GBLC05C
GBLC05C
    TECHPUBLIC(台舟)
    SOD-323
    VRWM:5V, IPP:8A, CJ:1pF
GBLC05C 数据手册
GBLC05C 1-Line Low Capacitance Bi-directional TVS Diode WWW.SOT23.COM.TW Features Package:SOD-323   Ultra low leakage: nA level   UL Flammability Classification Rating 94V-0 www.kxw-esd.com www.kxw-esd.com www.kxw-esd.com Ultra low leakage: nA leel www.kxw-esd.com Low clamping voltage Protects one power line or data line Complies with following standards: www.kxw-esd.com – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) RoHS Compliant www.kxw-esd.com www.kxw-esd.com www.kxw-esd.com www.kxw-esd.com www.kxw-esd.com Case Material: “Green” Molding Compound. www.kxw-esd.com www.kxw-esd.com www.kxw-esd.com Moisture Sensitivity: Level 3 per J-STD-020 www.kxw-esd.com www.kxw-esd.com  Cellular Handsets and Accessories  Personal Digital Assistants BL www.kxw-esd.com Ordering Information Part Number GBLC05C IC Applications  Notebooks and Handhelds  Portable Instrumentation  Peripherals PU    Ultra low capacitance: 1.0 pF typical Qty per Reel Reel Size 3000 7” CH  Low operating :5V TE       Mechanical Characteristics Dimensions and Pin Configuration w .kxw-esd.com GBLC05C 1-Line Low Capacitance Bi-directional TVS Diode WWW.SOT23.COM.TW Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter www.kxw-esd.com www.kxw-esd.com ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) www.kxw-esd.com Symbol www.kxw-esd.com www.kxw-esd.com Unit ±30 VESD Operating Temperature Range Storage Temperature Range Value kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Parameter VRWM Nominal Reverse Working Voltage IR Reverse Leakage Current @ VRWM VBR Reverse Breakdown Voltage @ IT Test Current for Reverse Breakdown VC Clamping Voltage @ IPP IPP Maximum Peak Pulse Current VC VBR VRWM CH f Reverse Voltage IT IR VRWM VBR VC V IR IT IPP Small Signal Frequency Parameter TE VR Parasitic Capacitance PU IT CESD I IPP BL Symbol IC Electrical Characteristics (TA=25°C unless otherwise specified) www.kxw-esd.com Reverse Working Voltage Breakdown Voltage Symbol Test Condition VRWM www.kxw-esd.com VBR IT = 1mA Bi-Directional TVS Min Typ 6 Max Unit 5 V 8 V Reverse Leakage Current IR VRWM = 5V 0.2 µA www.kxw-esd.com Clamping Voltagewww.kxw-esd.com VC IPP = 1A (8 x 20µs pulse) 9 V VC IPP = 8A (8 x 20us pulse) 19 V Junction Capacitance CJ VR = 0V, f = 1MHz Clamping Voltage 1 pF GBLC05C 1-Line Low Capacitance Bi-directional TVS Diode WWW.SOT23.COM.TW Electrical Characteristics (TA=25°C unless otherwise specified) Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 30 t - Time ( s) Power Derating Curve 110 100 CH 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power 10% PU Fig3. 0 25 50 75 100 125 Ambient Temperature –TA (ºC) 150 w w.kxw-esd.com IC 80 90% tr = 0.7~1ns BL IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP Percent of Peak Pulse Current % tr 30ns 60ns Time (ns) GBLC05C 1-Line Low Capacitance Bi-directional TVS Diode WWW.SOT23.COM.TW Outline Drawing - SOD-323 A DIMENSIONS MILLIMETERS INCHES MIN MAX MIN MAX 1.50 1.80 0.060 0.071 B 1.20 1.40 0.045 0.054 C 2.30 2.70 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 F 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 IC SYM TE CH PU BL w w.kxw-esd.com Land Pattern - SOD-323 SYM DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031
GBLC05C 价格&库存
很抱歉,暂时无法提供与“GBLC05C”相匹配的价格&库存,您可以联系我们找货
GBLC05C
  • 10+0.36969
  • 100+0.29754
  • 300+0.26147
  • 3000+0.21730
  • 6000+0.19570
  • 9000+0.18479
库存:36719
GBLC05C
    • 10+0.33888
    • 100+0.27275
    • 600+0.23968
    • 1200+0.23608
    • 3000+0.19919
    库存:5372
    GBLC05C
      • 20+0.17608
      • 200+0.16368
      • 600+0.15128
      • 3000+0.13888
      库存:31
      GBLC05C
      • 10+0.36490
      • 100+0.29340
      • 300+0.25760
      • 3000+0.21320
      • 6000+0.19200
      • 9000+0.18120
      库存:6782
      GBLC05C
      • 1+0.30470
      • 200+0.19690
      • 1500+0.17160
      • 3000+0.15180
      库存:2823
