79214578
    CROUZET(高诺斯)
    KEY-STRAIGHT FOR METAL BODIES
79214578 数据手册
Limit Switches – Technical Guide Introduction Rules and regulations What is meant by a "position detector" is any device which needs to be operated by a member which exerts a physical force, in view of : - either the form which its operating device takes - or the considerable force needed to operate it EC Directives Our detectors conform to the EC Low Voltage Technical Directive 73/23/EEC and can be used in accordance with the specifications of the Machinery Directive 89/392/EEC. The distinguishing features of position detectors are : - their high electrical performance capability - their excellent resistance to accidental impact - good protection against splashed or dripping water - a wide range of operating devices to allow the detectors to be adapted to a vast variety of mechanisms Environmental conditions Temperature limits When they are used in the temperature range quoted, the mechanical and electrical characteristics of our position detectors will remain substantially unchanged. If you intend to use them outside this range, please consult us. Protective treatment Construction Our detectors are designed to conform to international IEC recommendations and/or European standards (EN). Proof that a detector conforms to these standards or recommendations takes the form of a conformity declaration made by the manufacturer (drafted as indicated in guidance document ISO/IEC 22 - EN 450-14). Characteristics in line with the general requirements of standards NFC 63140, IEC 947.5.1 and EN 60947.5.1. - Leakage paths and air gaps : IEC 664.1 - NFC 20-040. Our position detectors which comply with IEC 947.5.1 can be fitted to machine-tools and industrial machines complying with NFC 79130, IEC 204.1, EN60204 or VDE 113. The treatment given to our position detectors is suitable in the vast majority of applications. Parts made of steel are zinc-coated or painted according to their mechanical function. Further information is available on request. This treatment allows our detectors to be used under the following temperature and humidity conditions : T °C 20 40 50 Relative humidity % 95 80 50 This treatment may thus be suitable for applications in tropical or equatorial climates where the equipment concerned is in an interior location sheltered from direct exposure to atmospheric conditions. Other types of reinforced protection are possible for resistance to very severe environments. Please enquire. Electrical characteristics Mounting requirements Assigned working current (Ie): - the current level adopted as a basis for the operating conditions quoted for a detector, and for the life tests on it. Thermal rating (Ith): - the current the microswitch will withstand when not being operated electrically, for a temperature rise of not more than 60 °C. Assigned insulation voltage (Ui): - the voltage adopted as a reference for the dielectric tests and leakage paths. It must be equal to or greater than the assigned working voltage. Categories of use (IEC 947.5.1): - AC 15 for operating AC solenoids and electromagnets - DC 13 for operating DC solenoids and electromagnets Contact element designation (IEC 947.5.1): - a letter and number which define the use category and the assigned working voltage and current For example, A 300 means : in category AC 15, a maximum working voltage of 300 V and 6 A at 120 V or 3 A at 240 V. Electric shock protection. The user should observe the mounting instructions relating to the mode of protection against electric shocks defined in the IEC 536.1, EN 60204.1 NFC 20030 standards : Class I : earth circuit link. Protection via differential circuit-breaker. Class II : double insulation. Class III : very low safety voltage. Screw tightening torque : 1 : Actuator tightening 1.2 to 1.5 Nm 2 : Head fixing screw 3 : Body fixing screw 4 : Fixing screw Plastic Metal body body 0.7 to 0.8 Nm 0.8 to 1 Nm 0.7 to 0.8 Nm 0.8 to 1 Nm 2 to 2.5 Nm 2 1 4 3 Adjustment of rotary heads with momentary action to right and left : For series 83 850, 83 851, 83 861, 83 854, 83 855, 83 863 10° (x 360°) Contact block electrical wiring diagram Form Za Form Zb Both contacts have the same polarity The 2 contacts are electrically isolated Positive break contact operation (IEC 947-5-1, chapter 3) For contacts used in safety applications, limit switches, emergency stop devices, assurance that opening has occurred is essential (see IEC 204, EN60204). After each attempt, contact opening is checked by an impulse voltage test (2500 V). Contact element : - Snap action contact This is characterized by tripping points and release points which cannot be confused. The speed at which the control devices moves is independent from the speed of the control device. This feature makes it possible to obtain satisfactory electrical performance even where the control device is moving at low speed. A B F 0 C D A : Total travel (TT) of the control device B : Pre-travel (PT) until the contact element opens C : Release travel until the contact element closes D : B-C = Differential travel F : Travel required to reach the positive opening point (POT) Degree of protection Under the IEC 529 or NFC 20010 classification scheme, standards employ an IP code to define the degree or class of protection which a position detector provides against access to live components and against the entry of solid foreign bodies and the entry of water. 1st numeral Protection equipment provides against the entry of solid foreign bodies 0 4 5 6 Protection for persons against access to dangerous parts (not protected) diameter ≥1 mm protected against dust sealed against dust (not protected) 1 mm Ø wire 1 mm Ø wire 1 mm Ø wire 2nd numeral Protection equipment provides against the entry of water 0 4 5 (not protected) splashed water hosed water 6 7 8 high-pressure hosed water temporary immersion prolonged immersion Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/111 3 Mechanical characteristics Terminology Forces - Positions - Travel OP TP RRF OL RLP NC NO OF Operating force Forces Force which must be applied to the operating device to displace the rest position RP to the tripping point TP. RP Rest position TP Tripping point OP Operating point Position of the operating device when no external mechanical force is applied. Also described as "height at rest". Position of the operating device in relation to its mounting (hole, face) at the moment when an operating force causes the snap action of the mechanism to trip. Position of the operating device when the applied force has moved it to the point on its travel where mechanical and electrical operation of the detector can be relied on to occur. PT Pre-travel OT Operating travel Distance between the rest position RP and the operating point OP. Travel Positions TTF POP DT TT DT POF POT OT PT OF RP Electrical circuit POT OT TT Position of operating device PT Distance between the rest position RP and the tripping point TP. POF Positive opening force Operating force applied to the operating device to cause the positive opening action to take place. POP Positive opening point Position of the operating device at the moment when a force produces the positive opening action. POT Positive opening travel Minimum movement of the operating device required to ensure that the opening contact is positively opened. TTF Total travel force RRF Release force Force applied to the operating device to move it through its total travel. Level to which the operating force OF must be reduced to allow the mechanism to return to its release position RLP. OL Overtravel limit RLP Release position Position of the operating device when the force applied has brought it to the effective end of its permitted travel without causing damage. Position of the operating device at the moment when the snap-action mechanism trips on its return to its original position. TT Total travel Distance between the rest position RP and the overtravel limit OL. DT Differential travel Distance between the tripping point TP and the release position RLP. - Positive opening action : see IEC 947-5-1 chapter 3, § 2.2 N.B. : The max. and min. values quoted for each detector (min. operating force, max. total travel, etc.) are the maxima and minima users must allow for if they are to use our products under the proper conditions. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/112 Key Operated Safety Limit Switches – Technical Guide Standards Machine control circuits Extract from standards EN 292-2 and EN 1088. Moving guards to prevent risks created by moving (and therefore dangerous) parts must be used in conjunction with locking devices or interlocks with guard locking. Interlocks with guard locking must be used on machines with inertia. An interlock with guard locking must be used if the stopping time is greater than the time required for a person to reach the danger zone. This mechanism will delay unlocking the moving guard until the dangerous movement has actually stopped. Areas of application Key-operated safety interlock switches have been designed specifically for protecting operators working on dangerous machines. They can be used to lock or unlock moving guards on industrial machines, and meet the requirements of standards EN 292-2, EN 294, EN 1088 and EN 60204-1. Key-operated safety interlock switches are mainly used in applications which form part of the machine operating process. They are used to stop any dangerous movement whenever the moving guard system is open. The use of safety interlock switches in conjunction with XS and RS safety relays creates control circuits conforming to EN 954-1. Operating principle The start circuit is only closed after the key has been inserted fully and is used to close the NC contacts. Removing the key once the moving cover is open causes the positive action opening of the NC contact(s). The opening of the moving guard can be: Immediate Machines without inertia. Machines with a stopping time which is less than the time taken to access the danger zone. Delayed Machines with a stopping time which is greater than the time taken to access the danger zone. Examples of application Monitoring of delayed access moving guards Monitoring of immediate access moving guards 1 Level 3 for 1 or 2 moving cover(s): KNA3-XS + 83 893 001 The KNA3-XS interrupts the 24 V supply to the PLC outputs (33-34) Cover (closed) 2 Level 3 for 1 moving cover: KZR3-RS + 83 893 201 3 Level 4 for 1 moving cover: KNA3-RS + KSW2-RS + 83 893 201 24 V NO 0V Emergency stop C1 24 V PLC NC 24 V 13 23 33 A1 Y1 Y2 Run 14 24 34 KNA3-XS A2 41 42 14 24 34 OPEN C1 13 23 33 C2 c1 Y11 c2 C3 Y11 Y12 A1 13 23 31 41 13 23 K1 41 31 K2 K4 14 24 42 32 KZR3-RS Y21 Y22 42 A2 Y2 Y1 14 24 32 Run 3 C2 K3 M Y21 C1 C2 C3 C1 C2 0V 0V Y12 Y22 Emergency stop and moving cover controlled by two channels on terminals 41-42 (data contact) to a PLC output. Monitoring of immediate access rotary guards Level 3 for 1 moving cover: KNA3-XS + 83 893 3 + 24 V Cover C1 c1 Y11 Y12 13 23 33 A1 X1 Y2 S1 S2 41 PLC 4 c2 13 21 A1 X1 X2 Y11 24 V 13 23 33 A1 Y1 Y2 13 23 33 Run 14 24 34 KNA3-XS A2 41 42 14 24 34 C2 Y21 C1 13 23 33 41 14 24 34 42 KNA3-RS Y21Y22 42 A2 X2 Y1 14 24 34 C2 C3 KSW2-RS A2 14 22 L1 L2 L3 Y12 Y22 C1 M C2 0V C1 C2 C3 0V Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/113 Key-operated safety interlock switch, plastic Without key locking Switches with plastic body for use on light machinery, without inertia. For use in unstable environments where there is a risk of the guard opening accidentally (due to vibrations, if the guard is positioned at an angle, bouncing of the guard, etc). The guard is kept closed by adding a door stopping mechanism. WIth interlocking and locking of the key using an electromagnet Devices in plastic cases for use on machines with inertia, or which require controlled opening of the guard. The moving guard is locked by removing the voltage, or by applying voltage to the electromagnet. A special tool can be used to unlock the guard manually, to ensure the safety of personnel carrying out maintenance operations on the machine, or if there is a malfunction. Key-operated safety interlock switch, metal Without key locking Switches with metal body for use on machines without inertia in a stable environment where there is no risk of the guard opening accidentally (due to vibrations, if the guard is positioned at an angle, bouncing of the guard, etc) WIth interlocking and locking of the key using an electromagnet Devices in metal cases for use on machines without inertia, or which require controlled opening of the guard. The moving guard is locked by removing the voltage. A key-operated lock can be used to unlock the guard manually, to ensure the safety of personnel carrying out maintenance operations on the machine, or if there is a malfunction. These devices are fitted with 2 LEDs: one indicates the opening/closing of the guard, the other whether it is locked. Safety switch for hinged guards With angular or rotary movement head Switches with plastic body and angled lever or rotary shaft. They are designed for use on small industrial machines with compact doors, covers or rotating housings. These ensure the safety of the operator by stopping the dangerous movement immediately the lever or rotary shaft reaches an angle of 5°. These devices provide a solution for monitoring rotary guards with a small opening radius on machines without inertia. They are particularly suitable for adapting existing machines to meet applicable standards, as they can be mounted on covers which are already installed, including those mounted imprecisely. Mounting the switch increases the safety of the operator as it reduces the opening distance of the guard, and therefore the risk of reaching the danger zone. Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/114
79214578
物料型号:文档中没有明确列出具体的物料型号
器件简介:限位开关是一种位置检测器,需要物理力来操作。它们具有高电气性能、抗意外冲击的优良性能、良好的防水保护,并有多种操作装置以适应不同的机械结构。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性:包括工作电流(Ie)、热额定电流(Ith)、绝缘电压(Ui)等。这些参数定义了限位开关的电气特性和使用类别。
功能详解:限位开关符合国际IEC标准和/或欧洲标准(EN)。它们设计用于符合机器工具和工业机器的相关标准。
应用信息:限位开关适用于需要在各种机械上进行位置检测的场合,尤其是在需要高电气性能和抗冲击性的工业环境中。
封装信息:文档中没有提供具体的封装信息
79214578 价格&库存
很抱歉,暂时无法提供与“79214578”相匹配的价格&库存,您可以联系我们找货
