA6981 Datasheet 矽睿 Rev: C Figure 3. Package Outline Drawing 3.2.3 Marking: Figure 4. Marking Format Marking Text Description Comments Line 1 Product Name “6981” stand for QMA6981 Y: the last digital of year CCC: lot code Lot code: 3 alphanumeric digits, variable to generate mass production trace-code P: Part number P: 1 alphanumeric digit, variable to identify part number S: Sub-con ID S: 1 alphanumeric digit, variable identify sub-con Pin 1 identifier -- Line 2 Line3 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 8 / 34 QMA6981 Datasheet 矽睿 4 4.1 Rev: C EXTERNAL CONNECTION Dual Supply Connection Digital Power 1.7~3.6V Power 2.2Kohm SCL SDA SDA VDD IO RES V0 INT 1 RES V2 QMA6981 C3=10nF SCL Top View 2.2Kohm AD0 INT 2 Analog Power 2.4~3.6V RES V1 GND GND IO VDD C1=0.1uF C2=2.2uF Interrupt Figure 5. 4.2 Dual Supply Connection Single Supply connection Figure 6. Single Supply Connection The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 9 / 34 QMA6981 Datasheet 矽睿 Rev: C 5 BASIC DEVICE OPERATION 5.1 Acceleration Sensors The QMA6981 acceleration sensor circuit consists of tri-axial sensors and application specific support circuits to measure the acceleration of device. When a DC power supply is applied to the sensor, the sensor converts any accelerating incident in the sensitive axis directions to charge output. 5.2 Power Management Device has two power supply pins. VDD is the main power supply for all of the internal blocks, including analog and digital. VDDIO is a separate power supply, for digital interface only. The device contains a power-on-reset generator. It generates reset pulse as power on, which can load the register’s default value, for the device to function properly. To make sure the POR block functions well, we should have such constrains on the timing of VDD and VDDIO. The device should turn-on both power pins in order to operate properly. When the device is powered on, all registers are reset by POR, then the device transits to the standby mode and waits for further commends. Table 6 provides references for four power states. Table 6. Power States 5.3 Power State 1 2 VDD 0V 0V VDDIO 0V 1.7v~3.6v 3 4 2.4v~3.6v 2.4v~3.6v 0 1.7v~VDD Power State description Device Off, No Power Consumption Not allowed. User need to make sure that VDDIO is less than VDD. Otherwise, there will be leakage from VDDIO to VDD through internal ESD devices Device Off, Same Current as Standby Mode Device On, Normal Operation Mode, Enters Standby Mode after POR Power On/Off Time After the device is powered on, some time periods are required for the device fully functional. The external power supply requires a time period for voltage to ramp up (PSUP), typically 50 milli-second. However it isn’t controlled by the device. The Power–On–Reset time period (PORT) includes time to reset all the logics, load values in NVM to proper registers, enter the standby mode and get ready for analogy measurements. The power on/off time related to the device is in Table 7 Table 7. Time Required for Power On/Off The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 10 / 34 QMA6981 Datasheet 矽睿 Parameter POR Completion Time Symbol PORT Power off Voltage Power on Interval SDV Power on Time PSUP PINT Condition Time Period After VDD and VDDIO at Operating Voltage to Ready for I2C Commend and Analogy Measurement. Voltage that Device Considers to be Power Down. Time Period Required for Voltage Lower Than SDV to Enable Next POR Time Period Required for Voltage from SDV to 90% of final value Rev: C Min. Typ. Max. 250 Unit μs 0.2 V 100 μs 50 ms Figure 7. Power On/Off Timing 5.4 Communication Bus Interface I2C and Its Addresses This device will be connected to a serial interface bus as a slave device under the control of a master device, such as the processor. Control of this device is carried out via I²C. This device is compliant with I²C -Bus Specification, document number: 9398 393 40011. As an I²C compatible device, this device has a 7-bit serial address and supports I²C protocols. This device supports standard and fast speed modes, 100 kHz and 400 kHz, respectively. External pull-up resistors are required to support all these modes. There are two I2C addresses selected by connecting pin 1 (AD0) to GND or VDDIO. The first six MSB are hardware configured to “001001” and the LSB can be configured by AD0. Table 8. I2C Address Options AD0 (pin 1) Connect to GND Connect to VDDIO I2C Slave Address(HEX) 12 13 I2C Slave Address(BIN) 0010010 0010011 The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 11 / 34 QMA6981 Datasheet 矽睿 Rev: C 6 MODES OF OPERATION 6.1 Modes Transition QMA6981 has two different operational modes, controlled by register (0x11), MODE_BIT. The main purpose of these modes is for power management. The modes can be transited from one to another, as shown below, through I2C commands. The default mode after power-on is standby mode. Power Off Reset (POR or Soft Reset) NVM Load 0x36=0xB6 Standby 0x11=1 0x33=1 Active 0x11=0 0x36=0xB6 Figure 8. Basic operation flow after power-on The default mode after power on is standby mode. Through I2C instruction, device can switch between standby mode and active mode. With SOFTRESET by writing 0xB6 into register 0x36, all of the registers will get default values. SOFTRESET can be done both in active mode and in standby mode. Also, by writing 1 in NVM_LOAD (0x33) when device is in active mode, the NVM related image registers will get default value from NVM, however, other registers will keep the values of their own. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 12 / 34 QMA6981 Datasheet 矽睿 Rev: C Reset (POR or Soft Reset) NVM Load 0x36=0xB6 Standby 0x11=1 0x33=1 Active 0x11=0 0x36=0xB6 Figure 9. The work mode transferring 6.2 Description of Modes 6.2.1 Active Mode In active mode, there are two states, run state, and sleep state. 6.2.1.1 Sleep State In sleep state, whole signal chain is off, including analog and digital signal conditioning, and the rest blocks are on. 6.2.1.2 Run State In run state, the ADC digitizes the charge signals from transducer, and digital signal processor conditions these signals in digital domain, processes the interrupts, and send data to FIFO (accessible through register 0x3F) and Data registers (0x01~0x06). After the signal conditioning, the signal chain will be off and device enters back into sleep state, leaves timer and FSM on. Also in sleep state, reference and power blocks are on. This mode can also be called as power cycling. The power cycling duty is configurable through state registers SLEEP_DUR (0x11). Device can enter into active mode by setting MODE_BIT (0x11) to logic 1. Besides the power cycling, device can also be configured as FULLRUN, by setting SLEEP_DUR=0000b. In this setting, no sleep state in the active mode, and device consumes most power, deliver the data most frequently. 6.2.2 Standby Mode In standby mode, most of the blocks are off, while device is ready for access through I2C. Standby mode is the default mode after power on or soft reset. Device can enter into this mode by set the soft reset register (0x36) to 0xB6 or set the MODE_BIT (0x11) to logic 0. Besides the above two modes, the device also contains NVM loading state. This state is used to reset the value of the NVM related image registers. There are two bits related to this state. When NVM_LOAD (0x33) is set to 1, NVM loading starts. When the device is in NVM loading state, NVM_RDY (0x33) is set to logic 0 by device. After NVM loading is finished, NVM_RDY (0x33) is set back to logic 1 by device, and NVM_LOAD is reset to 0 by device automatically. NVM loading can only happen when NVM_LOAD is set to 1 in active mode. If the user sets this NVM_LOAD bit to 1 in standby mode, the device will not take the action until it enters into active state by setting MODE_BIT (0x11) to logic 1. After loading NVM, the device will enter into standby mode directly. The loading time for NVM is about 100uS. The information contained herein is the exclusive property of QST, and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of QST. 13 / 34 QMA6981 Datasheet 矽睿 Rev: C 7 Functions and interrupts ASIC support interrupts, such as POL_INT, FOB_INT, STEP_INT, TAP_INT, LOW-G, HIGH-G, DRDY_INT, and FIFO_INT. 7.1 POL_INT The POL_INT stands for Portrait or Landscape interrupt. It responds to the device in portrait direction or landscape direction. It includes 4 different event types, left, right, up and down events. The different type event stored and can be read from register ORIENT (0x0D). POLA(0x0D) 000 001 010 101 110 Left 0 1 0 0 0 Right 0 0 1 0 0 Down 0 0 0 1 0 Up 0 0 0 0 1 comments unknown Left/Landscape Right/Landscape Down/portrait Up/portrait   All different events can be detected by comparing the threshold set by register UD_X_TH(0x2D),RL_Y_TH(0x2F) with the sensor data , also have dependency on comparing result between the Z sensor readings and the register UD_Z_TH(0x2C) and RL_Z_TH(0x2E). Hysteresis can be introduced to the angle by decreasing a small offset for the threshold registers. All angle data inside the Hysteresis area will be regarded as unknown status in the orient status register (0x0D). Below Table shows the condition four kinds of orient events generation, the default threshold for X, Y is set to 40 degrees Event Up Down Right Left X |X|>UD_X_TH |X|>UD_X_TH Y X 0 |Y|>RL_Y_TH |Y|>RL_Y_TH Y 0 Z |Z|
QMA6981 价格&库存
很抱歉,暂时无法提供与“QMA6981”相匹配的价格&库存,您可以联系我们找货
