Applications Note: SY5881
Single Stage Buck And PFC Controller With
Primary Side Control For LED Lighting And
Mutiple Dimming Option
Advanced Design Specification
Features
General Description
The SY5881 is a single stage Buck and PFC controller
targeting at LED lighting applications with PWM or
Analog dimming. It is a primary side controller without
applying any secondary feedback circuit for low cost,
and drives the Buck converter in the quasi-resonant
mode to achieve higher efficiency. It keeps the Buck
converter in constant on time operation to achieve high
power factor.
Ordering Information
SY5881 □(□□)□
Package type
SO8
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY5881FAC
Note
High dimming accuracy
Dimming Range from 5.5% to 100.0%
CV mode for Bias supply at 0.90
Compact package: SO8
Applications
• LED lighting
Typical Applications
PWM Signal Input VS. IOUT
100
80
60
40
60
80 90 100
PWM Duty(%)
Figure.1a Analog dimming with PWM signal input
AN_SY5881 Rev.0.0
Silergy Corp. Confidential- Prepared for Customer Use Only
1
IOUT(%)
AN_SY5881
Figure.1b Dimming curve of analog dimming
IOUT(mA)
IOUT(mA)
Test Condition: VIN=220VAC, VOUT=80V, IOUT=300mA
Figure.1c Actual curve of analog dimming VS. PWM input
AN_SY5881 Rev.0.0
2
AN_SY5881
Pinout (top view)
(SO8)
Top Mark: BEHxyz (device code: BEH, x=year code, y=week code, z= lot number code)
Pin Name
Pin number
COMP
1
ZCS
2
ISEN
3
Pin Description
Loop compensation pin. Connect a RC network across this pin and
ground to stabilize the control loop.
Inductor current zero-crossing detection pin. This pin receives the
auxiliary winding voltage by a resister divider and detects the inductor
current zero crossing point. This pin also provides over voltage
protection and line regulation modification function simultaneously. If
the voltage on this pin is above VZCS,OVP, the IC would enter over
voltage protection mode. Good line regulation can be achieved by
adjusting the upper resistor of the divider.
Current sense pin. Connect this pin to the source of the primary
switch. Connect the sense resistor across the source of the primary
switch and the GND pin.
(current sense resister R : R
S
GND
DRV
4
5
VIN
6
ADIM
7
PWM
8
AN_SY5881 Rev.0.0
S
V
REF
2×I
OUT
Ground pin
Gate driver pin. Connect this pin to the gate of primary MOSFET.
Power supply pin. This
pin also
provides output over voltage
protection along with ZCS pin.
Bypass this pin to GND with enough capacitance to hold on internal
voltage reference.
PWM dimming input pin, this pin detects the PWM dimming signal
3
AN_SY5881
Block Diagram
COMP
VIN
UVLO
ISEN
IO Estimator
Gm
&BIAS
PWM
Logic
VREF
V
REF
DRV
Driver
GND
VISEN,MAX
Valley Detect
ZCS
Buffer
OVP
DIM
Control
PWM
VREF
ADIM
Figure.3 Block Diagram
Absolute Maximum Ratings (Note 1)
VIN, DRV -------------------------------------------------------------------------------------------------------------------0.3V~25V
Supply current IVIN ----------------------------------------------------------------------------------------------------------------7mA
ZCS, PWM ------------------------------------------------------------------------------------------------------------------0.3V~23V
ADIM ------------------------------------------------------------------------------------------------------------------------0.3V~15V
ISEN, COMP ----------------------------------------------------------------------------------------------------------------0.3~ 3.6V
Power Dissipation, @ TA = 25°C SO8 ----------------------------------------------------------------------------------------1.1W
Package Thermal Resistance (Note 2)
SO8, θ JA -----------------------------------------------------------------------------------------------------------------------88°C/W
SO8, θ JC -----------------------------------------------------------------------------------------------------------------------45°C/W
Temperature Range --------------------------------------------------------------------------------------------------- - 40°C to 150°C
Lead Temperature (Soldering, 10 sec.) ---------------------------------------------------------------------------------------260°C
Storage Temperature Range ----------------------------------------------------------------------------------------- - 65°C to 150°C
Recommended Operating Conditions (Note 3)
VIN, DRV ----------------------------------------------------------------------------------------------------------------------
AN_SY5881 Rev.0.0
8V~20V
4
AN_SY5881
Electrical Characteristics
(VIN = 12V (Note 3), TA = 25°C unless otherwise specified)
Parameter
Power Supply Section
VIN turn-on threshold
VIN turn-off threshold
VIN OVP voltage
Start up Current
Shunt current in OVP mode
Error Amplifier Section
Internal reference voltage
Current Sense Section
Current limit reference voltage
ZCS pin Section
ZCS pin OVP voltage
threshold
Gate Driver Section
Gate driver voltage
Maximum source current
Minimum sink current
Max ON Time
Min ON Time
Max OFF Time
Min OFF Time
Maximum switching frequency
ADIM function Section
ADIM Enable ON
ADIM Enable OFF
Symbol
V
VIN_ON
V
VIN_OFF
V
VIN_OVP
I
ST
I
Test Conditions
Min
Typ
Max
Unit
19
V
8.0
8.5
V
7.5
VIN ON+3.0
V
34
µA
7
mA
REF
300
mV
ISEN_MAX
750
mV
1.5
V
VIN_OVP
V V
VIN
VIN_OVP
V
V
V
ZCS_OVP
V
Gate
12
V
SOURCE
200
mA
SINK
650
mA
I
I
T
ON_MAX
T
ON_MIN
T
VCOMP=2.6V
24
µs
300
ns
OFF_MAX
120
µs
OFF_MIN
0.5
µs
MAX
120
kHz
75
mV
37
mV
FB
145
°C
SD
160
°C
T
f
V
ADIM_ON
V
ADIM_OFF
Thermal Section
Thermal Fold back
Temperature
Thermal shut down
Temperature
PWM function Section
PWM ON voltage
PWM OFF voltage
T
T
V
PWM_ON
V
PWM_OFF
1.2
0.5
V
V
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may
affect device reliability.
Note 2: ſJA is measured in the natural convection at TA = 25°C on a low effective single layer thermal conductivity test
board of JEDEC 51-3 thermal measurement standard. Test condition: Device mounted on 2” x 2” FR-4 substrate PCB,
2oz copper, with minimum recommended pad on top layer and thermal vias to bottom layer ground plane.
Note 3: Increase VIN pin voltage gradually higher than VVIN_ON voltage then turn down to 12V.
AN_SY5881 Rev.0.0
5
AN_SY5881
Operation
targeting at LED lighting applications with multiple
dimming function.
The Device provides primary side control to eliminate the
opto-couplers or the secondary feedback circuits, which
would cut down the cost of the system.
High power factor is achieved by constant on operation
mode, with which the control scheme and the circuit
structure are both simple.
SY5881 is compatible with Analog dimming and PWM
dimming for different application.
In order to reduce the switching losses and improve EMI
performance, Quasi-Resonant switching mode is applied,
which means to turn on the power MOSFET at voltage
Fig.4 Start up
The start up resistor RST and CVIN are designed by rules
below:
(a) Preset start-up resistor RST, make sure that the current
through RST is larger than IST and smaller than IVIN_OVP
V
I
BUS
V
176V × 1.414
15µA
=16.59MΩ ,
= 264V×1.414 =186.7kΩ
BUS
I
2mA
VIN_OVP
Set RST
R ST =300kΩ × 2=600kΩ
(b) Design CVIN
C
VBUS
R
ST
VIN
-I ST ) × tST
V
VIN_ON
176V × 1.414
600kΩ
-34µA)×500ms
22V
=8.6µF
Set CVIN
CVIN =10µF
#6 Set COMP pin
Refer to Internal pre-charge design for quick start up
Parameters designed
R
C
COMP
1.5kΩ
COMP1
2µF
V
C
COMP_IC
900mV
COMP2
#7 Set current sense resistor to achieve ideal output current
Refer to constant-current control
Known conditions at this step
V
REF
0.3V
The current sense resistor is
AN_SY5881 Rev.0.0
I
OUT
0.3A
15
AN_SY5881
V
0.3
R S = 2 × I OUT = 2 × 0.3A = 0.5Ω
REF
#8 set ZCS pin
Refer to Line regulation modification and Over Voltage Protection (OVP) & Open Loop Protection (OLP)
First identify RZCSU need for line regulation.
Parameters Designed
R
ZCSU
200kΩ
k
1
Then compute RZCSD
Conditions
V
V
V
1.42V
24V
ZCS_OVP
OUT
68
OVP
35V
AUX
45
Parameters designed
R
200kΩ
100
ZCSU
N
NS
N
V
N
OVP
3 × 12
AUX
= 35
36
≈1
V
ZCS_OVP
R
V
× NS
OUT
ZCSD
1-
V
V
ZCS_OVP
OUT
×R
N
AUX
ZCSU
N
×N S
AUX
1.5V ×1
= 24V
× 200kΩ
1-1.5V ×1
24V
= 13.3kΩ
RZCSD is set to
R ZCSD =13kΩ
#9 set ADIM and PWM pin
Refer to Analog Dimming Mode Design
Conditions
V
PWM_ON
0.8V
Parameters Designed
200kΩ
RPWM_UP
10 −3
C ADIM =
f PWM
F × Hz =
10−3
F=1uF
1000
AN_SY5881 Rev.0.0
16
AN_SY5881
Hence CADIM is set to
CADIM=1uF
#10 final result
AN_SY5881 Rev.0.0
17
AN_SY5881
1.55
SO8 Package Outline & PCB Layout Design
5.80 - 6.20
4
8
1.27 TYP
0.30 – 0.50
0.60
1
4
6
0.180.25
0.25 - 0.50
0.08-0.25
2
5
b
a
s
e
Recommended Pad Layout
4.80 - 5.00
5°
-8° 0
0.60 - 0.85
1.27 (TYP)
Notes: All dimensions are in millimeters.
All dimensions don’t include mold flash & metal burr.
AN_SY5881 Rev.0.0
18
很抱歉,暂时无法提供与“SY5881FAC”相匹配的价格&库存,您可以联系我们找货
