BCX56TX
BCX56TX
    NEXPERIA(安世)
    SOT89
    BCX56TX
BCX56TX 数据手册
BCX56T series 80 V, 1 A NPN power bipolar transistors Rev. 1 — 22 August 2019 Product data sheet 1. Product profile 1.1. General description NPN power transistors in a medium power SOT89 (SC-62) flat lead Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number PNP complement Package BCX56T Nexperia JEDEC SOT89 SC-62 BCX53T BCX56-10T BCX53-10T BCX56-16T BCX53-16T 1.2. Features and benefits • • • • High collector current capability IC and ICM Three current gain selections High power dissipation capability AEC-Q101 qualified 1.3. Applications • • • • • Linear voltage regulators MOSFET drivers Low-side switches Power management Amplifiers 1.4. Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 80 V IC collector current - - 1 A ICM peak collector current - - 2 A single pulse; tp ≤ 1 ms BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors Symbol Parameter Conditions Min Typ Max hFE DC current gain [1] 63 - 250 BCX56-10T [1] 63 - 160 BCX56-16T [1] 100 - 250 BCX56T [1] VCE = 2 V; IC = 150 mA Unit pulsed; tp ≤ 300 μs; δ ≤ 0.02 2. Pinning information Table 3. Pinning Pin Symbol Description 1 E emitter 2 C collector 3 B base Simplified outline Graphic symbol C B 3 2 E 1 sym042 3. Ordering information Table 4. Ordering information Type number Package BCX56T BCX56-10T Name Description Version SC-62 plastic, surface-mounted package; 3 leads; 1.5 mm pitch; 4.5 mm x 2.5 mm x 1.5 mm body SOT89 BCX56-16T 4. Marking Table 5. Marking Type number Marking code BCX56T A7 BCX56-10T A5 BCX56-16T A6 BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 100 V VCEO collector-emitter voltage open base - 80 V VEBO emitter-base voltage open collector - 5 V IC collector current - 1 A ICM peak collector current - 2 A IB base current - 200 mA IBM peak base current single pulse; tp ≤ 1 ms - 300 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 500 mW [2] - 800 mW [3] - 1100 mW single pulse; tp ≤ 1 ms Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] [3] Device mounted on an FR4 PCB; single-sided copper; tin-plated and standard footprint. 2 Device mounted on an FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 1 cm . 2 Device mounted on an FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 6 cm . 006aaa238 1600 Ptot (mW) 1200 (1) (2) 800 (3) 400 0 - 75 - 25 25 75 125 175 Tamb (°C) 2 (1) FR4 PCB; mounting pad for collector 6 cm 2 (2) FR4 PCB; mounting pad for collector 1 cm (3) FR4 PCB; standard footprint Fig. 1. Power derating curves BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors 6. Thermal characteristics Table 7. Thermal characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] [2] [3] Min Typ Max Unit [1] - - 250 K/W [2] - - 157 K/W [3] - - 114 K/W Device mounted on an FR4 PCB; single-sided copper; tin-plated and standard footprint. 2 Device mounted on an FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 1 cm . 2 Device mounted on an FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 6 cm . 006aaa235 103 Zth (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.2 0.1 0.05 10 0.02 0 1 10-5 0.01 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB; single-sided copper; tin-plated and standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aaa236 103 Zth (K/W) duty cycle = 1 102 0.75 0.33 0.1 10 0 1 10-5 0.5 0.2 0.05 0.02 0.01 10-4 10-3 10-2 10-1 1 FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 1 cm Fig. 3. 10 102 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors 006aaa237 103 Zth (K/W) 102 duty cycle = 1 0.75 0.33 0.5 0.2 10 0.1 0.05 0.02 0 0.01 1 10-5 10-4 10-3 10-2 10-1 1 FR4 PCB; single-sided copper; tin-plated; mounting pad for collector 6 cm Fig. 4. 102 10 103 tp (s) 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = 100 µA; IE = 0 A 100 - - V V(BR)CEO collector-emitter breakdown voltage IC = 2 mA; IE = 0 A 80 - - V V(BR)EBO emitter-base breakdown voltage IE = 100 µA; IC = 0 A 5 - - V ICBO collector-base cut-off current VCB = 30 V; IE = 0 A - - 100 nA VCB = 30 V; IE = 0 A; Tj = 150 °C - - 10 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 2 V; IC = 5 mA 63 - - BCX56T, -10T, -16T VCE = 2 V; IC = 500 mA [1] 40 - - BCX56T VCE = 2 V; IC = 150 mA [1] 63 - 250 BCX56-10T VCE = 2 V; IC = 150 mA [1] 63 - 160 BCX56-16T VCE = 2 V; IC = 150 mA [1] 100 - 250 VCEsat collector-emitter saturation voltage IC = 500 mA; IB = 50 mA [1] - - 500 mV VBE base-emitter voltage VCE = 2 V; IC = 500 mA [1] - - 1 V fT transition frequency VCE = 5 V; IC = 50 mA; f = 100 MHz - 155 - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 4.5 - pF [1] pulsed; tp ≤ 300 μs; δ ≤ 0.02 BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors aaa-023511 200 (1) hFE aaa-023512 200 hFE 150 150 (2) 100 100 (3) 50 0 10-1 1 10 102 0 10-1 103 104 IC (mA) VCE = 2 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 5. (1) (2) (3) 50 Fig. 6. aaa-023513 IB (mA) = 30 IC (A) 10 102 103 104 IC (mA) Tamb = 25 °C (1) VCE = 1 V (2) VCE = 2 V (3) VCE = 5 V DC current gain as a function of collector current; typical values 1 1 27 21 0.8 15 aaa-023514 1.5 24 VBE (V) 18 12 1 9 0.6 DC current gain as a function of collector current; typical values (1) 6 (2) 0.4 3 (3) 0.5 0.2 0 0 1 2 3 4 VCE (V) 0 10-1 5 Tamb = 25 °C Fig. 7. Fig. 8. Product data sheet 10 102 103 104 IC (mA) VCE = 2 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Collector current as a function of collectoremitter voltage; typical values BCX56T_SER 1 Base-emitter voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors aaa-023515 1.5 VBEsat (V) aaa-023516 1 VCESat (V) 1 (1) (3) 0.5 0 10-1 1 10 102 103 104 IC (mA) 10-2 10-1 IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig. 9. (1) (2) (3) 10-1 (2) 1 10 102 103 104 IC (mA) IC/IB = 10 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Base-emitter saturation voltage as a function of Fig. 10. Collector-emitter saturation voltage as a collector current; typical values function of collector current; typical values aaa-023517 1 aaa-023518 16 Cc (pF) VCESat (V) 12 10-1 8 (1) (2) 4 (3) 10-2 10-1 1 10 102 103 104 IC (mA) 0 0 20 40 60 80 100 VCB (V) f = 1 MHz; Tamb = 25 °C Tamb = 25 °C (1) IC/IB = 50 (2) IC/IB = 20 (3) IC/IB = 5 Fig. 12. Collector capacitance as a function of collectorbase voltage; typical values Fig. 11. Collector-emitter saturation voltage as a function of collector current; typical values BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors aaa-023519 100 aaa-023520 103 Ce (pF) 80 fT (MHz) 60 102 40 20 0 0 1 2 3 4 VEB (V) 10 10-1 5 f = 1 MHz; Tamb = 25 °C Fig. 13. Emitter capacitance as a function of emitterbase voltage; typical values 1 10 102 IC (mA) 103 VCE = 5 V f = 100 MHz; Tamb = 25 °C Fig. 14. Transition frequency as a function of collector current; typical values 8. Test information 8.1. Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 4.6 4.4 1.8 1.4 1.6 1.4 2.6 2.4 4.25 3.75 1 2 0.53 0.40 1.5 1.2 0.8 3 0.48 0.35 0.44 0.23 3 Dimensions in mm 06-08-29 Fig. 15. Package outline SOT89 (SC-62) BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors 10. Soldering 4.75 2.25 2 1.9 1.2 0.2 0.85 solder lands 1.7 1.2 4.6 solder resist 0.5 1 (3×) 4.85 occupied area 1.1 (2×) 1.5 solder paste Dimensions in mm 1.5 0.6 (3×) 0.7 (3×) 3.95 sot089_fr Fig. 16. Reflow soldering footprint for SOT89 (SC62) 6.6 2.4 3.5 solder lands 7.6 0.5 solder resist occupied area 1.8 (2×) Dimensions in mm preferred transport direction during soldering 1.9 1.5 (2×) 1.9 0.7 5.3 sot089_fw Fig. 17. Wave soldering footprint for SOT89 (SC62) BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BCX56T_SER v.1 20190822 Product data sheet - BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 - © Nexperia B.V. 2019. All rights reserved 10 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 12. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 BCX56T series Nexperia 80 V, 1 A NPN power bipolar transistors Contents 1. Product profile.............................................................. 1 1.1. General description......................................................1 1.2. Features and benefits..................................................1 1.3. Applications................................................................. 1 1.4. Quick reference data................................................... 1 2. Pinning information......................................................2 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Limiting values............................................................. 3 6. Thermal characteristics............................................... 4 7. Characteristics.............................................................. 5 8. Test information............................................................8 8.1. Quality information.......................................................8 9. Package outline............................................................ 8 10. Soldering..................................................................... 9 11. Revision history........................................................ 10 12. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 August 2019 BCX56T_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 22 August 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12
BCX56TX 价格&库存
很抱歉,暂时无法提供与“BCX56TX”相匹配的价格&库存,您可以联系我们找货
BCX56TX
  • 1+3.16459
  • 10+2.02548
  • 50+1.45652
BCX56TX
  • 3254+0.975853254+0.12683
  • 10000+0.8700510000+0.11308
  • 100000+0.72871100000+0.09471
库存:7606980
BCX56TX
  • 1+3.080381+0.40036
  • 10+1.8770110+0.24396
  • 100+1.17492100+0.15271
  • 500+0.86891500+0.11293
BCX56TX
库存:5700
BCX56TX
  • 1000+0.770021000+0.10008
  • 2000+0.686602000+0.08924
  • 3000+0.644013000+0.08370
  • 5000+0.596095000+0.07748
  • 7000+0.567687000+0.07378
  • 10000+0.5400510000+0.07019
BCX56TX
  • 1+4.827101+0.62730
  • 10+3.3419010+0.43430
  • 100+2.12010100+0.27550
  • 500+1.32960500+0.17280
  • 1000+1.166701000+0.15160
