PPNM010
PPNM010
    PRISEMI(上海芯导电子)
    PTC自恢复保险丝 100mA
PPNM010 数据手册
PPNM SERIES Surface Mount -Positive temperature coefficient fuse Description The PPNM series are designed specifically to provide over current protection for sensitive electronic equipment, the over current events are usually caused by voltage transients induced by lightning and other transient overvoltage. Feature SMD1206  For surface mounted application to optimize board space  Low profile package  Lead free device size 0.12*0.06 inch/3.2*1.6 mm  High temperature soldering guaranteed:260℃/40 seconds at terminals Applications PPNM series are ideal for the over current protection of I/O interfaces, VCC bus and other vulnerable circuits used in telecom, computer industrial and consumer electronic application, When the current reaches its trip current, its internal impedance will increase rapidly, so as to reduce the over current. Environmental Specifications Test Conditions Resistance change Passive aging +85℃, 1000hrs. ±5% typical Humidity aging +85℃, 85% R.H., 168 hours ±5% typical Thermal shock +85℃ to -40℃, 20 times ±33% typical Resistance to solvent MIL-STD-202, Method 215 No change Vibration MIL-STD-202, Method 201 No change Ambient operating condition : -40℃ to +85℃ Maximum surface temperature of the device in the tripped state is 125℃ Rev.06 1 www.prisemi.com PPNM SERIES Surface Mount -Positive temperature coefficient fuse Performance Specification Ihold @25℃ Itrip @25℃ Vmax Imax (A) (A) (Vdc) (A) Current (A) Time (Sec) (W) Rimin R1max PPNM005 0.05 0.15 60 10 0.25 1.50 0.40 2.500 40.00 PPNM010 0.10 0.25 30 10 0.50 1.20 0.40 1.400 15.00 PPNM012 0.12 0.29 30 10 1.00 0.20 0.40 1.350 8.500 PPNM020 0.20 0.46 24 10 1.00 0.60 0.60 0.600 2.600 PPNM025 0.25 0.55 16 10 1.25 0.60 0.60 0.400 2.400 PPNM035/6 0.35 0.75 6 40 8.00 0.10 0.60 0.300 1.200 PPNM035/24 0.35 0.75 24 40 8.00 0.10 0.60 0.300 1.200 PPNM050 0.50 1.00 13.2 40 8.00 0.10 0.40 0.150 0.750 PPNM050/16 0.50 1.00 16 40 8.00 0.10 0.40 0.150 0.750 PPNM075 0.75 1.50 6 100 8.00 0.10 0.40 0.100 0.400 PPNM100 1.00 2.00 6 100 8.00 0.10 0.60 0.060 0.280 PPNM110 1.10 2.20 6 100 8.00 0.10 0.60 0.060 0.280 PPNM150 1.50 3.00 6 100 8.00 0.30 0.60 0.030 0.170 PPNM175 1.75 3.50 6 100 8.00 1.00 0.70 0.020 0.120 PPNM200 2.00 4.00 6 100 8.00 1.00 0.70 0.020 0.120 Model Maximum Time to Trip Pd typ. Resistance (Ω) Ihold = Hold Current. Maximum current device will not trip in 25℃ still air. Itrip = Trip Current. Minimum current at which the device will always trip in 25℃ still air. IMAX = Maximum fault current device can withstand without damage at rated voltage (Vmax). VMAX = Maximum operating voltage device can withstand without damage at rated current (Imax). Pd = Power dissipation when device is in the tripped state in 25℃ still air environment at rated voltage. Rimin/max = Minimum/Maximum device resistance prior to tripping at 25℃. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Rev.06 2 www.prisemi.com PPNM SERIES Surface Mount -Positive temperature coefficient fuse Ihold Versus Temperature Hold current (Ihold/A) versus maximum ambient operating temperature (Tmao/℃) Model -40 -20 0 25 40 50 60 70 85 PPNM005 0.08 0.07 0.06 0.05 0.05 0.04 0.04 0.03 0.02 PPNM010 0.16 0.14 0.13 0.10 0.09 0.08 0.08 0.07 0.06 PPNM012 0.19 0.17 0.15 0.12 0.11 0.10 0.09 0.08 0.07 PPNM020 0.30 0.27 0.24 0.20 0.18 0.16 0.14 0.12 0.11 PPNM025 0.38 0.34 0.30 0.25 0.23 0.20 0.18 0.15 0.14 PPNM035/6/24 0.51 0.46 0.40 0.35 0.30 0.27 0.24 0.22 0.18 PPNM050 0.76 0.68 0.59 0.50 0.44 0.40 0.35 0.32 0.26 PPNM075 1.11 1.00 0.85 0.75 0.67 0.61 0.52 0.50 0.42 PPNM100 1.60 1.40 1.30 1.00 0.90 0.80 0.75 0.70 0.60 PPNM110 1.64 1.46 1.30 1.10 0.92 0.83 0.80 0.65 0.52 PPNM150 2.20 1.99 1.77 1.50 1.34 1.23 1.10 1.01 0.84 PPNM175 2.57 2.32 2.07 1.75 1.56 1.44 1.28 1.18 0.98 PPNM200 2.88 2.61 2.28 2.00 1.80 1.66 1.51 1.39 1.19 Construction And Dimension (Unit: mm) A 2.0±0.1 T02 D B E 1.9±0.1 C 1.0±0.1 1.0±0.1 Recommended Pad Layout (mm) T:PPTC 02:Holding Current 0.2A Rev.06 3 www.prisemi.com PPNM SERIES Surface Mount -Positive temperature coefficient fuse Model Marking PPNM005 A B C D Min Max Min Max Min Max Min T0 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM010 T1 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM012 T01 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM020 T02 3.00 3.40 1.40 1.80 0.60 1.00 0.25 PPNM025 T03 3.00 3.40 1.40 1.80 0.60 1.00 0.25 PPNM035/6/24 T04 3.00 3.40 1.40 1.80 0.60 1.00 0.25 PPNM050 T05 3.00 3.40 1.40 1.80 0.60 1.00 0.25 PPNM075 T07 3.00 3.40 1.40 1.80 0.45 0.85 0.25 PPNM100 T10 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM110 T10 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM150 T15 3.00 3.40 1.40 1.80 0.80 1.20 0.25 PPNM175 T20 3.00 3.50 1.40 1.80 0.80 1.20 0.25 PPNM200 T20 3.00 3.50 1.40 1.80 0.80 1.20 0.25 Termination Pad Characteristics Terminal pad material: Gold-plated Nickel-Copper or Tin- plated Nickel-Copper Terminal pad solderability: Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Rework Use standard industry practices, the removal device must be replaced with a fresh one Model Q’ty/Reel PPNM005 ~ PPNM012;PPNM100~PPNM200 3500 pcs PPNM020 ~ PPNM075 4000 pcs Note: Reel packaging per EIA-481-1 standard Rev.06 4 www.prisemi.com PPNM SERIES Surface Mount -Positive temperature coefficient fuse IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06 5 www.prisemi.com
PPNM010 价格&库存
很抱歉,暂时无法提供与“PPNM010”相匹配的价格&库存,您可以联系我们找货
