SJD12C30L01
SJD12C30L01
    DOWO(东沃电子)
    SOD123
    特性:玻璃钝化芯片。 200W 峰值脉冲功率能力,波形为 10/1000μs,重复率(占空比):0.01%。 低泄漏。 单向和双向单元。 出色的钳位能力。 极快的响应时间。 符合 RoHS 标准
SJD12C30L01 数据手册
SJD12 Series Working Voltage: 5.0 to 350 V Peak Pulse Power: 200 W Surface Mount Transient Voltage Suppressors Features ● Glass passivated chip ● 200 W peak pulse power capability with a 10/1000 μs waveform, repetitive rate (duty cycle):0.01 % ● Low leakage Uni and Bidirectional unit Excellent clamping capability Very fast response time RoHS compliant ● ● ● ● SOD-123 Mechanical Data ● ● ● ● ● Case: Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Solderable per MIL-STD-750, method 2026 Polarity: Color band denotes cathode end except Bipolar Mounting position: Any Maximum Ratings(TA=25℃ unless otherwise noted) Parameter Peak power dissipation with a 10/1000μs waveform(1) Peak power dissipation with a 8/20μs waveform(1) Peak pulse current wih a 10/1000μs waveform(1) Power dissipation on infinite heatsink at TL = 75 °C Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 25 A for unidirectional only Operating junction and storage temperature range Value Symbol PPP 200 PPP 1000 IPP See Next Table 0.4 PD UNIT W W A W IFSM 20 A VF 3.5 V TJ, TSTG - 55 to +150 °C Note: (1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1 (2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum P. 1 SJD12 Series Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) 0 30 100 20 TJ = TJ max. 1 8.3 ms Single Half Sine-Wave 25 Peak Forward Surge Current, (A) Peak Pulse Derating in Percentage of Peak Power or Current, (%) AMBIE AVERAGE FORWARD CURRENT, (A) 100 100 75 150 0 50 25 0 100 20 10 0 0 25 50 75 100 125 150 175 200 1 Fig. 1 - Pulse Derating Curve Fig. 2 - Maximum Non-Repetitive Surge Current 0.6 10 0.1 7 70 0.5 0.4 4500 0.1 0 0.4 Peak Power (kW) Steady State Power Dissipation, (W) 0.4 ## 100 10 Number of Cycles at 60 Hz Ambient Temperature ,TA (℃) 0 6 0.3 0.2 1 0.1 0.1 0.0 0 25 50 75 100 125 150 175 0.1 200 1 10 100 1000 10000 Pulse Width ,td (μs) Lead Temperature , TL (℃) Fig. 3 - Steady State Power Derating Curve Fig. 4 - Peak Pulse Power Rating Curve 10000 Tr=10μs Peak Value (Ipp) 5 1000 0.2 100 0.5 = Ipp 76 Half Value 2 1 50 1.5 33 10/1000 μsec. Waveform 2as defined23 by R.E.A. 3 13 4 10 50 td Junction Capacitance,CJ (pF) Peak Pulse Current , (% ) 100 TJ = 25 °C Pulse Width (td) is defined as the point where the peak current decays to 500% of Ipp 0 100 Bi-directional @zero bias 450 2000 30 5 450 1000 18 5 450 Uni-directional @zero bias 700 2RWM Uni-directional @V 10 5 450 500 3 TJ=25 °C f=1.0MHz Bi-directional @VRWM 1 0 0 1 2 Time , (ms) Fig. 5 - Pulse Waveform 3 4 1 10 100 1000 Reverse Breakdown Voltage,VBR (V) Fig. 6 - Typical Junction Capacitance P. 2 SJD12 Series Electrical Characteristics(TA=25℃ unless otherwise noted) Part Number Part Number (Uni) (Bi) SJD12A05L01 SJD12A06L01 SJD12A6.5L01 SJD12A07L01 SJD12A7.5L01 SJD12A08L01 SJD12A8.5L01 SJD12A09L01 SJD12A10L01 SJD12A11L01 SJD12A12L01 SJD12A13L01 SJD12A14L01 SJD12A15L01 SJD12A16L01 SJD12A17L01 SJD12A18L01 SJD12A19L01 SJD12A20L01 SJD12A22L01 SJD12A24L01 SJD12A26L01 SJD12A28L01 SJD12A30L01 SJD12A33L01 SJD12A36L01 SJD12A40L01 SJD12A43L01 SJD12A45L01 SJD12A48L01 SJD12A51L01 SJD12A54L01 SJD12A58L01 SJD12A60L01 SJD12A64L01 SJD12A70L01 SJD12A75L01 SJD12A78L01 SJD12A80L01 SJD12A85L01 SJD12A90L01 SJD12A100L01 SJD12A110L01 SJD12A120L01 SJD12A130L01 SJD12A140L01 SJD12A150L01 SJD12A160L01 SJD12A170L01 SJD12A180L01 SJD12A190L01 SJD12A200L01 SJD12A220L01 SJD12A250L01 SJD12A300L01 SJD12A350L01 SJD12C05L01 SJD12C06L01 SJD12C6.5L01 SJD12C07L01 SJD12C7.5L01 SJD12C08L01 SJD12C8.5L01 SJD12C09L01 SJD12C10L01 SJD12C11L01 SJD12C12L01 SJD12C13L01 SJD12C14L01 SJD12C15L01 SJD12C16L01 SJD12C17L01 SJD12C18L01 SJD12C19L01 SJD12C20L01 SJD12C22L01 SJD12C24L01 SJD12C26L01 SJD12C28L01 SJD12C30L01 SJD12C33L01 SJD12C36L01 SJD12C40L01 SJD12C43L01 SJD12C45L01 SJD12C48L01 SJD12C51L01 SJD12C54L01 SJD12C58L01 SJD12C60L01 SJD12C64L01 SJD12C70L01 SJD12C75L01 SJD12C78L01 SJD12C80L01 SJD12C85L01 SJD12C90L01 SJD12C100L01 SJD12C110L01 SJD12C120L01 SJD12C130L01 SJD12C140L01 SJD12C150L01 SJD12C160L01 SJD12C170L01 SJD12C180L01 SJD12C190L01 SJD12C200L01 SJD12C220L01 Device Marking Code Uni Bi FE FG FK FM FP FR FT FV FX FZ HE HG HK HM HP HR HT HB HV HX HZ JE JG JK JM JP JR JT JV JX JZ XE XG XK XM XP XR XT XB XV XX XZ TE TG TK TB TM TP TR TT TV TX TZ YE YG YK KE KG KK KM KP KR KT KV KX KZ LE LG LK LM LP LR LT LB LV LX LZ ME MG MK MM MP MR MT MV MX MZ NE NG NK NM NP NR NT NB NV NX NZ PE PG PK PB PM PP PR PT PV PX PZ Maximum Reverse Leakage IR @VRWM IT (mA) (uA) Breakdown Voltage VBR @IT Min (V) Max (V) 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.00 11.10 12.20 13.30 14.40 15.60 16.70 17.80 18.90 20.00 21.10 22.20 24.40 26.70 28.90 31.10 33.30 36.70 40.00 44.40 47.80 50.00 53.30 56.70 60.00 64.40 66.70 71.10 77.80 83.30 86.70 88.80 94.40 100.00 111.00 122.00 133.00 144.00 155.00 167.00 178.00 189.00 200.00 211.00 224.00 246.00 279.00 335.00 391.00 7.00 7.37 7.98 8.60 9.21 9.83 10.40 11.10 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 23.30 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 49.10 52.80 55.30 58.90 62.70 66.30 71.20 73.70 78.60 86.00 92.10 95.80 97.60 104.00 111.00 123.00 135.00 147.00 159.00 171.00 185.00 197.00 209.00 220.00 232.00 247.00 272.00 309.00 371.00 432.00 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 400 400 250 100 50 25 10 5 2.5 2.5 2.5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Working Peak Reverse Voltage VRWM (V) 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 26.0 28.0 30.0 33.0 36.0 40.0 43.0 45.0 48.0 51.0 54.0 58.0 60.0 64.0 70.0 75.0 78.0 80.0 85.0 90.0 100.0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 220.0 250.0 300.0 350.0 Maximum Maximum Clamping Reverse Voltage VC Surge @IPP Current IPP (A) (V) 21.74 19.42 17.86 16.67 15.50 14.71 13.89 12.99 11.76 10.99 10.05 9.30 8.62 8.20 7.69 7.25 6.85 6.54 6.17 5.63 5.14 4.75 4.41 4.13 3.75 3.44 3.10 2.88 2.75 2.58 2.43 2.30 2.14 2.07 1.94 1.77 1.65 1.59 1.55 1.46 1.37 1.23 1.13 1.04 0.96 0.89 0.82 0.77 0.73 0.68 0.65 0.62 0.56 0.50 0.41 0.36 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 30.6 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 113.0 121.0 126.0 129.0 137.0 146.0 162.0 177.0 193.0 209.0 224.0 243.0 259.0 275.0 292.0 308.0 324.0 356.0 405.0 486.0 567.0 Note: 1. The available parts are "A" type only,the parts without A(VBR is ±10%) is not available 2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices 3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double P. 3
SJD12C30L01 价格&库存
很抱歉,暂时无法提供与“SJD12C30L01”相匹配的价格&库存,您可以联系我们找货
SJD12C30L01
    • 1+0.56540
    • 200+0.18920
    • 1500+0.11770
    • 3000+0.09350
    库存:2117
