140000481413
140000481413
    NIDEC(尼得科)
    GRYRCKRCAPFORR/AORSTRT
140000481413 数据手册
FL Washable RoHS Compliant Hyper-miniature Lever & Rocker Switches ■Features ■ Specifications 1. Hyper-miniature type. The volumetric ratio is half the conventional Series A. 2. Immersion cleaning is possible after soldering. 3. The terminal pitch is of the 0.1-inch size.. 4. The independent detent mechanism ensures light operating feeling. 5. For the contact reliability, long-term stability is assured by the clip contacts. 6. Since the contacts are gold-plated, the switches are best suited for use in the dry circuit areas. 7. The full-molded type prevents malfunction caused by static electricity. L Rocker type Actuator shape Lever Dielectric strength 250VAC 1 minute Insulation resistance 500MΩ min. Electrical life 10,000 cycles at max. rating 50,000 cycles at min. Operating temperature range −40℃∼+85℃ (250VDC) −40℃∼+85℃ Storage temperature range 1 1 pole 2 2 poles Switching function Number of poles D ON ‒ ■ Standard Accessories Part name (1.5mA 200μVAC) Initial contact resistance 100mΩ max. F  L  2  D  -  2  M - Z ■Part Numbering Series code Max : 0.4VA(28VDC max.) Min : 1μA 20mVDC Rating (PC Straight&R/A) ON 2 PC Straight 5 Right angle 《Supplied separately》 Rocker (PC Straight&R/A) Rocker Actuator shape Terminal style (PC Straight) M Standard ■Lever・Rocker Mounting Lever Rocker Dimensions ABS resin White Black Gray 140000050858 140000050860 140000050861 ABS resin 140000481410 140000481412 140000481413 ABS resin 140000481594 140000481596 140000481597 ●The lever and the rocker are standard accessories. Specify either of the lever or the rocker by part number. (ON) :Momentary FL SPDT Switching function Part No.  FL1D−2M−Z Connecting terminals Mount with Rocker PC Straight Viewed from part No. marking side ON − ON 2−1 − 2−3 Terminal numbers are not shown on the bottom of the switch. (Top view) PC Hole Layouts DPDT Switching function Part No. ★FL2D−2M−Z Connecting terminals Mount with Lever PC Straight Viewed from part No. marking side − ON 2−1 5−4 − ON 2−3 5−6 Terminal numbers are not shown on the bottom of the switch. (Top view) PC Hole Layouts SPDT Switching function Part No. ★FL1D−5M−Z Connecting terminals Viewed from part No. marking side ON − ON 2−3 − 2−1 Mount with Rocker R/A Terminal numbers are not shown on the bottom of the switch. (Top view) PC Hole Layouts DPDT Switching function Part No. ★FL2D−5M−Z Connecting terminals Viewed from part No. marking side − ON 2−3 5−6 − ON 2−1 5−4 Mount with Lever R/A Terminal numbers are not shown on the bottom of the switch. (Top view) PC Hole Layouts ■Packaging Specifications ■Soldering Specifications Plastic Pack 100 pcs/pack KU 15 SO SO JI 231 JI FU FU KU 196 ⑴Manual Soldering Device: Soldering iron 380℃, Max.; 3 seconds, Max. ⑵Auto Soldering Device: Jet wave type or dip type 275℃; 6 seconds, Max. Temperature [℃] 275 120 80 S 120 6 Pre Heating Zone Soldering Zone ★:Made to order products.
140000481413 价格&库存
很抱歉,暂时无法提供与“140000481413”相匹配的价格&库存,您可以联系我们找货
