RPJ-20R
RPJ-20R
    JST
    P=1.35mm(交错脚)
    2.7MM
RPJ-20R 数据手册
2.7mmピッチ RPJ CONNECTOR 2.7mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 2 A AC, DC (AWG #24) • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #28 to #24 JS JST T The pin and socket are adopted for use as the small rack panel connector. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 J50185783 • Compact design • Floating mechanism • Contact lance Panel layout and Assembly layout Plug Receptacle (21.1) 11 12.5 (15.8) 3-R0.5 2-φ3.2 ±0.1 C2 11.5 ±0.1 14.9 ±0.1 C2 2-φ3.2 ±0.1 24.6 29.4 ±0.1 ±0.1 42.4 ±0.05 37.1 ±0.05 2-φ3.2 ±0.1 2-M3 C2 11.5 ±0.1 10.7 ±0.1 C2 29.4 ±0.1 42.4 ±0.05 1 29.7 ±0.1 42.4 ±0.05 RPJ CONNECTOR Contact Applicable wire Model No. 1.42 Pin contact 13.7 Pin contact Socket contact mm2 RPJ-SP2331 RPJ-SS2331 0.08∼0.22 2.85 AWG # Insulation O.D. (mm) Q'ty/ reel 28∼24 0.9∼1.5 10,000 0.81 Material and Finish Phosphor bronze, nickel-undercoated, gold-plated RoHS compliance 1.36 Socket contact 11.65 2.85 Contact 1.4 RPJ-SP2331 RPJ-SS2331 Plug housing (for socket contact) Applicator Crimping machine Crimp applicator AP-K2N Dies Crimp applicator with dies MKS-L MK/RPJ-SP/SS2 APLMK RPJ-SP/SS2 − − − Receptacle housing (for pin contact) 14 12.5 47.1 11.5 12.5 43 2.7 2.7 13.5 13.5 16.2 16.2 11 1 50.4 11 11 51.4 2.7 2.7 18.9 18.9 21.6 21.6 Circuits Model No. Q'ty/box 50 20 RPJ-20R 50 50 26 RPJ-26RS 50 Material Receptacle housing: Glass-filled PBT, UL94V-0 RoHS compliance Note: Two screws are supplied under the same package of RPJ-26RS. RoHS compliance Screw φ8 φ4.05 M3XP0.5 Note: Two screws are supplied for one receptacle housing, RPJ-26RS. 4 2.5 6 2
RPJ-20R
物料型号: - RPJ-SP2331(针接触) - RPJ-SS2331(套接触) - RPJ-20PRW(20路插头) - RPJ-26P(26路插头) - RPJ-20R(20路插座) - RPJ-26RS(26路插座)
器件简介: - 2.7mm间距的可断开压接式线对线连接器 - 针和插座适用于小型机架面板连接器 - 设计紧凑,具有浮动机制和接触销
引脚分配: - 插头(15.8)和插座(21.1)的布局信息,包括不同电路数的尺寸和公差 - 例如,20路插头的尺寸为14.9±0.1mm,26路插头的尺寸为29.4±0.1mm
参数特性: - 电流额定值:2A AC, DC(AWG #24) - 电压额定值:250V AC, DC - 温度范围:-25˚C至+85˚C(包括施加电流时的温度升高) - 接触电阻:初始值/最大20 mΩ,环境测试后/最大30 mΩ - 绝缘电阻:最小1,000 MΩ - 耐电压:1,000 VAC/分钟 - 适用线材:AWG #28至#24
功能详解: - 接触材料为磷青铜,底层镀镍,表面镀金,符合RoHS - 压接工具和模具信息提供,如RPJ-SP2331的压接工具为AP-K2N,模具为MKS-L
应用信息: - 适用于需要高接触可靠性和机械耐久性的应用 - 符合RoHS指令,环境友好
封装信息: - 插座外壳材料:玻璃填充PBT,UL94V-0 - 包装信息,如RPJ-20PRW每盒50个,RPJ-26P每盒50个 - 注意事项:RPJ-26RS包装内附带两个螺丝
RPJ-20R 价格&库存
很抱歉,暂时无法提供与“RPJ-20R”相匹配的价格&库存,您可以联系我们找货
RPJ-20R
    • 50+3.08760
    库存:1150
    RPJ-20R
      库存:1210
      RPJ-20R
      • 1+4.60080
      • 10+3.73680
      • 30+3.30480
      • 100+2.85120
      • 500+2.59200
      • 1000+2.46240
      库存:1121
