KBP210
KBP210
    YFW(佑风微)
    KBP
    桥式整流器/整流桥 KBP 1000V 500μA
KBP210 数据手册
KBP201 THRU KBP210 KBP 2.0A GLASS PASSIVATED BRIDGE RECTIFIER Reverse Voltage - 100 to 1000 V Forward Current – 2.0A FEATURES  High current capability  Low forward voltage drop  Glass Passivated Chip Junction  Low power loss, high efficiency  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: KBP  Terminals: Solderable per MIL-STD-202, Method 208 1.Input pin(+) 2.Input pin(~) 3.Output Anode(~) 4.Output Cathode(-)  Approx. Weight: 1.52g / 0.05oz KBP Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Parameter Symbols KBP201 KBP202 KBP204 KBP206 KBP208 KBP210 Units Maximum Repetitive Peak Reverse Voltage VRRM 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 100 200 400 600 800 1000 V Average Rectified Output Current I(AV) 2 IFSM 45 A IFSM 80 100 A VF 1.1 V Peak Forward Surge Current 8.3 ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC method) Peak Forward Surge Current 1.0ms single half sine-wave @ Tj = 25 ℃ @ Tj = 125℃ Forward Voltage per element @IF =2.0A and 25°C Maximum DC Reverse Current @Tj=25°C at Rated DC Blocking Voltage A 5 IR μA 500 @Tj=125°C I2t Rating for Fusing(3ms≤t≤8.3ms) It 2 17.5 AS Typical Junction Capacitance(Note1) Cj 25 pF Typical Thermal Resistance (Note2) RθJA/ RθJC 40/10 °C/W Tj, Tstg -55 ~ +150 °C Operating and Storage Temperature Range 2 (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)Thermal Resistance Junction to Case, Lead and Ambient. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. KBP201 THRU KBP210 KBP PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD CURRENT AMPERES FIG.1 # FORWARD CURRENT DERATING CURVE 2.0 1.0 0 0 100 50 150 FIG.2 # MAXIMUM NON-REPETITIVE SURGE CURRENT 45 40 35 30 25 20 15 10 Single Half#Sine#Wave 05 0 1 2 5 TEMPERATURE , C 50 100 FIG.4 # TYPICAL FORWARD CHARACTERISTICS FIG.3 # TYPICAL JUNCTION CAPACITANCE 100 10 INSTANTANEOUS FORWARD CURRENT ,(A) CAPACITANCE , (pF) 20 10 NUMBER OF CYCLES AT 60Hz 10 Vsig=50mV p#p TJ = 25 C, f= 1MHz 1.0 0.1 TJ = 25 C PULSE WIDTH 300us .01 1.0 0.1 1.0 4 100 10.0 0 REVERSE VOLTAGE , VOLTS 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE , VOLTS FIG.5 # TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT ,(uA) 1000 TJ = 125 C 100 10 1.0 TJ = 25 C 0.1 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) www.yfwdiode.com 2/3 Dongguan YFW Electronics Co, Ltd. KBP201 THRU KBP210 KBP Package Outline KBP KBP MIN. MAX. A 14.25 14.75 B 3.35 3.65 C 10.20 10.60 D 14.25 14.73 d 1.40 1.70 E 1.80 2.20 DIM. F 0.80 1.10 G 3.56 4.06 H 0.35 0.55 I 1.22 1.42 J 0.76 0.86 K + ~ ~ - 2.7 x 45° (Typ) L # 3° M # 2° All Dimensions in millimeter Summary of Packing Options Package KBP www.yfwdiode.com Packing Description Packing Quantity 500 BOX 3/3 Industry Standard EIA-481-1 Dongguan YFW Electronics Co, Ltd.
KBP210 价格&库存
很抱歉,暂时无法提供与“KBP210”相匹配的价格&库存,您可以联系我们找货
KBP210
    • 5+0.74672
    • 50+0.62748
    • 150+0.56787
    • 500+0.49324
    • 2500+0.45749
    • 5000+0.43956
