SPECIFICATIONS
Material: Silicone rubber conforms to A-A-59588
Class lll, GR60 (unless otherwise specified).
Mounting Nut: Brass, nickel-plated
Temperature Range: -94 F to +400 F (-70 C to +204 C).
Pressure Range: Exceeds 15 psi internal and 1500 psi external.
Operational Life: 50,000 actuations (minimum).
Shelf Life: Excess of 25 years.
Resistant to: Salt spray, sunlight, ozone, weather, fungus,and most
acids and lubricating oils.
Agency Recognition: UL & ULC Recognized to UL Std. 50
ROTARY SHAFT SEAL
CUSTOMER'S PANEL
CUSTOMER'S
BACKING FASTENER
A
A
HEX
.500
[12.7]
CUSTOMER'S
ROTARY DEVICE
ROTARY SHAFT SEAL
0.236
[6]
CUSTOMER'S PANEL
PERMISSIBLE RUBBER
OVERLAY .005 [0.127] MAX.
0.219
[5.56]
CUSTOMER'S
BACKING FASTENER
M10X0.75
TOLERANCES: UNLESS OTHERWISE NOTED
1/32 [ 0.793].
CUSTOMER'S
ROTARY DEVICE
A
REV.
ADDED CELSIUS EQUIVENT VALUE TEMPERATURE RANGE
DESCRIPTION
MAXIMUM AND MINIMUM MEASURETITLE:
MENTS ARE STATED DIRECTLY ON
EACH DIMENSION.
SEAL, SHAFT, ROTARY,
MAT'L: SILICONE RUBBER
conforms to A-A-59588, Gr. 60
FINISH:
BLACK
APM-HEXSEAL CORPORATION
ENG.
DWN:
CHKD.
SCALE
4:1
10.01.12
DATE
DAN LAW 12.07.11
DAN LAW 12.07.11
KEN S.
10.02.12
DWG.NO.
1332/46
THIS DRAWING COVERS PROPRIETARY ITEM AND IS THE PROPERTY OF THE APM-HEXSEAL CORPORATION.
THIS DRAWING IS NOT TO BE COPIED OR USED WITHOUT THE WRITTEN APPROVAL OF AN OFFICER OF THE APM-HEXSEAL CORPORATION.
很抱歉,暂时无法提供与“1332/4612”相匹配的价格&库存,您可以联系我们找货
