MMB50A-6-N
MMB50A-6-N
    COSEL
    MMB50A-6-N
MMB50A-6-N 数据手册
Ordering information AC-DC Power Supplies Enclosed type MMB50A MMB 50A 1 2 -1 3 -O 4 1Series name 2Output wattage 3Output voltage combination 4Optional *1 C :with Coating J :Connector type N :with Cover R MMB MODEL DC OUTPUT V1 V2 MMB50A-1 MMB50A-2 +5V 3.0A +5V 5.0A +12V 3.0(Peak 3.6)A +12V 2.1A MMB50A-3 MMB50A-4 +5V 3.0A +12V 2.1A +24V 1.5(Peak 1.8)A +12V 2.1A MMB50A-5 +12V 3.0A +12V 1.5A MMB50A-6 +15V 1.7A +15V 1.7A MMB50A-1 MMB50A-2 AC85 - 132 1f or DC110 - 170 1.4typ (Io=100%) 47 - 440 or DC 75typ 72typ 20typ (Io=100%) (At cold start) MMB50A-3 MMB50A-4 MMB50A-5 MMB50A-6 75typ 76typ 76typ 76typ SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 100V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] INRUSH CURRENT[A] ACIN 100V VOLTAGE[V] CURRENT[A] MINIMUM CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C RIPPLE[mVp-p] -10 - 0C 0 to +50C RIPPLE NOISE[mVp-p] -10 - 0C TEMPERATURE REGULATION[mV] 0 to +50C START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION INPUT-CASE, OUTPUT OUTPUT-CASE OUTPUT-OUTPUT(V1-V2) OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE +5 +12 +5 +12 +5 +24 +12 +12 +12 +12 +15 3 (Peak3.6) 5 2.1 3 1.5 (Peak1.8) 2.1 2.1 3 1.5 1.7 3 0 0 0 0 0 0 0 0 0 0 0 20max 48max 20max 48max 20max 96max 48max 48max 48max 48max 60max 40max 100max 40max 100max 40max 150max 100max 100max 100max 100max 120max 80max 120max 80max 120max 80max 120max 120max 120max 120max 120max 120max 140max 160max 140max 160max 140max 160max 160max 160max 160max 160max 160max 120max 150max 120max 150max 120max 150max 150max 150max 150max 150max 150max 160max 180max 160max 180max 160max 180max 180max 180max 180max 180max 180max 50max 120max 50max 120max 50max 240max 120max 120max 120max 120max 150max 100max (ACIN 85V, Io=100%) 15typ (ACIN 85V, Io=100%) 25typ (ACIN 100V, Io=100%) 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 10.8 - 13.2 Fixed 10.8 - 13.2 Fixed 13.5 - 16.5 11.64 - 12.36 xx 11.64 - 12.36 xx 23.28 - 24.72 xx 11.64 - 12.36 xx 11.64 - 12.36 xx xx Works at over 105% of rating (V2 works at peak current) and recovers automatically Works at 115 - 140% of rating AC2,000V 1minute, DC500V 50MWmin (At Room Temperature) AC500V 1minute, DC500V 50MWmin (At Room Temperature) AC100V 1minute, DC100V 50MWmin (At Room Temperature) -10 to +65C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) -25 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 30minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL Complies with DEN-AN Complies with FCC-B *1 Please contact us about safety approvals for the model with option. * Series/Parallel operation with other model is not possible. * Derating is required when operated with case cover. MMB-2 June 29, 2011 +15 1.7 0 60max 120max 120max 160max 150max 180max 150max Fixed 14.55 - 15.45 max MMB50A External view MMB I/O Connector Mating Connector CN1 10-31-1048 CN2 09-65-2089 10-63-3044 09-50-1083 Terminal Chain : 08-70-1031 Loose : 08-70-1030 Connector type Barrier strip type Dimensions in mm. Performance data ¡STATIC CHARACTERISTICS (MMB50A-1) ¡RISE TIME & FALL TIME (MMB50A-1) ¡OVERCURRENT CHARACTERISTICS (MMB50A-1) ¡DERATING CURVE June 29, 2011 MMB-3 Ordering information AC-DC Power Supplies Enclosed type MMB75A MMB 75A 1 2 -1 3 -O 4 1Series name 2Output wattage 3Output voltage combination 4Optional *1 J :Connector type N :with Cover R MMB MODEL DC OUTPUT V1 V2 MMB75A-1 +5V 5.0A +12V 4.0A MMB75A-2 +5V 6.0A +24V 2.0A MMB75A-1 AC85 - 132 1f or DC110 - 170 2.1typ (Io=100%) 47 - 440 or DC 76typ (Io=100%) 15typ (Io=100%) MMB75A-2 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS MODEL VOLTAGE[V] ACIN 100V CURRENT[A] FREQUENCY[Hz] EFFICIENCY[%] ACIN 100V INRUSH CURRENT[A] ACIN 100V VOLTAGE[V] CURRENT[A] MINIMUM CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C RIPPLE[mVp-p] -10 - 0C 0 to +50C RIPPLE NOISE[mVp-p] -10 - 0C TEMPERATURE REGULATION[mV] 0 to +50C START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION INPUT-CASE, OUTPUT OUTPUT-CASE OUTPUT-OUTPUT(V1-V2) OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE +5 +12 +5 +24 5 4 6 2 0 0 0 0 20max 48max 20max 96max 40max 100max 40max 150max 80max 120max 80max 120max 140max 160max 140max 160max 120max 150max 120max 150max 160max 180max 160max 180max 50max 120max 50max 240max 200max (ACIN 85V, Io=100%) 15typ (ACIN 85V, Io=100%) 25typ (ACIN 100V, Io=100%) 4.5 - 5.5 Fixed 4.5 - 5.5 Fixed 11.64 - 12.36 23.28 - 24.72 xx xx Works over 105% of rating and recovers automatically Works at 115 - 140% of rating AC2,000V 1minute, DC500V 50MWmin (At Room Temperature) AC500V 1minute, DC500V 50MWmin (At Room Temperature) AC100V 1minute, DC100V 50MWmin (At Room Temperature) -10 to +65C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -25 to +75C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 30minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL Complies with DEN-AN Complies with FCC-B *1 Please contact us about safety approvals for the model with option. * Series/Parallel operation with other model is not possible. * Derating is required when operated with case cover. MMB-4 78typ (Io=100%) June 29, 2011 MMB75A External view MMB I/O Connector Mating Connector CN1 10-31-1048 CN2 09-65-2089 10-63-3044 09-50-1083 Terminal Chain : 08-70-1031 Loose : 08-70-1030 Connector type Barrier strip type Dimensions in mm. Performance data ¡STATIC CHARACTERISTICS (MMB75A-1) ¡RISE TIME & FALL TIME (MMB75A-1) ¡OVERCURRENT CHARACTERISTICS (MMB75A-1) ¡DERATING CURVE 13.00 5.20 12.00 5.00 11.00 4.80 10.00 4.60 9.00 4.40 8.00 4.20 OUTPUT VOLTAGE V 12V 0 2.0 4.0 5V 6.0 8.0 OUTPUT CURRENT A June 29, 2011 Powered by TCPDF (www.tcpdf.org) MMB-5
MMB50A-6-N 价格&库存
很抱歉,暂时无法提供与“MMB50A-6-N”相匹配的价格&库存,您可以联系我们找货
