79214581
    CROUZET(高诺斯)
    KEY-STRAIGHT FOR PLASTIC BODIE
79214581 数据手册
Miniature Plastic Key Lock Limit Switches Series 83 893 0 / 83 893 1 IP 67 ■ Key-operated safety interlock switches for monitoring the moving cover ■ Plastic bodies and heads ■ Heads have 4 possible positions ■ Positive opening contacts 1 General characteristics Part numbers Environment Conforming to standards Type of contact NC+NO 2-pole contact NC+NO 83 893 001 break before make, slow action NC+NC 2-pole contact NC+NC, 83 893 010 slow action Products Machine assemblies Certifications Protective treatment Temperature Use Stored Vibration resistance Shock resistance Degree of protection Cable entry Electrical characteristics Assigned working characteristics IEC 947-5-1, EN 60 947-5-1, UL 508, CSA C22-2 no.14, JIS C4520 (See P. 2/2 and 2/3) IEC 204-1, EN 60 204-1, EN 1088, EN 292 UL, CSA In normal operation: "TC" -25°C, +70°C -40°C, +70°C 5 gn (10…500 Hz) according to IEC 68-2-6 10 gn (duration 11 ms) according to IEC 28-2-27 IP 67 according to IEC 529 and IEC 947-5-1 Cable gland 11 Assigned impulse voltage AC 15 A 300 Ue = 240 V, Ie = 3A or Ue = 120 V, Ie = 6 A DC 13 Q 300 Ue = 250 V, Ie = 0.27 A or Ue = 125 V, Ie = 0.55 A Ui = 500 V according to IEC 947-5-1 Ui = 300 V according to UL 508, CSA C22-2 no. 14 Uimp = 6 KV acc. to IEC 947-5-1 Thermal rating Electric shock protection Ithe = 10 A according to IEC 947-5-1 Class 2 according to IEC 536 Resistance between terminals Short-circuit protection ≤ 30 mΩ according to IEC 954-5-4 Cartridge fuse 10 A gG (gl) Connection Screw clamp terminals Clamping capacity min. 1 x 0.5 mm2, max. 1.5 mm2 with or without ferrule Electrical life According to IEC 947-5-1 appendix C Assigned insulation voltage 83 893 120 NC+NO+NO 3-pole contact NC+NO+NO (2 NO bbm) + slow action NC+NC+NO 3-pole contact NC+NC+NO (NO bbm) + slow action 83 893 130 Additional characteristics Maximum actuation speed Minimum actuation speed Resistance to removal of key 0.5 m/s 0.01 m/s 10 N 0.5 m/s 0.01 m/s 10 N Mechanical life 1 million operating cycles 600 operating cycles per hour 1 million operating cycles 600 operating cycles per hour Minimum positive opening force 15 N 15 N Pg 11 cable entry according to NFC 68 300 Thermal rating (Ith) Assigned insulation voltage (Ui) 1 2 10 A 500 V 10 A 500 V Weight 0.110 kg 0.160 kg Maximum operating frequency Straight key 79 214 581 Key with wide fixing bar 79 214 582 Short key with wide fixing bar 79 214 585 Angled key 79 214 584 Flexible key 79 214 583 To order, specify: Standard products 1 2 Part number Accessory Example: Safety limit switch 83 893 001 - Straight key 79 214 581 Standard products, non stocked 2 Accessory Example: Straight key 79 214 581 Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/58 2 Accessories Dimensions 83 893 0 83 839 1 7 7 30 34 114.5 93.5 34 2 slots Ø 5.3 x 13.3 = 30 20/22 30 2 slots Ø 4.3 x 8.3 fixing centres 22 ; 2 holes Ø 4.3 fixing centres 20 12.5 2 slots Ø 4.3 x 8.3 fixing centres 22 ; 2 holes Ø 4.3 fixing centres 20 13.2 1 threaded hole for cable gland 11 39 30 39 30 = 12.5 2 threaded holes for cable gland 20/22 30 40.3 52 Accessories 79 214 584 79 214 583 12 Types 79 214 582 79 214 585 5 45 2 2 55 10° 10° 13 12 26 26 = 2 slots Ø 4.7 x 10 27 = 4.7 13 55 40 2 = 15 13 = 26 22 15 == 12 13 22 1 slot Ø 4.7 x 10 L 4.7 2 slots Ø 4.7 x 10 42 12 2 2 65 35 79 214 582 / 585 42 79 214 581 23 29 2 slots Ø 4.7 x 10 32 Dimension L (mm) 40 29 66 3 Operating radius 79 214 581 79 214 582 / 585 R= R = min. radius 00 150 0 00 00 12 15 12 = = R= R R R = min. radius Types 71 71 79 214 584 79 214 582 79 214 585 d d Dimension d (mm) 46 35 79 214 583 R = min. radius R = 15 0 30 = 0 0 00 150 12 R R= R= R = min. radius 48 48 72 72 Other information Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 3/59
79214581
物料型号: - 83 893 001 - 83 893 010 - 83 893 120 - 83 893 130
器件简介: - 微型塑料钥匙锁限位开关系列83 893 0 / 83 893 1,IP 67 - 钥匙操作的安全联锁开关,用于监控移动盖 - 塑料体和头部 - 头部有4个可能的位置,正开接触
引脚分配: - 未提供具体引脚分配信息
参数特性: - 环境:符合IEC 947-5-1, EN 60 947-5-1, UL 508, CSA C22-2no.14, JIS C4520等标准 - 认证:UL, CSA - 保护等级:IP 67 - 电缆入口:电缆密封套11
功能详解: - 电气特性包括额定工作特性、绝缘电压、冲击电压、热等级、电击保护等级等 - 连接方式:螺丝夹端子,最小1 x 0.5 mm2,最大1.5 mm2
应用信息: - 适用于需要安全联锁的场合
封装信息: - 提供了不同尺寸和形状的钥匙作为配件,例如直键、宽固定条短键、角键和柔性键
79214581 价格&库存
很抱歉,暂时无法提供与“79214581”相匹配的价格&库存,您可以联系我们找货
  • 15+46.44154
库存:50
