ESD0801PB
ESD0801PB
    MDD(辰达半导体)
    ESD 5V截止 峰值脉冲电流:4A
ESD0801PB 数据手册
ESD0801PB TVS/ESD Protection Diodes DFN1006 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION ESD0801PB is a low-capacitance Transient Voltage Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection for data, control or power lines. With maximum capacitance of 15pF, ESD0801PB is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. ESD0801PB uses ultra-small DFN1006 package. Each ESD0801PB device can protect one data line. It offers system designers flexibility to protect single data line where space is a premium concern. Features Pin Configuration  Transient protection for high-speed data lines  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE)  Package optimized for hingh-speed lines  Low clamping voltage  Low Capacitance  Low leakage current  Each I/O pin can withstand over 1000 ESD strikes for ±8kV contact discharge Circuit Diagram Applications Mechanical Characteristics       Portable Electronics Desktops, Servers and Notebooks Cellular Phones MP3 Ports Subscriber Identity Module (SIM) card Digital Ports Package: DFN1006 Flammability Rating: UL 94V-0 Packaging: Tape and Reel High temperature soldering guaranted: 260℃/10s  Marking: PB  MSL3     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol VESD Peak Pulse Power(tp=8/20us waveform) PPP Operating Temperature Storage Temperature Range Lead Solder Temperature – Maximum (10 Second Duration) Value ± 25 ± 20 Unit kV 60 W TJ −55 to +125 °C TSTG −55 to +150 °C TL 260(10 sec.) °C The above data are for reference only. DN:T21827A1 http://www.microdiode.com Rev:2021A1 Page :1 ESD0801PB TVS/ESD Protection Diodes Electrical Characteristics (TA=25°C unless otherwise specified) Symbol bol Param VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage Test Condition IT = 1mA Min Typ Max Units 5.0 V 5.6 V IR Reverse Leakage Current VRWM = 5V 1 uA IPP Peak Pulse Current tP = 8/20us 4 A IPP = 1A, tp = 8/20μs 9.5 V IPP = 4A, tp = 8/20μs 15 V 15 pF VC Clamping Voltage CJ Junction Capacitance VR = 0V, f = 1MHz 8 The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :2 ESD0801PB TVS/ESD Protection Diodes ELECTRICAL CHARACTERISTICS CURVE The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :3 ESD0801PB TVS/ESD Protection Diodes Outlitne Drawing DFN1006 Package Outline Dimensions A DFN1006 Min Max Typ Dim A 0.50 0.45 0.55 b 0.55 0.50 0.45 D 1.05 0.95 1.00 E 0.55 0.60 0.65 e 0.40 L 0.30 0.25 0.20 R 0.07 0.17 0.12 All Dimensions in mm D R E b e L Suggested Pad Layout X1 Dimensions C G X X1 Y X Y Value (in mm) 0.90 0.40 0.50 1.10 0.50 Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. G C PACKAGE SPECIFICATIONS Package Reel Size DFN1006 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 10,000 210×210×205 100,000 445×445×230 400,000 7' http://www.microdiode.com Rev:2021A1 Page :4
ESD0801PB 价格&库存
很抱歉,暂时无法提供与“ESD0801PB”相匹配的价格&库存,您可以联系我们找货
