3003
3003
    HEYCO
3003 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Shorty Universal Bushings ® Single Locking Step for Panel Thickness up to .062˝ (1,6 mm) Mounting Hole Diameter Range: .500˝ (12,7 mm) to 1.093˝ (27,8 mm) MOUNTING HOLE DIAMETER in. PART NO. DESCRIPTION Maximum Inside Diameter in. mm. Black mm. .500 12,7 2858 SUB 500 .625 15,9 2861 SUB 625 .750 19,1 2862 SUB 750 .875 22,2 2863 SUB 875 1.000 25,4 2864 SUB 1000 1.093 27,8 2158 SUB 1093 Standard color black. Consult Heyco for white and other colors. .31 .44 .50 .56 .75 .81 7,6 11,1 12,7 14,3 19,0 20,6 PART DIMENSIONS A Head Diameter in. mm. .60 .73 .86 .94 1.06 1.16 15,2 18,5 21,8 23,8 27,0 29,4 B Overall Height in. mm. .25 6,4 B • For use in mounting panels .062˝ (1,6 mm) and thinner. • Absorb vibration and cushion and insulate cables, tubing, hoses or shafts with limited internal clearance. • Flexible shutters adjust to accommodate and support any shape from .125˝ (3,2 mm) to a maximum inside diameter of .812˝ (20,6 mm). • Fingertip pressure snap-locks the bushing into its mounting hole. • See Quick Specs on 6-11. A Heyco Thick Panel Universal Bushings ® Multiple Locking Steps for Panel Thickness up to .250˝ (6,4 mm) Mounting Hole Diameter Range: .500˝ (12,7 mm) to 1.500˝ (38,1 mm) MOUNTING HOLE DIAMETER PART NO. DESCRIPTION Maximum Inside Diameter in. mm. Black PART DIMENSIONS A Head Diameter in. mm. B Overall Height in. mm. .500 12,7 3001 UBT 500 .31 7,6 .60 15,2 .55 in. 13,8 .625 15,9 3118 UBT 625* .44 11,1 .73 18,5 .51 13,0 .750 .875 1.000 1.093 19,1 22,2 25,4 27,8 3119 3120 3121 3002 UBT 750* UBT 875 UBT 1000 UBT 1093 .50 .56 .75 .81 12,7 14,3 19,1 20,6 .84 .94 1.06 1.16 21,4 23,8 27,0 29,5 .55 13,8 1.375 34,9 3003 UBT 1375 1.00 1.500 38,1 3122 UBT 1500 1.06 Standard color black. Consult Heyco for white and other colors. *Single Locking Step for Panel Thickness up to .250˝ (6,4 mm). 25,4 26,9 1.49 1.61 37,8 40,9 .56 14,2 B mm. • For use in mounting panels up to .250˝ thick. • Flexible shutters to absorb vibration on the inside diameter. • Insulate and mechanically protect electrical and telecommunications cables, tubing, hose, rope, and utility lines. • Withstand a push back force of 35 pounds. • Locking fingers snap into holes with fingertip pressure. • Locking fingers in fractional increments up to the maximum panel thickness. • Available in multiple sizes for use in .500˝ (12,7 mm) to 1.500˝ (38,1 mm) diameter holes. • See Quick Specs on 6-11. A 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com 6-12
很抱歉,暂时无法提供与“3003”相匹配的价格&库存,您可以联系我们找货
