MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
160 to 450Vdc long life, 105℃
KXG
Series
KXJ
Downsized
・For electronic ballast circuits and other long life applications
・Endurance with ripple current : 8,000 to 10,000 hours at 105℃
・Non solvent resistant type
・RoHS2 Compliant
KXG
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃ (160 to 400Vdc)
-25 to+105℃ (450Vdc)
160 to 450Vdc
±20% (M)
(at 20℃, 120Hz)
After 1 minute
After 5 minutes
CV≦1,000
I=0.1CV+40
I=0.03CV+15
CV>1,000
I=0.04CV+100
I=0.02CV+25
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃)
Rated voltage (Vdc)
160 to 250V
350 to 450V
tanδ (Max.)
0.20
0.24
(at 20℃, 120Hz)
Rated voltage (Vdc)
160 to 250V
350 & 400V
450V
Z(-25℃)/Z(+20℃)
3
5
6
Z(-40℃)/Z(+20℃)
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours (8,000 hours forφ10) at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
F±0.5
Code : E
φD'
φd
Sleeve (PET : Brown)
F±0.5
● Terminal
L'
Vent
4min.
15min.
(φ10)
(φ12.5 to φ18)
φD
φd
F
φD'
L'
10
0.6
5.0
18
12.5 16
0.6 0.8 0.8
5.0 7.5 7.5
φD+0.5max.
L+1.5max.
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KXG AAA E AA AAA M AAA S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 6.8µF:6R8,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 160V:161,450V:451)
Series code
Category
Please refer to "Product code guide (radial lead type)"
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
6.8 to 82
100 to 330
120
1.00
1.00
1k
1.75
1.67
10k
2.25
2.05
100k
2.50
2.25
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V 2021
KXGSeries
◆STANDARD RATINGS
WV
(Vdc)
160
200
250
350
400
450
Cap
(µF)
Case size
φD×L(mm)
tanδ
10
22
33
47
68
82
100
100
150
220
330
10
22
33
47
68
82
100
150
220
330
10
22
33
47
68
82
100
150
220
6.8
10
22
33
47
68
68
82
100
120
150
6.8
10
15
22
33
47
47
68
82
100
120
150
6.8
10
15
22
33
33
47
68
82
100
10 × 16
10 × 20
10 × 20
10 × 20
12.5 × 20
12.5 × 20
12.5 × 25
16 × 20
16 × 20
16 × 25
18 × 31.5
10 × 16
10 × 20
10 × 20
12.5 × 20
12.5 × 20
16 × 20
16 × 20
16 × 25
18 × 25
18 × 35.5
10 × 20
10 × 20
12.5 × 20
12.5 × 20
16 × 20
16 × 20
16 × 25
18 × 25
18 × 31.5
10 × 16
10 × 20
12.5 × 20
16 × 20
16 × 20
16 × 25
18 × 20
18 × 25
18 × 25
18 × 31.5
18 × 35.5
10 × 16
10 × 20
12.5 × 20
12.5 × 20
16 × 20
16 × 25
18 × 20
18 × 25
18 × 25
18 × 31.5
18 × 35.5
18 × 40
10 × 20
12.5 × 20
12.5 × 25
16 × 20
16 × 25
18 × 20
18 × 25
18 × 31.5
18 × 35.5
18 × 40
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
Rated ripple current(mArms/105℃)
120Hz
100kHz
125
200
250
300
470
510
620
630
770
1,020
1,390
125
200
260
390
470
550
630
840
1,050
1,430
140
200
320
390
520
550
680
860
1,130
110
140
260
360
430
560
550
610
700
830
960
110
140
220
260
360
470
450
585
610
765
865
985
110
180
240
290
390
380
480
630
715
800
315
500
625
750
1,175
1,275
1,395
1,420
1,735
2,295
3,130
315
500
650
975
1,175
1,375
1,420
1,890
2,365
3,220
350
500
800
975
1,300
1,375
1,530
1,935
2,545
275
350
650
900
1,075
1,400
1,375
1,525
1,575
1,865
2,160
275
350
550
650
900
1,175
1,125
1,465
1,525
1,720
1,945
2,215
275
450
600
725
975
950
1,200
1,575
1,785
1,800
Part No.
EKXG161E□□100MJ16S
EKXG161E□□220MJ20S
EKXG161E□□330MJ20S
EKXG161E□□470MJ20S
EKXG161E□□680MK20S
EKXG161E□□820MK20S
EKXG161E□□101MK25S
EKXG161E□□101ML20S
EKXG161E□□151ML20S
EKXG161E□□221ML25S
EKXG161E□□331MMN3S
EKXG201E□□100MJ16S
EKXG201E□□220MJ20S
EKXG201E□□330MJ20S
EKXG201E□□470MK20S
EKXG201E□□680MK20S
EKXG201E□□820ML20S
EKXG201E□□101ML20S
EKXG201E□□151ML25S
EKXG201E□□221MM25S
EKXG201E□□331MMP1S
EKXG251E□□100MJ20S
EKXG251E□□220MJ20S
EKXG251E□□330MK20S
EKXG251E□□470MK20S
EKXG251E□□680ML20S
EKXG251E□□820ML20S
EKXG251E□□101ML25S
EKXG251E□□151MM25S
EKXG251E□□221MMN3S
EKXG351E□□6R8MJ16S
EKXG351E□□100MJ20S
EKXG351E□□220MK20S
EKXG351E□□330ML20S
EKXG351E□□470ML20S
EKXG351E□□680ML25S
EKXG351E□□680MM20S
EKXG351E□□820MM25S
EKXG351E□□101MM25S
EKXG351E□□121MMN3S
EKXG351E□□151MMP1S
EKXG401E□□6R8MJ16S
EKXG401E□□100MJ20S
EKXG401E□□150MK20S
EKXG401E□□220MK20S
EKXG401E□□330ML20S
EKXG401E□□470ML25S
EKXG401E□□470MM20S
EKXG401E□□680MM25S
EKXG401E□□820MM25S
EKXG401E□□101MMN3S
EKXG401E□□121MMP1S
EKXG401E□□151MM40S
EKXG451E□□6R8MJ20S
EKXG451E□□100MK20S
EKXG451E□□150MK25S
EKXG451E□□220ML20S
EKXG451E□□330ML25S
EKXG451E□□330MM20S
EKXG451E□□470MM25S
EKXG451E□□680MMN3S
EKXG451E□□820MMP1S
EKXG451E□□101MM40S
□□ : Enter the appropriate lead forming or taping code.
