DYL060-3
DYL060-3
    TRI-MAG
    DYL060-3
DYL060-3 数据手册
      DYL060seriesisauniversalinputmultipleoutput powersupply.Theseriesisa60Wattpowersupplyinthe sizeof3”x5”withawattagedensityof3.1W/in3.The efficiencycanreachupto7586%dependingonmodel.  InputVoltage………………...…...90VACto264VAC InputFrequency………………………..47Hzto63Hz InrushCurrent(cold)…………...……Lessthan30Aat 115VAC,25°C OperatingTemperature……………..………..0to70ºC derated2.5%/°C>50°C StorageTemperature……………………40°Cto85°C Cooling…………………………..FreeAirConvection Efficiency……………………………..…...75%to86% HoldupTime……………………….>16msat115VAC OvervoltageType…….………………….…LatchOff OverloadProtection……...……………..Autorecovery ShortCircuitProtection…………………Autorecovery EarthLeakage…………...…...300AMax@240VAC DesignedinfullcompliancewithUL609501, UL606011 CSA22.2#609501,601.1 EN609501,EN606011 EMI……….…………….EN55022“B”,EN55011“B” FCCdocketclass“B” EMS…………………...EN6100042,3,4,5,6,8,11                            Connector:TB1—ACinput:Molex52772orequivalent TB2—DCoutput:Molex52738orequivalent TB3—ForLED:Molex50452orequivalentforDYL0601 TB4—ForFAN3,7,71,8,81,9,91,19,011  TB3—ForLED:Molex50452orequivalentforDYL0606 TB4—ForRemoteSense18  TB3—ForLED:Molex50452orequivalentforDYL06014  Size:76.2mmx127mmx30mm;3”x5”x1.18” MountingHoles:64.8mmx115.6mm;2.551”x4.551”   Jan. 2014    DYL0601 60 DYL0603 60 DYL0606 60 DYL0607 60 DYL06071 60 DYL0608 60 DYL06081 60 DYL0609 60 DYL06091 DYL06014 DYL06018 60 60 60 DYL06019 60 DYL060011 60              +5V +12 12 +5V +12V +5V +12V +5V +12V +15V +5V +15V +24V +5V +24V +48V +3.3V +3.3V +5V +12V 12V +5V +12V 12V 5V 0 0 0 0 0 0 0 0 0 0 0 0 0.1 0 0.1 0 0 0 0 0 0 0 0 0 0 3 3 0.3 3 3.5 10 4.8 0.5 5 3.8 0.5 4.0 2.4 0.5 2.7 1.25 10 5 4 1 0.6 3 3 0.3 0.3            5 6    5 5 1 5 5.5 15 7.5 1 7.5 6.0 1 6.0 3.8 1 3.8 2 18 8 7 2 1 5 5 1 1 ±1% ±5% ±5% ±1% ±5% ±1% ±1% ±5% ±1% ±1% ±5% 1% ±1% ±5% ±1% ±1% ±1% ±1% ±5% ±5% ±5% ±1% ±5% ±5% ±5% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 1% 50mv 50mv 1% 1% 1% 1% 1% 1% 1%    ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±3% ±3% ±5% ±3% ±3% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±3% ±3% ±3% ±5% ±5% ±3% ±3% ±5% ±5%                  Jan. 2014      DYL0601 DYL0603 DYL0606 DYL0607 DYL06071 DYL0608 DYL06081 DYL0609 DYL06091 DYL06014 DYL06018 DYL06019 DYL060011         +5V +5V +5V +12V +12V +15V +15V +24V +24V +48V +3.3V +3.3V +5V +5V +5V +5V +12V +12V +15V +15V +24V +24V +48V +3.3V +3.3V +5V GND GND +5V +12V +12V +15V +15V +24V +24V +48V +3.3V GND GND GND GND +5V GND GND GND GND GND GND GND GND GND GND +12V +12V GND GND GND GND GND GND GND GND GND +5V +12V +12V +12V GND GND GND GND GND GND GND GND GND +5V +12V 12V NC GND GND GND GND GND GND GND GND GND 12V 12V NC NC GND +5V NC +5V NC +5V NC NC GND +12V 5V   OurStandardpowersupplies,theDYL060Series,can beinstalledintoafullyenclosedchassisorina‘U’shape chassisasanoption.Theseoptionsoffertwomounting planes.Thefullyenclosedoptionhelpstoreduceradiated noise.  ExamplePartNumber: DYL0609ECSorDYL0609EUS *NoteDY040picturedinchassis   Jan. 2014
DYL060-3 价格&库存
很抱歉,暂时无法提供与“DYL060-3”相匹配的价格&库存,您可以联系我们找货
