SN1603-TR
SN1603-TR
    3PEAK(思瑞浦)
    SOT23-6
    SN1603-TR
SN1603-TR 数据手册
SN1603 Full-HD Composite Video Filter Driver Features          Single FHD Video Filter Support HDCVI-1080p /1080i/720p, VGA/SVGA/XGA Optimized 6th-order Butterworth Video reconstruction filter: FHD Channel: -3dB ≥ 72MHz Support Multiple Input Biasing: - Provide 80-mV Level-Shift when DC-Coupled - Transparent Input Clamping when AC-Coupled - Support External DC Biasing when AC-Coupled Very Low Quiescent Current: 11.5 mA(at 3.3V, Typical) 6dB Gain(2V/V), Rail TO Rail Output AC- or DC-Coupled Output Driving Dual Video Loads (75Ω) Wide Power Supply: +3.0V to +5.5V Single Supply Robust ESD Protection: - Robust 8kV – HBM and 2kV – CDM ESD Rating Green Product, SOT23-6 Package Applications      Video Signal Amplification Set-Top Box Video Driver PVR、DVD Player Video Buffer Video Buffer for Portable or USB-Powered Video Devices HDTV Description SN1603 is a specially designed for consumer applications, high-performance, low-cost video reconstruction filter, it combine excellent video performance and low power consumption perfectly. It incorporates one Full high-definition (FHD) filter channels. The filter feature sixth-order Butterworth characteristics that are useful as digital-to-analog converter (DAC) reconstruction filters or as analog-to-digital converter (ADC) anti-aliasing filters. The FHD filters can be bypassed to support filters. The FHD filters can be bypassed to support 1080p60 video or up to quad extended graphics array (QXGA) RGB video. As part of the SN1603 flexibility, the input can be configured for ac- or dc-coupled inputs. The 84-mV output level shift allows for a full sync dynamic range at the output with 0-V input. The ac-coupled modes include a transparent sync-tip clamp option for Y', and G'B'R' signals. AC- coupled biasing for C'/P'B/P'R channels can easily be achieved by adding an external resistor to VS+. The SN1603 rail-to-rail output stage with 6-dB gain allows for both ac and dc line driving. The ability to drive two lines, or 75-Ω loads, allows for maximum flexibility as a video line driver. The 11.5-mA total quiescent current at 3.3 V makes it an excellent choice for power-sensitive video applications. SN1603 is available in SOT23-6 package. Its operation temperature range is from −40°C to +85°C. Related Resources AN-1201: Application notes of TPF1xx Function Block Figure 1. Rev. A www.3peakic.com ©2013 3PEAK INCORPORATED SN1603 Full-HD Composite Video Filter Driver Order Information Operating Order Number SN1603-TR Temperature Range -40 to 85°C Marking Package Transport Media, Information SOT23-6 S41 Quantity Tape and Reel, 3000 C Pin configuration (Top View) Pin Name FHD IN Pin Function Full-HD video input, LPF = 72 MHz GND Ground +VS Full-HD video output, LPF = 72 MHz FHD OUT No Connection NC Figure 2. Positive Power Supply Absolute Maximum Ratings* * Note: VIN IO TJ TA TSTG TL Parameters Power Supply, VDD to GND Input Voltage Output Current Maximum Junction Temperature Operating Temperature Range Storage Temperature Range Lead Temperature (Soldering 10 sec) Value Units 6.0 V VDD + 0.3V to GND - 0.3V 65 IO 150 TJ –45 to 85 TA –65 to 150 TSTG 300 TL Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (1) This data was taken with the JEDEC low effective thermal conductivity test board. (2) This data was taken with the JEDEC standard multilayer test boards. ESD, Electrostatic Discharge Protection Symbol HBM CDM Parameter Human Body Model ESD Condition MIL-STD-883H Method 3015.8 Charged Device Model ESD JEDEC-EIA/JESD22-C101E ©2014 3PEAK INCORPORATED ~ 2 ~ Minimum Level 8 2 Unit kV kV Rev. A www.3peakic.com SN1603 Full-HD Composite Video Filter Driver Electrical Characteristics All test condition is VDD = 3.3V, TA = +25°C, RL = 150Ω to GND, unless otherwise noted. SYMBOL PARAMETER CONDITIONS Input Electrical Specifications VDD Supply Voltage Range ICC Quiescent current (IQ) VOLS Output Level Shift Voltage VIN = 0V, no load, input referred ICLAMP-UP Clamp Charge Current VY = -0.2V AV Voltage Gain PSRR Power Supply Rejection Ratio VOL Output Voltage Low Swing ICLAMP-DOWN VCLAMP Clamp Discharge Current Input Voltage Clamp VOH Output Voltage High Swing ISC Short-circuit current AC Electrical Specifications VDD = 3.3V, VIN = 500mV, no load VDD = 5.0V, VIN = 500mV, no load VIN=300mV, measure current IY = -100μA VIN=0.5V,1V or 2V RL=150Ω to GND ΔVDD = 3.3V to 3.6V VIN = -0.3V, RL =75Ω VIN = 3V, RL =75Ω to GND (dual load) 2V output step, 80% to 20% dP Differential Phase Video input range 1V THD Total Harmonic Distortion D/DT Group Delay Variation tPD Propagation Delay SNR Signal-to-Noise Ration ROUT_AC 0.05 3.05 71.5 300 0.1 0.3 0.15 f = 100kHz to 27MHz 2.5 f=22MHz, VOUT=1.4VPP Output Impedance f = 10MHz f= 100kHz to 60MHz ~3~ mA 124 mV +40 6.03 0.1 3.1 72.9 80.1 1 0.6 0.6 6.0 -68 mA μA mA mV dB dB dB V V mA mA f=10MHz, VOUT=1.4VPP Channel Crosstalk 14.27 65 Video input range 1V f = 100kHz to 60MHz Maximum delay from input to output: (100kHz to 60MHz) f = 1MHz, VOUT=1.4VPP Rev. A www.3peakic.com 61 67 63.7 Slew Rate XTALK 6.01 39 f =148MHz Differential Gain 5.9 0 34 Stop Band Attenuation V 5.3 63.2 RL=150Ω 5.5 2.0 80 -1.7 3 UNITS 18.53 -1.5 -40 MAX 15 53.1 VIN =0.1V, output short to VDD Att148MHz dG 1.1 11.5 65 RL=150Ω SR 53 TYP VIN = 2V, 10Ω, output to GND -1dB Bandwidth -3dB Bandwidth 3.0 ΔVDD = 5.0V to 5.5V, 50Hz f-1dB f-3dB MIN 11.0 -74 MHz MHz dB V/μs % ° % % ns 18.0 64 0.5 ©2014 3PEAK INCORPORATED ns ns dB dB Ω SN1603 Full-HD Composite Video Filter Driver Typical Performance Characteristics All test condition is VDD = 3.3V, TA = +25°C, RL = 150Ω to GND, unless otherwise noted. 1 5 0.6 3 4 NORMALIZED GAIN (dB) NORMALIZED GAIN (dB) 0.8 0.4 0.2 0 -0.2 -0.4 VDD =3.3V RL =150Ω CL =15pF -0.6 -0.8 -1 100k -0.1dB@50MHz 1M 10M FREQUENCY (Hz) 2 1 0 -1 -2 VDD =3.3V RL =150Ω CL =15pF -3 -4 -5 100k 100M Figure3. Small-Scale Frequency Response 2 CL =15pF 1 -100 CL =5pF -200 PHASE (O) NORMALIZED GAIN (dB) 3 0 -300 -1 -400 CL =20p -2 V DD =3.3V RL =150Ω CL =15pF -500 V DD =3.3V RL =150Ω -5 100k 1M 10M FREQUENCY (Hz) -600 100k 100M Figure5. Gain Vs. Frequency With CLOAD NORMALIZED GAIN (dB) 30.0 25.0 20.0 15.0 10.0 0.0 -5.0 -10.0 100M 10 35.0 5.0 1M 10M FREQUENCY (Hz) Figure6. Gain Vs. Frequency 40.0 GROUP DELAY (ns) 100M 0 4 -4 1M 10M FREQUENCY (Hz) Figure4. Large-Scale Frequency Response 5 -3 -3dB@72MHz V DD =3.3V RL =150Ω CL =15pF 1M 10M 100M FREQUENCY (Hz) -10 -20 148MHz, -39dB -30 -40 -50 -60 1G Figure7. Group Delay vs Frequency ©2014 3PEAK INCORPORATED 0 V DD =3.3V RL =150Ω CL =15pF 1M 10M 100M FREQUENCY (Hz) Figure8. Stop Band Attenuation ~ 4 ~ Rev. A www.3peakic.com 1G SN1603 Full-HD Composite Video Filter Driver 0 V DD =3.3V -10 45 40 CURRENT (mA) PSSR (dB) -20 -30 -40 -50 -60 -70 -80 35 30 25 20 15 10 5 1k 10k 100k 1M FREQUENCY (Hz) 10M 0 3.0 100M Figure9. PSRR Vs. Frequency 5.5 0.9 1.5 0.8 VDD =+3.3V RL =100Ω VOUT=1VP-P 1.0 0.5 tRISE=7.75ns 0 20 40 60 AMPLITUDE (V) AMPLITUDE (V) 4.0 4.5 5.0 SUPPLY VOLTAGE (V) Figure10. Current Vs. Supply Voltage 2.0 0.0 3.5 tFALL =7.41ns 80 100 TIME (ns) 120 140 Figure11. Large-Signal Pulse Response Vs. Time Rev. A www.3peakic.com 0.6 0.5 0.4 160 VDD =+3.3V RL =100Ω VOUT=200mV P-P 0.7 tRISE=3.25ns 0 20 40 60 tFALL =3.59ns 80 100 TIME (ns) 120 140 160 Figure12. Small-Signal Pulse Response Vs. Time ~5~ ©2014 3PEAK INCORPORATED SN1603 Full-HD Composite Video Filter Driver Application Information The SN1603 is targeted for systems that require one full high-definition (FHD) video outputs. Although it can be used for numerous other applications, the needs and requirements of the video signal are the most important design parameters of the SN1603. The SN1603 incorporates many features not typically found in integrated video parts while consuming very low power. Internal Sync Clamp The typical embedded video DAC operates from a ground referenced single supply. This becomes an issue because the lower level of the sync pulse output may be at a 0V reference level to some positive level. The problem is presenting a 0V input to most single supply driven amplifiers will saturate the output stage of the amplifier resulting in a clipped sync tip and degrading the video image. A larger positive reference may offset the input above its positive range. The SN1603 features an internal sync clamp and offset function to level shift the entire video signal to the best level before it reaches the input of the amplifier stage. These features are also helpful to avoid saturation of the output stage of the amplifier by setting the signal closer to the best voltage range. The simplified block diagram of the SN1603 in Figure-1. The AC coupled video sync signal is pulled negative by a current source at the input of the comparator amplifier. When the sync tip goes below the comparator threshold the output comparator is driven negative, The PMOS device turns on clamping sync tip to near ground level. The network triggers on the sync tip of video signal. Droop Voltage and DC Restoration Selection of the input AC-coupling capacitance is based on the system requirements. A typical sync tip width of a 64μs NTSC line is 4μs during which clamp circuit restores its DC level. In the remaining 60μs period, the voltage droops because of a small constant 2.0μA sinking current. If the AC-coupling capacitance is 0.1μF, the maximum droop voltage is ©2014 3PEAK INCORPORATED about 1mV which is restored by the clamp circuit. The maximum pull-up current of the clamp circuit is 1.7mA. For a 4μs sync tip width and 0.1μF capacitor, the maximum restoration voltage is about 80mV. The line droop voltage will increase if a smaller AC-coupling capacitance is used. For the same reason, if larger capacitance is used the line droop voltage will decrease. Table 1 is droop voltage and maximum restoration voltage of the clamp for typical capacitance. Table 1. Maximum restoration voltage and droop voltage of Y signals for different capacitance CAP VALUE (nF) 100 1,000 DROOP IN 60μs (mV) 1.2 0.12 CHARGE IN 4μs (mV) 68 6.8 Low Pass Filter--Sallen Key The Sallen Key is a classic low pass configuration. This provides a very stable low pass function, and in the case of the SN1603, the six-pole roll-off at around 72MHz. The six-pole function is accomplished with an RC low pass network placed in series with and before the Sallen Key. Output Couple SN1603 output could support both “AC Couple” and “DC Couple”, if use “AC Couple”, this capacitor is typically between 220-μF and 1000-μF, although 470-μF is common. This value of this capacitor must be this large to minimize the line tilt (droop) and/or field tilt associated with ac-coupling as described previously in this document. The SN1603 internal sync clamp makes it possible to DC couple the output to a video load, eliminating the need for any AC coupling capacitors, thereby saving board space and additional expense for capacitors. This makes the SN1603 extremely attractive for portable video applications. Additionally, this solution completely eliminates the issue of field tilt in the lower frequency. The trade off is greater demand of supply current. Typical load current for AC coupled is around 1mA, compared to typical 6.6mA used when DC ~ 6 ~ Rev. A www.3peakic.com SN1603 Full-HD Composite Video Filter Driver coupling. PDMAX =Vs  I SMAX +(Vs  VOUT) Output Drive Capability and Power Dissipation Where: VS = Supply voltage ISMAX = Maximum quiescent supply current VOUT = Maximum output voltage of the application RLOAD = Load resistance tied to ground With the high output drive capability of the SN1603, it is possible to exceed the +125°C absolute maximum junction temperature under certain load current conditions. Therefore, it is important to calculate the maximum junction temperature for an application to determine if load conditions or package types need to be modified to assure operation of the amplifier in a safe operating area. The maximum power dissipation allowed in a package is determined according to Equation: PDMAX = By setting the two PDMAX equations equal to each other, we can solve the output current and RLOAD to avoid the device overheat. Power Supply Bypassing Printed Circuit Board Layout As with any modern operational amplifier, a good printed circuit board layout is necessary for optimum performance. Lead lengths should be as short as possible. The power supply pin must be well bypassed to reduce the risk of oscillation. For normal single supply operation, a single 4.7μF tantalum capacitor in parallel with a 0.1μF ceramic capacitor from VS+ to GND will suffice. TJMAX  TAMAX  JA Where: TJMAX = Maximum junction temperature TAMAX = Maximum ambient temperature ΘJA = Thermal resistance of the package The maximum power dissipation actually produced by an IC is the total quiescent supply current times the total power supply voltage, plus the power in the IC due to the load, or: for sourcing: VIDEO FILTER DRIVER SELECTION GUIDE P/N TPF110 /TPF110L TPF113 TPF114 TPF116 TPF123 TPF133 TPF134 Product Description VOUT RL Channel -3dB Bandwidth 9MHz SC70-5 SOT23-6 Low power 3 channel, 6th-order 3-SD 9MHz SO-8 Low power 4 channel, 6th-order 4-SD 9MHz Low power 4 channel, 6th-order 6-SD 9MHz MSOP-10 TSSOP-14 3-ED 13.5MHz SO-8 Low power 3 channel, 6th-order 3-HD 36MHz SO-8 Low power 3 channel, 6th-order 1-SD& 3-SD 9MHz 36MHz MSOP-10 TSSOP-14 Low power, enable function and SAG correction, 1 channel 6 order 9MHz th 9MHz SD video filter 9MHz SD video filter 9MHz SD video filter for CVBS, SVIDEO 3 channel 6th-order 13.5MHz, 960H/720H-CVBS video filter or Y’Pb’Pr 480P/576P video filter 36MHz HD video filter 36MHz HD video filter and 1 channel Rev. A www.3peakic.com 1-SD ~7~ Package TSSOP-14 ©2014 3PEAK INCORPORATED SN1603 Full-HD Composite Video Filter Driver TPF136 TPF143 TPF144 TPF146 TPF153 SD video filter 36MHz HD video filter and 3 channel 3-SD& 3-HD 9MHz 36MHz TSSOP-20 Low power 3 channel, 6th-order 3-FHD 72MHz SO-8 Low power 3 channel, 6th-order 1-SD& 3-FHD 9MHz 72MHz MSOP-10 TSSOP-14 72MHz Full HD video filter and3 3-SD& 3-FHD 9MHz 72MHz TSSOP-20 Low power 3 channel, 6th-order 3-CH 220MHz SO-8 Low power 3 channel, 6th-order SD video filter 72MHz Full HD video filter 72MHz Full HD video filter and 1 channel SD video filter Low power 3 channel, 6th-order channel SD video filter 220MHz Full HD video filter ©2014 3PEAK INCORPORATED ~ 8 ~ Rev. A www.3peakic.com SN1603 Full-HD Composite Video Filter Driver Package Outline Dimensions SOT23-6 Symbol Min Max In Inches Min Max 0.000 0.100 0.000 0.004 b 0.300 0.400 0.012 0.016 1.700 0.059 0.067 D E E1 e 1.050 2.820 1.500 2.650 1.150 3.020 2.950 0.950TYP 0.041 0.111 0.104 0.045 0.119 0.116 0.037TYP e1 1.800 2.000 0.071 0.079 θ 0° 8° 0° 8° L1 ~9~ In Millimeters Dimensions A1 A2 Rev. A www.3peakic.com Dimensions 0.300 0.460 0.012 0.024 ©2014 3PEAK INCORPORATED SN1603 Full-HD Composite Video Filter Driver IMPORTANT NOTICE "PRELIMINARY" PRODUCT INFORMATION DESCRIBES PRODUCTS THAT ARE IN PRODUCTION, BUT FOR WHICH FULL CHARACTERIZATION DATA IS NOT YET AVAILABLE. 3PEAKIC MICROELECTRONICS CO. LTD BELIEVES THAT THE INFORMATION CONTAINED IN THIS DOCUMENT IS ACCURATE AND RELIABLE. HOWEVER, THE INFORMATION IS SUBJECT TO CHANGE WITHOUT NOTICE AND IS PROVIDED “AS IS” WITHOUT WARRANTY OF ANY KIND (EXPRESS OR IMPLIED). CUSTOMERS ARE ADVISED TO OBTAIN THE LATEST VERSION OF RELEVANT INFORMATION TO VERIFY, BEFORE PLACING ORDERS, THAT INFORMATION BEING RELIED ON IS CURRENT AND COMPLETE. ALL PRODUCTS ARE SOLD SUBJECT TO THE TERMS AND CONDITIONS OF SALE SUPPLIED AT THE TIME OF ORDER ACKNOWLEDGMENT, INCLUDING THOSE PERTAINING TO WARRANTY, INDEMNIFICATION, AND LIMITATION OF LIABILITY. NO RESPONSIBILITY IS ASSUMED BY 3PEAKIC MICROELECTRONICS CO. LTD FOR THE USE OF THIS INFORMATION, INCLUDING USE OF THIS INFORMATION AS THE BASIS FOR MANUFACTURE OR SALE OF ANY ITEMS, OR FOR INFRINGEMENT OF PATENTS OR OTHER RIGHTS OF THIRD PARTIES. THIS DOCUMENT IS THE PROPERTY OF 3PEAKIC MICROELECTRONICS CO. LTD AND BY FURNISHING THIS INFORMATION, 3PEAKIC MICROELECTRONICS CO. LTD GRANTS NO LICENSE, EXPRESS OR IMPLIED UNDER ANY PATENTS, MASK WORK RIGHTS, COPYRIGHTS, TRADEMARKS, TRADE SECRETS OR OTHER INTELLECTUAL PROPERTY RIGHTS. 3PEAKIC MICROELECTRONICS CO. LTD OWNS THE COPYRIGHTS ASSOCIATED WITH THE INFORMATION CONTAINED HEREIN AND GIVES CONSENT FOR COPIES TO BE MADE OF THE INFORMATION ONLY FOR USE WITHIN YOUR ORGANIZATION WITH RESPECT TO 3PEAKIC MICROELECTRONICS CO. LTD INTEGRATED CIRCUITS OR OTHER PRODUCTS OF 3PEAKIC MICROELECTRONICS CO. LTD. THIS CONSENT DOES NOT EXTEND TO OTHER COPYING SUCH AS COPYING FOR GENERAL DISTRIBUTION, ADVERTISING OR PROMOTIONAL PURPOSES, OR FOR CREATING ANY WORK FOR RESALE. CERTAIN APPLICATIONS USING SEMICONDUCTOR PRODUCTS MAY INVOLVE POTENTIAL RISKS OF DEATH, PERSONAL INJURY, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE (“CRITICAL APPLICATIONS”). 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS ARE NOT DESIGNED, AUTHORIZED OR WARRANTED FOR USE IN AIRCRAFT SYSTEMS, MILITARY APPLICATIONS, PRODUCTS SURGICALLY IMPLANTED INTO THE BODY, AUTOMOTIVE SAFETY OR SECURITY DEVICES, LIFE SUPPORT PRODUCTS OR OTHER CRITICAL APPLICATIONS. INCLUSION OF 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS IN SUCH APPLICATIONS IS UNDERSTOOD TO BE FULLY AT THE CUSTOMER'S RISK AND INCLUSION DISCLAIMS AND MAKES NO WARRANTY, EXPRESS, STATUTORY OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR PARTICULAR PURPOSE, WITH REGARD TO ANY DISCLAIMS PRODUCT THAT IS USED IN SUCH A MANNER. IF THE CUSTOMER OR CUSTOMER'S CUSTOMER USES OR PERMITS THE USE OF 3PEAKIC MICROELECTRONICS CO. LTD PRODUCTS IN CRITICAL APPLICATIONS, CUSTOMER AGREES, BY SUCH USE, TO FULLY INDEMNIFY 3PEAKIC MICROELECTRONICS CO. LTD, ITS OFFICERS, DIRECTORS, EMPLOYEES, DISTRIBUTORS AND OTHER AGENTS FROM ANY AND ALL LIABILITY, INCLUDING ATTORNEYS' FEES AND COSTS, THAT MAY RESULT FROM OR ARISE IN CONNECTION WITH THESE USES. THE LOGO DESIGNS OF 3PEAKIC MICROELECTRONICS CO. LTD ARE TRADEMARKS OF DESIGNS. ALL OTHER BRAND AND PRODUCT NAMES IN THIS DOCUMENT MAY BE TRADEMARKS OR SERVICE MARKS OF THEIR RESPECTIVE OWNERS. Contact information: USA: 635 W. Alma School Road, Suite102 Chandler, USA. AZ 85234 Shanghai-China: Room 401-407 No.1278 Keyuan Road, Zhangjiang High-tech Park, Pudong New District, Shanghai, China Zip Code: 201203 Suzhou-China: Suite 304, Building B2, Creative Industrial Park, No.328 Xinghu Street, Industrial Park, Suzhou, Jiangsu Province, China Zip Code: 215123 ©2014 3PEAK INCORPORATED ~ 10 ~ Rev. A www.3peakic.com
SN1603-TR 价格&库存
很抱歉,暂时无法提供与“SN1603-TR”相匹配的价格&库存,您可以联系我们找货
