KRL2012E-M-R100-F-T5
    SUSUMU
    电流采样电阻 0508
KRL2012E-M-R100-F-T5 数据手册
Metal foil low resistance chip resistors (long-side terminal) ■KRL series AEC-Q200 Compliant Features ・ High current sensing long side terminal low resistance chip resistor ・ Two types available: high temperature (operating temperature up to 175°C), low emf type (operating temperature up to 155°C) ・ High current handling capability and wide range of power ratings ・ Size: 1608 ~ 15075, power ratings: 0.5W ~ 10W, resistance value range: 1m ~ 500mΩ ・ Face down construction. Choice between bottom only or wrap around terminal. Applications ・ Automotive electronics ・ Power source devises, ACDC converters, DCDC converters ・ Motors, inverters, office automation equipment ◆Part numbering system KRL 2012E - C - R010 - F - T1 Series code Resistance tolerance Current sensing surface mount resistors Size: KRL1608, KRL2012, KRL3216, KRL5025 KRL6432, KRL7638, KRL9045, KRL11050 KRL15075 KRL series Packaging quantity:T05(500pcs) T1(1,000pcs), T5(5,000pcs) Nominal resistance value Temperature characteristics type: C (high operating temperature), M (low EMF) Terminal type: D (bottom terminal), E (wrap around terminal) ◆Electrical Specification Type Power ratings KRL1608 0.5W KRL2012 1W KRL3216 1.5W KRL5025 2W KRL6432 3W KRL7638 4W KRL9045 5W KRL11050 6W KRL15075 10W Temperature coefficient of resistance (ppm/°C) ±1% (F) ±2% (G) ±5% (J) ±50 ±100 ー 5m≦R≦9m ー ー ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー R=2m ー ー R=1m ー ー ±100 ±150 10m≦R≦100m ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー 3m≦R≦9m (1m step) 10m≦R≦500m ー ー R=2m ー ー R=1m ±50 10m≦R≦500m ー ー ±100 3m≦R≦9m (1m step) ー R=2m R=1m ー ー ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±100 ±150 ±50 ±150 *1 *2 *1 Resistance range(Ω) Resistance tolerance We can meet your requirement of less than 1mΩ. Please contact our sales office. We can meet your requirement of resistance value outside of E-6 series. Please contact our sales office. 53 Resistance value series Operating temperature C Packaging quantity M T5 T1 T5 E-6 *2 -55℃ ~ 175℃ -55℃ ~ 155℃ T1 T05 T1 ◆Dimensions L t a a Size Type (inch) *1 W D Type L t a a W L W t a KRL1608 0603 0.80±0.20 1.60±0.20 0.50±0.20 0.25±0.20(5mΩ∼) KRL2012 0805 1.25±0.20 2.00±0.20 0.50±0.20 0.30±0.20(2mΩ∼)/0.55±0.20(1mΩ) KRL3216 1206 1.60±0.20 3.20±0.20 0.50±0.20 0.30±0.20(2mΩ∼)/0.55±0.20(1mΩ) KRL5025 2010 2.50±0.20 5.00±0.20 0.50±0.20 0.55±0.20(2mΩ∼)/0.90±0.20(1mΩ) KRL6432 2512 3.10±0.20 6.30±0.20 0.50±0.20 0.50±0.20(2mΩ∼)/1.20±0.20(1mΩ) KRL7638 3015 3.80±0.20 7.60±0.20 0.50±0.20 0.60±0.20(2mΩ∼)/1.35±0.20(1mΩ) KRL9045 3518 4.50±0.20 9.00±0.20 0.50±0.20 0.70±0.20(2mΩ∼)/1.60±0.20(1mΩ) KRL11050 4320 5.00±0.20 11.00±0.20 0.50±0.20 0.80±0.20(2mΩ∼)/1.60±0.20(1mΩ) KRL15075 5930 7.50±0.20 15.00±0.20 0.65±0.20 1.10±0.20(2mΩ∼)/2.75±0.20(1mΩ) *1 KRL1608 dosen't have E Type (unit:mm) E Type C(high operating temperature) M(low EMF) 100 50 0 -55     0     50  100 120 KRL series Ratio to rated power (%) Current sensing surface mount resistors ◆Derating Curve 155 175 Ambient temperature (℃) 54
KRL2012E-M-R100-F-T5 价格&库存
很抱歉,暂时无法提供与“KRL2012E-M-R100-F-T5”相匹配的价格&库存,您可以联系我们找货
    • 5000+1.203355000+0.15096
    • 10000+1.1768110000+0.14763
      • 5000+0.884825000+0.11100
      • 5000+1.390075000+0.17439
      • 10000+1.2963610000+0.16263
      • 15000+1.2482215000+0.15659
      • 25000+1.1937925000+0.14976
      • 35000+1.1613535000+0.14570
      • 50000+1.1296550000+0.14172
      • 60000+1.1144660000+0.13981
      库存:21506
      • 1+5.262931+0.66024
      • 10+3.3784610+0.42383
      • 25+2.8708425+0.36015
      • 50+2.5550750+0.32054
      • 100+2.28396100+0.28653
      • 250+1.98761250+0.24935
      • 500+1.80175500+0.22603
      • 1000+1.643901000+0.20623
      库存:21506
