FKBP210
FKBP210
    YFW(佑风微)
FKBP210 数据手册
FKBP210 KBP 2.0A UITRASOFT RECOVERY BRIDGE RECTIFIER Reverse Voltage –1000 V Forward Current – 2.0A FEATURES  Uitrasoft recovery  Low IRRM, Low VF, Low VRRM  Glass Passivated Chip Junction  Special frame design for heat dissipation  Lead free in comply with EU RoHS 2011/65/EU directives BENEFITS  Reduced EMI  Reduced Power loss and switching transistor  Reduced snubbing 1.Input pin(+) 2.Input pin(~) 3.Output Anode(~) 4.Output Cathode(-) MECHANICAL DATA  Case: GBP/KBP  Terminals: Solderable per MIL-STD-750, Method 2026 GBP/KBP Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols FKBP210 Units Maximum Repetitive Peak Reverse Voltage VRRM 1000 V Maximum RMS voltage VRMS 700 V Maximum DC Blocking Voltage VDC 1000 V Io 2.0 A Trr 10 uS IFSM 55 A Average Rectified Output Current Reverse Recovery Time.IF=0.5A,IR=1A,IRR=0.25A Peak Forward Surge Current 8.3 ms Single Half Sine-Wave Superimposed on Rated Load(JEDEC method) I2t Rating for Fusing(1ms≤t≤10ms) It 2 15 AS Maximum Forward Voltage at 1.0 A VF 1.0 V IR 5 100 uA Cj 40 pF Tj, Tstg -55 ~ +175 °C Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Junction Capacitance(Note1) Operating and Storage Temperature Range @TA=25℃ @TA=125℃ 2 Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. FKBP210 KBP RATINGS AND CHARACTERISTICS CURVES (TA = 25 °C unless otherwise noted) 100 Capacitance (pF) If, Average Forward Current (A) 3 2 1 0 T J =25°C 10 1 25 0 50 75 100 125 150 175 0.1 1.0 Tc, Case Temp ( C) Current Derating, Case 1050 Ir, Reverse Current (nA) If, Instantaneous Forward Current (A) 100 Typical Junction Capacitance 10 1.0 Tj=125℃ 0.1 0.01 10 Reverse Voltage (V) o Tj=75℃ Tj=25℃ 0.0 pulse with 300μs 1% duty cycle 0.5 1.0 1.5 Vf, Instantaneous Forward Voltage (V) 900 750 600 450 300 150 8.3 ms Single Half Sine Wave 00 2.0 100 500 1000 VR, Reverse Voltage (Volts) Typical Forward Voltage www.yfwdiode.com (JEDEC Method) Typical Reverse Current 2/3 Dongguan YFW Electronics Co, Ltd. FKBP210 KBP Package Outline KBP KBP DIM. A ~ ~ - MAX. 14.75 B 3.35 3.65 C 10.20 10.60 D 14.25 14.73 d 1.40 1.70 E 1.80 2.20 F 0.80 1.10 G 3.56 4.06 H 0.35 0.55 I 1.22 1.42 J 0.76 0.86 K + MIN. 14.25 2.7 x 45° (Typ) L # 3° M # 2° All Dimensions in millimeter Summary of Packing Options Package KBP www.yfwdiode.com Packing Description Packing Quantity 500 BOX 3/3 Industry Standard EIA-481-1 Dongguan YFW Electronics Co, Ltd.
FKBP210 价格&库存
很抱歉,暂时无法提供与“FKBP210”相匹配的价格&库存,您可以联系我们找货
