TB310S
TB310S
    YFW(佑风微)
TB310S 数据手册
TB34S THRU TB320S ABS 3A SURFACE MOUNT SCHOTTKY BRIDGE RECTIFIER Reverse Voltage - 40 to 200 V Forward Current - 3A FEATURES  High current capability  Low forward voltage drop  Low power loss, high efficiency    Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: ABS/LBF  Terminals: Solderable per MIL-STD-750, Method 2026        Approx. Weight: 88mg / 0.0031oz    ABS/LBF Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols TB34S TB36S TB38S TB310S TB320S Units Maximum Repetitive Peak Reverse Voltage VRRM 40 60 80 100 200 V Maximum RMS voltage VRMS 28 42 56 70 140 V Maximum DC Blocking Voltage VDC 40 60 80 100 200 V Average Rectified Output Current IF(AV) Parameter Peak Forward Surge Current 8.3 ms Single Half Sine-Wave Superimposed on Rated Load(JEDEC method) IFSM Max Instantaneous Forward Voltage at 3 A VF Maximum DC Reverse Current at Rated DC Blocking Voltage @TA=25°C @TA=100°C IR 3 A 80 0.55 A 70 0.70 0.85 0.5 0.3 10 5 250 160 0.95 V μA Typical Junction Capacitance(Note1) Cj Typical Thermal Resistance (Note2) RθJA 60 °C/W Tj -55 ~ +125 °C Tstg -55 ~ +150 °C Operating and Storage Temperature Range Storage Temperature Range pF (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm) copper pad. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. TB34S THRU TB320S ABS Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 25 50 75 100 125 150 10 4 T J =75°C 10 2 TB34S TB36S-TB320S 10 1 T J =25°C 10 0 0 Case Temperature (°C) 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Fig.4 Typical Junction Capacitance 500 20 Junction Capacitance ( pF) Instaneous Forward Current (A) T J =100°C 10 3 10 1.0 TB34S TB36S/TB38S TB310S TB320S 0.1 0.2 0 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 T J =25°C 200 100 50 TB32S/TB34S 20 TB36S-TB320S 10 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 100 8.3 ms Single Half Sine Wave (JEDEC Method) 80 60 TB34S/TB36S TB38S~TB320S 40 20 00 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com 2/3 Dongguan YFW Electronics Co, Ltd. TB34S THRU TB320S ABS ABS/LBF Package Outline Plastic surface mounted package; 4 leads ∠ALL ROUND ∠ALL ROUND C A a L1 d L HE e D e E A C D E HE d e max 1.5 0.22 5.2 4.5 6.4 4.2 0.7 min 1.3 0.15 4.9 4.2 6.0 3.8 0.5 max 59 8.7 205 177 252 165 28 min 51 5.9 193 166 236 150 20 UNIT mm L L1 a 0.95 0.6 0.2 ∠ 7° 37 mil 24 8 The recommended mounting pad size 6.2 244 4.0 157 1.0 39 2.0 79 mm Unit : (mil) Summary of Packing Options Package ABS/LBF www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 5000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
TB310S 价格&库存
很抱歉,暂时无法提供与“TB310S”相匹配的价格&库存,您可以联系我们找货
