BC025M101LO6.3*8L-1A4T
    BERYL(绿宝石)
    插件,D6.3xL8mm
    直插铝电解电容 AEC_D6.3X8MM_TM
BC025M101LO6.3*8L-1A4T 数据手册
BC Series ● low impedance, high ripple current ● Load life of 2000 hours at 105℃ ● RoHS Compliant ◆ 规格表 Specifications CF BE 项目Items mini size Ultra low ESR 耐久性 Endurence 耐湿负荷特性 Damp Heat (Steady State) High BD 2.5 ~ 25V 静电容量允许偏差 Capacitance tolerance 温度特性 Low Temperture Characteristics (Max.Impedance Ratio) BC BC -55 ~ +105℃ 额定工作电压范围 Rated Voltage Range 损耗角正切值tanδ Dissipation Factor Long life 特性参数Characteristics 使用温度范围 Category Temperture Range 漏电流 Leakage Current CA ±20%(M) (at 20℃,120Hz) 施加额定工作电压2分钟后读数,小于或等于规格值 ( 20℃) I≤0.2CV 或280μA(取大值)(The bigger)(The bigger) After 2 minutes applied for rated voltage at 20℃, less than or equal to the specified value. Rated voltage (V) 2.5~25 (at 20℃,120Hz) tanδ (Max.) 0.12 Z(-25℃)/Z(+20℃) ≤1.25 Z(-55℃)/Z(+20℃) ≤1.25 (100KHz) 105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be met when thecapacitors are restored to 20°C after the rated voltage is applied for 2000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be met when the capacitors are restored to 20°C after the rated voltage is applied for 1000 hours at 60℃, 90%~ 95% RH. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ESR Leakage current ≦150% of the specified value ≦150% of the specified value ≦The specified value 浪涌电压=额定电压* 1.15(V) Surge Voltage=Rated voltage * 1.15(V) 浪涌电压特性 (Surge Voltage) 在105℃环境中,按充电30秒,放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求 The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value ◆ 外形图Dimensions (mm) ΦD 5 5.5 6.3 8 10 P 2 2.5 2.5 3.5 5 Φd 0.5 0.5 0.5 0.6 0.6 ɑ L
BC025M101LO6.3*8L-1A4T 价格&库存
很抱歉,暂时无法提供与“BC025M101LO6.3*8L-1A4T”相匹配的价格&库存,您可以联系我们找货
  • 5+1.09836
  • 50+0.89619
  • 150+0.79510
  • 1000+0.63861
  • 2000+0.57791
  • 5000+0.54756
    • 1+0.88930
    库存:5
