MM1Z18B
MM1Z18B
    YONGYUTAI(永裕泰)
    SOD123
    MM1Z18B
MM1Z18B 数据手册
MM1Z Series SOD-123 Plastic-Encapsulate Zener Diode SOD-123 特征 Features  齐纳击穿阻抗低; Low Zener Impedance  最大功率耗散 500mW; Power Dissipation of 500mW  高稳定性和可靠性。High Stability and High Reliability 机械数据 Mechanical Data     封装: SOD-123 封装 SOD-123 Small Outline Plastic Package 极性: 色环端为负极 Polarity: Color band denotes cathode end 环氧树脂 UL 易燃等级 Epoxy UL: 94V-0 安装位置: 任意 Mounting Position: Any 极限值和温度特性(TA = 25℃ 除非另有规定) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 参数 Parameters 符号 Symbol 数值 Value 单位 Unit 功率消耗 Power Dissipation Pd 500 1) mW 正向压降 Forward Voltage @IF=10mA Vf 0.9 2) V 存储温度 Storage temperature range Ts -65-+150 ℃ RthA 400 K/W Thermal resistance junction to ambient air Warmewiderstand Sperrschicht 1) –umgebende Luft 1) 2) 3) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² Short duration test pulse used to minimize self-heating effect f=1KHz 电特性 (TA = 25℃ 除非另有规定) Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener 3) Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MM1Z2V0 WY 2.0 1.80 2.15 5 150 600 1.0 100 1.0 -3.5 0 5 MM1Z2V4 WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 MM1Z2V7 W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 MM1Z3V0 W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 MM1Z3V3 W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 MM1Z3V6 W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 MM1Z3V9 W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 MM1Z4V3 W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 MM1Z4V7 W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 MM1Z5V1 W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 MM1Z5V6 W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 MM1Z6V2 WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 MM1Z6V8 WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 MM1Z7V5 WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 MM1Z8V2 WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 MM1Z9V1 WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 MM1Z10 WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 www.yongyutai.com PAGE 1 MM1Z Series Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MM1Z11 WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 MM1Z12 WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 MM1Z13 WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 MM1Z15 WJ 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 MM1Z16 WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 MM1Z18 WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 MM1Z20 WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 MM1Z22 WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 MM1Z24 WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 MM1Z27 WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 MM1Z30 WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 MM1Z33 WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 MM1Z36 WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 MM1Z39 WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 MM1Z43 WU 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 MM1Z47 WV 47 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 MM1Z51 WW 51 48.0 54.0 2 125 750 1.0 0.1 38.0 10.0 12.0 5 MM1Z56 XW 56 52.0 60.0 2 135 700 1.0 0.1 39.0 10.0 12.0 5 MM1Z62 6E 62 58.0 66.0 2 200 1000 1.0 0.2 47.0 10.0 12.0 5 MM1Z68 6F 68 64.0 72.0 2 250 1000 1.0 0.2 52.0 10.0 12.0 5 MM1Z75 6H 75 70.0 79.0 2 300 1000 1.0 0.2 57 10.0 12.0 5 Breakdown characteristics at Tj=constant (pulsed) Forward characteristics www.yongyutai.com Admissible power dissipation versus ambient temperature PAGE 2 MM1Z Series Pulse thermal resistance versus pulse duration Dynamic resistance versus Zener current Capacitance versus Zener voltage Dynamic resistance versus Zener current Dynamic resistance versus Zener current Thermal differential resistance versus Zener voltage www.yongyutai.com PAGE 3 MM1Z Series Dynamic resistance versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Change of Zener voltage versus junction temperature Change of Zener voltage versus junction temperature Change of Zener voltge from turn-on up to the point of thermal equilibrium versus Zener voltage www.yongyutai.com PAGE 4 MM1Z Series SOD-123 PACKAGE OUTLINE Plastic surface mounted package θ θ 焊盘设计参考 Precautions: PCB Design Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs 技术要求: 3.24 1.0 中心距: 3.24 1, 塑封体尺寸: 2.70 X 1.60 脚 宽: 0.55 2: 未注公差为: ±0.05 焊盘宽: 1.00 3, 所有单位: mm 脚 长: 0.50 焊盘长: 0.80 0.8 www.yongyutai.com PAGE 5
MM1Z18B 价格&库存
很抱歉,暂时无法提供与“MM1Z18B”相匹配的价格&库存,您可以联系我们找货
MM1Z18B
  • 50+0.10822
  • 500+0.08489
  • 3000+0.07193
  • 6000+0.06416
  • 24000+0.05735
  • 51000+0.05379
库存:586
