XB3-24Z8PT
XB3-24Z8PT
    DIGIINTERNATIONAL
    XB3-24Z8PT
XB3-24Z8PT 数据手册
DIGI XBEE 3 ZIGBEE 3.0 Easy-to-add connectivity in a compact, low-power, low-profile footprint Digi XBee® 3 modules accelerate time to market for designers, OEMs and solution providers by quickly enabling wireless connectivity and easy-to-add functionality. Building on industry-leading technology, pre-certified Digi XBee 3 modules offer the flexibility to switch between multiple frequencies and wireless protocols as needed. Digi XBee 3 Zigbee 3.0 offers a fully interoperable ecosystem covering all vertical markets including building automation, smart energy, digital health, intelligent lighting, and others. With Digi Remote Manager®, Digi XBee 3 modules can be easily configured and controlled from a simple, central platform. Built-in Digi TrustFence® security, identity and SIZE AND FLEXIBILITY – At 13 mm x 19 mm, the new Digi XBee® 3 micro form factor allows for more compact and portable applications data privacy features use more than 175 controls to protect against new and evolving cyber threats. MicroPython and Digi XCTU® software tools simplify adding functionality, configuration and testing. From edge computing to future migration, Digi XBee modules offer size, weight, power and performance advantages ideal for scalable device connectivity. A versatile addition to the expanding Digi XBee Ecosystem of wireless modules, adapters and software, the Digi XBee 3 Series is engineered to accelerate development and deployment. APPLICATION EXAMPLE – Digi XBee 3 is one module for all protocols including: Zigbee, 802.15.4, DigiMesh® and BLE, all configurable via Digi XCTU® DIGI REMOTE MANAGER® Application PROGRAMMABILITY – Eliminate the need for an external microcontroller and create smart end nodes using MicroPython – Bluetooth® Low Energy for beaconing, connecting to Bluetooth sensors and local configuration using the Digi XBee Mobile app ZIGBEE MESH NETWORK DIGI XBEE® GATEWAY SECURITY – Intrinsic IoT security with Digi TrustFence®, a layered approach securing the edge device, through the gateway, into and out of the IoT MicroPython Rules Engine Bluetooth® low energy Temp Sensor Digi XBee 3 Zigbee 3.0 RELATED PRODUCTS AND SERVICES TRUSTFENCE Development Kits Digi XCTU® Digi TrustFence® Temp Sensor Digi Remote Manager® Digi Design Services Digi XBee 3 Zigbee 3.0 Temp Sensor Digi XBee 3 Zigbee 3.0 SPECIFICATIONS SPECIFICATIONS Digi XBee® 3 Zigbee 3.0 Digi XBee® 3 PRO Zigbee 3.0 PERFORMANCE TRANSCEIVER CHIPSET Silicon Labs EFR32MG SoC DATA RATE RF 250 Kbps, serial up to 1 Mbps INDOOR/URBAN RANGE* Up to 60 m (200 ft) Up to 90 m (300 ft) OUTDOOR/RF LINE-OF-SIGHT RANGE* Up to 1200 m (4000 ft) Up to 3200 m (2 miles) TRANSMIT POWER +8 dBm +19 dBm RECEIVER SENSITIVITY (1% PER) -103 dBm Normal Mode FEATURES SERIAL DATA INTERFACE UART, SPI, I2C CONFIGURATION METHOD API or AT commands, local or over-the-air (OTA) FREQUENCY BAND ISM 2.4 GHz FORM FACTOR Micro, through-hole, surface mount INTERFERENCE IMMUNITY DSSS (Direct Sequence Spread Spectrum) ADC INPUTS (4) 10-bit ADC inputs DIGITAL I/O 15 ANTENNA OPTIONS Through-hole: PCB Antenna, U.FL Connector, RPSMA Connector SMT: RF Pad, PCB Antenna, or U.FL Connector Micro: U.FL Antenna, RF Pad, Chip Antenna OPERATING TEMPERATURE -40º C to 85º C (-40º F to 185º F) DIMENSIONS (L X W X H) Through-hole: 2.438 x 2.761 cm (0.960 x 1.087 in) SMT: 2.199 x 3.4 x 0.305 cm (0.866 x 1.33 x 0.120 in) Micro: 13 x 19 x 2 mm (0.533 x 0.76 x 0.087 in) PROGRAMMABILITY MEMORY 1 MB / 128 KB RAM (32KB are available for MicroPython) NETWORKING AND SECURITY PROTOCOL Zigbee® 3.0 ENCRYPTION 128/256 bit AES RELIABLE PACKET DELIVERY Retries/acknowledgements IDS PAN ID and addresses, cluster IDs and endpoints (optional) CHANNELS 16 channels POWER REQUIREMENTS SUPPLY VOLTAGE 2.1 to 3.6 V TRANSMIT CURRENT 40 mA @ 8 dBm RECEIVE CURRENT 17 mA POWER-DOWN CURRENT 2 micro Amp @ 25º C (77º F) 135 mA @ 19 dBm REGULATORY APPROVALS FCC, IC (NORTH AMERICA) Yes Yes ETSI (EUROPE) Yes No RCM (AUSTRALIA) Yes Yes ANATEL (BRAZIL) Yes Yes TELECK MIC (JAPAN) Yes No KCC (SOUTH KOREA) Yes No *Range figure estimates are based on free-air terrain with limited sources of interference. Actual range will vary based on transmitting power, orientation of transmitter and receiver, height of transmitting antenna, height of receiving antenna, weather conditions, interference sources in the area, and terrain between receiver and transmitter, including indoor and outdoor structures such as walls, trees, buildings, hills, and mountains. DIGI.COM PART NUMBERS DESCRIPTION XB3-24Z8RM-J Digi XBee 3 Zigbee 3.0, 2.4 GHz, Micro, RF Pad Ant, MMT XB3-24Z8UM-J Digi XBee 3 ZigBee 3.0, 2.4 GHz, Micro, U.FL Ant, MMT XB3-24Z8CM-J Digi XBee 3 ZigBee 3.0, 2.4 GHz, Micro, Chip Ant, MMT XB3-24Z8RM Digi XBee 3 PRO ZigBee 3.0, 2.4 GHz, Micro, RF Pad Ant, MMT XB3-24Z8UM Digi XBee 3 PRO ZigBee 3.0, 2.4 GHz, Micro, U.FL Ant, MMT XB3-24Z8CM Digi XBee 3 PRO ZigBee 3.0, 2.4 GHz, Micro, Chip Ant, MMT XB3-24Z8ST-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, SMA Ant, TH MT XB3-24Z8UT-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, U.FL Ant, TH MT XB3-24Z8PT-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, PCB Ant, TH MT XB3-24Z8ST Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, SMA Ant, TH MT XB3-24Z8UT Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, U.FL Ant, TH MT XB3-24Z8PT Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, PCB Ant, TH MT XB3-24Z8RS-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, RF Pad Ant, SMT XB3-24Z8US-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, U.FL Ant, SMT XB3-24Z8PS-J Digi XBee 3, 2.4 Ghz Zigbee 3.0, PCB Ant, SMT XB3-24Z8RS Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, RF Pad Ant, SMT XB3-24Z8US Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, U.FL Ant, SMT XB3-24Z8PS Digi XBee 3 PRO, 2.4 Ghz Zigbee 3.0, PCB Ant, SMT A24-HABUF-P5I Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, U.FL female, articulating A24-HASM-450 Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, RPSMA male, articulating A24-HASM-525 Antenna - 2.4 GHz, half wave dipole, 2.1 dBi, RPSMA male, articulating DC-ANT-24DT Antenna - Wi-Fi, table-top mount, 2450 Mhz, 0.5 m cable                       ACTUAL SIZE                             DIGI XBEE 3 MICRO        PRODUCT DIMENSIONS FOR MORE INFORMATION PLEASE VISIT DIGI.COM   DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004131 A16/1120   DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY  +49-89-540-428-0 DIGI INTERNATIONAL CHINA  +86-21-50492199 / www.digi.com.cn    DIGI INTERNATIONAL JAPAN  +81-3-5428-0261 / www.digi-intl.co.jp
XB3-24Z8PT 价格&库存
很抱歉,暂时无法提供与“XB3-24Z8PT”相匹配的价格&库存,您可以联系我们找货
