221-413
221-413
    WAGO(万可电子)
    CONN_18.7X18.6MM
    带有操作杆的导线连接器; 适于多种导线类型; max. 4 mm2; 3线; 带有操作手柄; 透明外壳; 工作环境温度:最大85℃(T85); 4,00 mm2; 透明
221-413 数据手册
Printview: COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C - Item No.: 221-413 . COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C Item No.: 221-413 . COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C . Marking . Business data Supplier WAGO Item no. 221-413 GTIN / EAN 4050821808442 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 3 Total number of potentials 1 Color transparent Ratings per EN 60664 Rated voltage (II / 2) [V] 450 [V] Rated impulse voltage (II / 2) [kV] 4 [kV] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C - Item No.: 221-413 Technical data Rated current [A] 32 [A] Connection technology CAGE CLAMP® Number of connection points connector 3 Actuation type Operating lever Connectable conductor materials Copper Nominal cross section 4 mm² Solid conductor 0.2 … 4 mm² / 24 … 12 AWG Stranded conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor 0.14 … 4 mm² / 24 … 12 AWG Strip length 11 mm / 0.43 Inch Type of wiring Side-entry wiring Flammability class per UL94 V2 Weight [g] 2.527 [g] Width 18.7 mm / 0.736 Inch Height 8.3 mm / 0.327 Inch Depth 18.6 mm / 0.732 Inch Safety information 1 In grounded power lines WAGO Kontakttechnik GmbH & Co. KG 2 Printview: COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C - Item No.: 221-413 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C - Item No.: 221-413 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: COMPACT Splicing Connectors; 3-conductor connector; with operating levers; Max.ambient operating temp. 85 °C - Item No.: 221-413 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
221-413 价格&库存
很抱歉,暂时无法提供与“221-413”相匹配的价格&库存,您可以联系我们找货
