ZMR-03
ZMR-03
    JST
    P=1.5mm
    1X3P 1.5MM
ZMR-03 数据手册
ZM CONNECTOR 1.5mm pitch/Crimp style Wire-to-wire connectors Matable with ZH and ZR receptacles Specifications ––––––––––––––––––– 1 T 3 2 JS • Current rating: 0.7A AC, DC max. (AWG #28) • Voltage rating: 50V AC, DC max. (See Note below.) • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20m Ω max. After environmental testing/ 30m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #30 to #28 Note: Contacts are exposed at the housing lances. Care should be taken so that these parts do not touch the metal section of the chasis. 3 ZM connector ST Crimp style ZH connector T JS Insulation displacement ZR connector 1.5mm pitch connectors allow higher densities. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. • Compact design • Housing-to-terminal locks • Both crimp style and insulation displacement receptacles can be used • Fully shrouded header resists "rocking" during mating Standards––––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 ZM/ZH connector ZM/ZR connector (9.2) 3.6 3.6 (9.1) Plug / ZM connector 3.6 B Housing 8.1 4.1 1.05 Contact 7 2.8 2.2 1 2 1 1.5 A Applicable wire Model No. mm SMM-003T-P0.5 Insulation O.D. (mm) AWG # 2 0.05∼0.08 30∼28 0.7∼0.9 Q´ty / reel 16,000 Material and Finish 2.85 1.5 Dimensions (mm) A B Q´ty / bag ZMR-02 1.5 5.5 2,000 ZMR-03 3.0 7.0 2,000 9 ZMR-09 12.0 16.0 1,000 13 ZMR-13 18.0 22.0 1,000 Circuits Model No. 2 3 Phosphor bronze, tin-plated (reflow treatment) Material RoHS compliance Glass-filled PA 66, UL94V-0 Contact Crimping machine Crimp applicator SMM-003T-P0.5 AP-K2N Note: *Strip-crimp applicator 1 Applicator Dies RoHS compliance Crimp applicator with dies MKS-L MK/SMM-003-05 APLMK SMM003-05 *MKS-SC SC/SMM-003-05 APLSC SMM003-05 0.3 φ0.5 3 ZM CONNECTOR Receptacle / ZH connector (Crimp style) Contact Housing B 1.5 3.4 A 0.3 1.5 4 2.2 1.4 1.1 2 1 0.3 0.3 1.5 4.2 3 1 0.5 Dimensions (mm) mm2 AWG # Insulation (mm) Q´ty / reel 0.032∼0.08 32∼28 0.5∼0.9 16,000 Model No. SZH-003T-P0.5 Material and Finish B Q´ty / bag ZHR-2 1.5 4.5 1,000 ZHR-3 3.0 6.0 1,000 ZHR-9 12.0 15.0 1,000 ZHR-13 18.0 21.0 1,000 Model No. 2 3 9 13 Dimensions (mm) A Circuits Phosphor bronze, tin-plated (reflow treatment) Material RoHS compliance PA 66, UL94V-0 Crimping machine Crimp applicator Contact SZH-003T-P0.5 AP-K2N Applicator RoHS compliance Dies Crimp applicator with dies MKS-L MK/SZH-003-05 APLMK SZH003-05 *MKS-SC SC/SZH-003-05 APLSC SZH003-05 Note: *Strip-crimp applicator Receptacle / ZR connector (IDC) Receptacle Circuits A 1.5 4.4 2.7 3.1 1.5 Model No. Dimensions (mm) A B Q´ty / bag 02ZR-8M-P 1.5 4.5 2,000 03ZR-8M-P 3.0 6.0 2,000 09ZR-3H-P 09ZR-8M-P 12.0 15.0 2,000 13ZR-3H-P 13ZR-8M-P 18.0 21.0 2,000 AWG #30 AWG #28 2 02ZR-3H-P 3 03ZR-3H-P 9 13 Material JST B 4.1 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: Glass-filled PA 66, UL94V-0 RoHS compliance 2
ZMR-03 价格&库存
很抱歉,暂时无法提供与“ZMR-03”相匹配的价格&库存,您可以联系我们找货
