XLP-08V
XLP-08V
    JST
    P=5mm
    1X8P 5MM
XLP-08V 数据手册
XL CONNECTOR 5.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– JS T • Current rating: 10A AC, DC (Refer to the table below.) • Voltage rating: 150V AC, DC • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #16 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Note: The rated current varies depending on the number of circuits and the size of the wire to be connected by crimping. Current unit:A Wire size(AWG) Circuits #16 10 9 9 6 6 5 2 3 4 8 12 16 The reliable XL connectors have been developed by utilizing the technology of JST's field proven VH and SM connectors. The XL connectors are being used in electric appliances, vending machines, and office automation equipment. #18 6 5 5 4 4 3 #20 5 4 4 3 3 2 #22 4 3 3 3 3 2 #24 3 3 3 2 2 1 #26 3 2 2 2 2 1 Note: Do not branch in parallel current which exceeds the rated current per circuit listed below. (Example: more than 10A in the case of a 2-circuit connector using AWG #16 wires.) If branched in parallel, current imbalance or other problems may develop. Standards –––––––––––––––––––––– • Reliable housing construction • Easy contact insertion • Box-shaped contact • Two kinds of connections 0 Recognized E60389 1 Certified LR20812 2 R75150 Locking header PC board layout (viewed from soldering side) and Assembly layout 3.0 min 17.7 φ1.5 ±0.05 20.1 5.8 ±0.05 (6.6) 5.0 ±0.05 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Shrouded header PC board layout (viewed from component side) [HDS type] Side entry type φ1.5±0.05 5.8±0.05 5.0±0.05 5.0±0.05 5.0±0.05 φ1.5±0.05 5.8±0.05 [HDS type] Top entry type 1 XL CONNECTOR Shrouded header PC board layout (viewed from component side) [HDB type] Top entry type 5.0±0.05 (3 circuits) 2-φ1.5±0.05 5.0±0.05 4.8±0.05 (2 circuits) φ2.5 3-φ1.5±0.05 6.6±0.05 5.8±0.05 φ2.5±0.05 4-φ1.5±0.05 10.3±0.1 5.8±0.05 φ2.5±0.05 (6 circuits) (4 circuits) (4 circuits) 6-φ1.5±0.05 4-φ1.5±0.05 5.0±0.05 6.6±0.05 2-φ1.5±0.05 ±0.05 5.0±0.05 φ2.5±0.05 5.0±0.05 φ2.5±0.05 3.0±0.05 (2 circuits) [HDB type] Side entry type φ2.5±0.05 5.8±0.05 10.3±0.1 5.8±0.05 6.6±0.05 5.8±0.05 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG # Model No. SXF-01T-P0.7 12.0 SXF-41T-P0.7 Insulation O.D. Q't y / reel (mm) 0.13∼0.5 26∼20 1.3∼2.7 0.5 ∼1.25 20∼16 1.9∼3.1 0.3×2∼0.5×2 22×2∼20×2 1.7×2∼2.0×2 3,000 4.0 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 3.35 Applicator Dies Crimp applicator with dies MKS-L MK/SXF-01-07 APLMK SXF01-07 |― |― |― Crimping machine Crimp applicator Contact AP-K2N SXF-01T-P0.7 RoHS compliance Note: Contact JST for brass products. 3.0 Contact SXF-41T-P0.7 Applicator Dies Crimp applicator with dies MKS-L MK/SXF-41-07 APLMK SXF41-07 |― |― |― Crimping machine Crimp applicator AP-K2N Housing (3 circuits) 2.55 4.35 5.8 10.9 (4 to 16 circuits) B 11.8 16.2 3.9 3.9 6.5 Circuits 2 3 4 8 12 16 5.0 Dimensions (mm) A B Model No. XLP-02V XLP-03V XLP-04V XLP-08V XLP-12V XLP-16V Q'ty / bag − − 500 − − 500 5.0 11.2 500 15.0 21.2 500 25.0 31.2 200 35.0 41.2 200 Material 2 5.1 10.0 PA 66, UL94V-0, natural (white) RoHS compliance 18.7 18.7 18.7 4.3 17.7 12.35 5.5 5.5 3.9 17.7 12.35 5.5 (2 circuits) 6.2 5.0 2.55 5.8 A 4.35 10.9 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. XLP-02V-oo(blank)…natural (white) K…black R…red E…blue Y…yellow XL CONNECTOR Locking header 1.85 Circuits 15.4 0.64 B02P-XL B04P-XL B08P-XL B12P-XL B16P-XL 2 4 8 14.6 3.4 8.0 14.6 17.8 Dimensions (mm) A B Model No. 12 16 Q'ty / box ― 5.0 250 5.0 10.0 200 15.0 20.0 100 25.0 30.0 50 35.0 40.0 50 Material and Finish 5.0 6.62 5.8 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) A B RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02P-XL-oo(blank)…natural (white) K…black R…red E…blue Y…yellow Shrouded header Top entry type Circuits 2 (2 circuits) (3 circuits) 3 4 6 1 Model No. Top entry type Side entry type S02P-XL-HDB B02P-XL-HDB − B03P-XL-HDB S04P-XL-HDB B04P-XL-HDB − B06P-XL-HDB Q'ty / box Top entry type Side entry type 200 100 200 − 200 100 100 − Material and Finish 3 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 16.4 13.8 8.0 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 14.6 14.6 7.9 2 1 2 3.0 3.0 ex. 6.6 0.64 φ3.2 1.2 4.8 5.0 5.8 (4 circuits) (6 circuits) 1 2 1 3 3 4 4 6 17.9 13.8 13.8 3.0 3.0 14.6 14.6 12.9 φ3.2 1.2 φ3.2 0.64 3.0 B02P-XL-HDB-oo-, S02P-XL-HDB-oo-, (blank)…natural (white) K…black R…red E…blue Y…yellow M…green H…gray N…brown D…orange L…lemon yellow 6.6 5.0 0.64 1.2 2.0 6.6 5.0 5.8 0.64 5.8 1.2 1.2 7.9 (4 circuits) 24.0 φ2.4 5.8 2 3 4 φ3.2 14.5 3.2 3.2 0.64 1 2 3.2 14.5 15.3 1 15.3 24.0 3.2 (2 circuits) 3.95 5.0 12.9 Side entry type 0.64 φ2.4 φ3.2 5.8 3 XL CONNECTOR Shrouded header Circuits Top entry type 2 4 8 12 8 5.8 5 16 14.6 3.0 7.9 200 12.9 200 − 15.0 22.9 100 40 25.0 32.9 50 30 35.0 42.9 40 20 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 5.0 − 5.0 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) B A 3.15 Dimensions (mm) Q'ty A B Top/bag Side/box Material and Finish 0.64 4 13.8 1 Model No. Top entry type Side entry type − B02P-XL-HDS − B04P-XL-HDS S08P-XL-HDS B08P-XL-HDS S12P-XL-HDS B12P-XL-HDS S16P-XL-HDS B16P-XL-HDS B08P-XL-HDS-oo-, S08P-XL-HDS-oo-, (blank)…natural (white) K…black R…red E…blue Y…yellow 1.2 3.2 15.3 Side entry type 5.0 0.64 1.2 5.8 24.0 B A Contact position location numbers 1 JST 4 8 16 7 15 6 12 6 14 5 11 5 13 4 10 4 12 2 JST 2 4 8 3 7 3 9 3 11 JST 1 JST JST JST 3 2 4 2 6 2 8 2 10 1 3 1 5 1 7 1 9 −
XLP-08V 价格&库存
很抱歉,暂时无法提供与“XLP-08V”相匹配的价格&库存,您可以联系我们找货
XLP-08V
    库存:23
    XLP-08V
      • 100+0.94170
      库存:739
      XLP-08V
        库存:1000
        XLP-08V
          • 1+1.366531+0.17713
          • 100+1.35825100+0.17606
          • 300+1.01040300+0.13097
          • 500+0.94415500+0.12238
          • 1000+0.894461000+0.11594
          • 4000+0.853054000+0.11057
          • 5000+0.853055000+0.11057
          库存:5184
