SIM800L
SIM800L
    SIMCOM(芯讯通)
    SMD,15.8x17.8mm
    SIM800L 是一款采用 LGA 封装的完整四频段 GSM/GPRS 解决方案,可嵌入客户应用中。SIM800L 支持 850/900/1800/1900MHz 四频段,能以低功耗传输语音、短信和数...
SIM800L 数据手册
Version:1005 GSM/GPRS Module SIM800L SIM800L is a complete Quad-band GSM/GPRS solution in a LGA type which can be embedded in the customer applications. SIM800L support Quad-band 850/900/1800/1900MHz, it can transmit Voice, SMS and data information with low power consumption. With tiny size of 15.8*17.8*2.4 mm, it can fit into slim and compact demands of customer design. Smart Machine Smart Decision General features Specifications for voice •Quad-band 850/900/1800/1900MHz •GPRS multi-slot class 12/10 •GPRS mobile station class B •Compliant to GSM phase 2/2+ – Class 4 (2 W @ 850/900 MHz) – Class 1 (1 W @ 1800/1900MHz) •FM: 76~109MHz worldwide bands with 50KHz tuning step •Dimensions: 15.8*17.8*2.4 mm •Weight: 1.35g •Control via AT commands (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands) •Supply voltage range 3.4 ~ 4.4V •Low power consumption •Operation temperature:-40℃ ~85℃ •Tricodec – Half rate (HR) – Full rate (FR) – Enhanced Full rate (EFR) •AMR – Half rate (HR) – Full rate (FR) •Hands-free operation (Echo suppression) Specifications for GPRS Data •GPRS class 12: max. 85.6 kbps (downlink/uplink) •PBCCH support •Coding schemes CS 1, 2, 3, 4 •PPP-stack •CSD up to 14.4 kbps •USSD •Non transparent mode Specifications for SMS via GSM/GPRS •Point to point MO and MT •SMS cell broadcast •Text and PDU mode Software features •0710 MUX protocol •Embedded TCP/UDP protocol •FTP/HTTP •MMS •E-MAIL •DTMF •Jamming Detection Interfaces 88 LGA pads including: •Analog audio interface •PCM interface •RTC backup •Serial interface •USB interface •Interface to external SIM 3V/1.8V •Keypad interface •GPIO •ADC •GSM Antenna pad •FM Antenna pad Compatibility •AT cellular command interface Certifications(Plan): •CE •GCF •FCC •ROHS •REACH More about SIMCom SIM800L Please contact: Tel: 86-21-32523300 Fax: 86-21-32523301 Email: simcom@sim.com Website: www.sim.com/wm All specifications are subject to change without prior notice.
SIM800L 价格&库存
很抱歉,暂时无法提供与“SIM800L”相匹配的价格&库存,您可以联系我们找货
