DTC114EE
DTC114EE
    GREENPOWER(格瑞宝)
    SOT523
    DTC114EE
DTC114EE 数据手册
DTC114EE Digital Transistor DTC114EE Digital Transistor(NPN) SOT-523 Feature  Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors  The bias resistors consist of thin-film resistors with complete isolation to allow positive biasing of the input .They also have the advantage of almost completely eliminating parasitic effects  Only the on/off conditions need to be set for operation, making device design easy 1.IN 2.GND 3.OUT Schematic diagram http://www.sh-greenpower.com Shanghai GreenPower Electronic Co.Ltd. 1 DTC114EE ABSOLUTE MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol Value Unit Supply Voltage VCC 50 V Input Voltage VIN -10~+40 V Output Current IO 100 mA Power Dissipation PD 150 mW Junction Temperature TJ 125 ℃ TSTG -45 ~ +125 ℃ Storage Temperature Range ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise noted) Parameter Symbol Test Condition Min Type Max VI(off) VCC=5V , IO=100µA VI(on) VO=0.3V , IO=10mA 3 V VO(on) IO=10mA ,II=0.5mA 0.3 V VI =5V 0.88 mA IO(off) VCC=50V , VI=0V 0.5 µA DC current gain GI VO=5V ,IO =5mA Input resistance R1 7 10 13 kΩ Resistance ratio R2/ R1 0.8 1 1.2 Input voltage Output voltage Input current Output current Transition frequency http://www.sh-greenpower.com II fT VO=10V,IO=5mA,f=1MHz Shanghai GreenPower Electronic Co.Ltd. 0.5 Unit V 30 250 MHz 2 DTC114EE Typical Characteristics http://www.sh-greenpower.com Shanghai GreenPower Electronic Co.Ltd. 3 DTC114EE SOT-523 Package Information http://www.sh-greenpower.com 2018/3/28 Shanghai GreenPower Electronic Co.Ltd. 4
DTC114EE 价格&库存
很抱歉,暂时无法提供与“DTC114EE”相匹配的价格&库存,您可以联系我们找货
