FL
Washable
RoHS Compliant
Hyper-miniature Lever & Rocker Switches
■Features
■ Specifications
1. Hyper-miniature type. The volumetric ratio is half
the conventional Series A.
2. Immersion cleaning is possible after soldering.
3. The terminal pitch is of the 0.1-inch size..
4. The independent detent mechanism ensures light
operating feeling.
5. For the contact reliability, long-term stability is
assured by the clip contacts.
6. Since the contacts are gold-plated, the switches
are best suited for use in the dry circuit areas.
7. The full-molded type prevents malfunction caused
by static electricity.
L
Rocker type
Actuator shape
Lever
Dielectric strength
250VAC 1 minute
Insulation resistance
500MΩ min.
Electrical life
10,000 cycles at max. rating
50,000 cycles at min.
Operating
temperature range
−40℃∼+85℃
(250VDC)
−40℃∼+85℃
Storage
temperature range
1
1 pole
2
2 poles
Switching function
Number of poles
D
ON
■ Standard Accessories
Part name
(1.5mA 200μVAC)
Initial contact resistance 100mΩ max.
F L 2 D - 2 M - Z
■Part Numbering
Series code
Max : 0.4VA(28VDC max.) Min : 1μA 20mVDC
Rating
(PC Straight&R/A)
ON
2
PC Straight
5
Right angle
《Supplied separately》
Rocker
(PC Straight&R/A)
Rocker
Actuator shape
Terminal style
(PC Straight)
M
Standard
■Lever・Rocker Mounting
Lever
Rocker
Dimensions
ABS resin
White
Black
Gray
140000050858
140000050860
140000050861
ABS resin
140000481410
140000481412
140000481413
ABS resin
140000481594
140000481596
140000481597
●The lever and the rocker are
standard accessories. Specify
either of the lever or the rocker by
part number.
(ON)
:Momentary
FL
SPDT
Switching
function
Part No.
FL1D−2M−Z
Connecting
terminals
Mount with Rocker
PC Straight
Viewed from part No. marking side
ON
ON
2−1
2−3
Terminal numbers are not shown on the bottom of the switch. (Top view)
PC Hole Layouts
DPDT
Switching
function
Part No.
★FL2D−2M−Z
Connecting
terminals
Mount with Lever
PC Straight
ON
2−1
5−4
ON
2−3
5−6
PC Hole Layouts
SPDT
Switching
function
Part No.
★FL1D−5M−Z
Connecting
terminals
ON
ON
2−3
2−1
Mount with Rocker
R/A
PC Hole Layouts
DPDT
Switching
function
Part No.
★FL2D−5M−Z
Connecting
terminals
ON
2−3
5−6
ON
2−1
5−4
Mount with Lever
R/A
PC Hole Layouts
■Packaging Specifications
■Soldering Specifications
Plastic Pack
100 pcs/pack
KU
15
SO
SO
JI
231
JI
FU
FU
KU
196
⑴Manual Soldering
Device: Soldering iron
380℃, Max.; 3 seconds, Max.
⑵Auto Soldering
Device: Jet wave type or dip type
275℃; 6 seconds, Max.
Temperature
275
120
80
S
120
6
Pre Heating Zone Soldering Zone
★:Made to order products.
很抱歉,暂时无法提供与“140000481594”相匹配的价格&库存,您可以联系我们找货
