ZL CONNECTOR
5.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 10A AC, DC max.
• Voltage rating: 300V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25mm2
• Applicable panel thickness: 0.7 to 2.4mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Retainer
Housing lance
Box-shaped contact
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector.
The table below lists the current rating as a function of the number of
circuits and wire size.
Current unit: A
Wire size (AWG)
Circuits
#16
ZL connectors are reliable, smoothly mating
wire-to-wire connectors.
• Housing lances
• Retainer
• Box-shaped contacts
• Mountable on a variety of panels
#24
#26
2
10
#18
6
#20
5
#22
4
3
2
4
9
5
4
3
3
2
6
8
4
3
3
2
2
8
6
4
3
3
2
2
12
6
4
3
3
2
2
16
5
3
2
2
1
1
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
Panel layout and Assembly layout
Circuits
Dimensions A (mm)
2・ 4
18.2
6・8・12・16
17.5
A
(41.8)(including retainer)
(38.2)
Shape I
Shape II
E
B
Circuits
B
2
D
C
D
C
7.8
4
6
8
2.7
12
A
A
16
Receptacle
housing
Panel Panel hole dimensions (mm) General tolerance ±0.13 Applicable panel
hole
thickness (mm)
A
B
C
D
E
shape
ZLR-02V
ZLR-04V
ZLR-06V
ZLR-08V
ZLR-12V
ZLR-16V
1
11.5
4.4
13.95
13.2
6.5
1
16.5
5.2
13.95
13.2
11.6
2
21.5
5.2
13.95
13.2
2
26.5
5.2
13.95
13.2
2
36.5
5.2
13.95
13.2
2
46.5
5.2
13.95
13.2
0.7∼2.4
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
ZL CONNECTOR
Contact
Applicable wire
Model No.
Pin contact
Socket contact
SZM-01T-P0.7
SZF-01T-P0.7
SZM-41T-P0.7
SZF-41T-P0.7
1.85
Pin contact
mm2
22.5
4.0
2.5
AWG #
Insulation O.D. Q´ty /
reel
(mm)
0.13∼0.5
26∼ 20
1.3∼2.7
0.75∼1.25
18∼16
1.9∼3.1
0.3+0.3∼
0.5+0.5
22+22∼
20+20
1.7+1.7∼
2.0+2.0
3,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Note: 1. Contact JST for special products.
2. Contact JST for brass products.
3.2
Socket contact
4.5
2.5
SZM-01T-P0.7
4.0
Applicator
Crimping
machine Crimp applicator
Contact
14.3
SZF-01T-P0.7
SZM-41T-P0.7
MKS-L
Dies
AP-K2N
MKS-L
SZF -41T-P0.7
Crimp applicator with dies
MK/SZF/M-01-07 APLMK SZF/M01-07
MK/SZF/M-41-07 APLMK SZF/M41-07
Contact position location numbers
Contact position numbers are stamped
Retainer
Retainer
Receptacle housing
Plug housing
6
3
5
4
2
3 6
2 5
1 4
16
6
8
1
3
1
2 4
1 3
JST
JST
1
JST
2
4
1
5
1 2
2
JST
2
3
6 3
5 2
4 1
1
3
6
JST
4
1
2
JST
2 1
4 2
3 1
4
Plug housing
2
Receptacle housing
7
13
6
12
5
4
9
2
1
3
10
1
11
2
8
1
2
2
3
10
5
4
3
7
6
3
2
12
11
10
9
8
7
1
JST
1
4
8
7
6
5
6
5
4
3
2
1
JST
5
4
3
2
1
JST
6
JST
JST
5
7
1
9
2
JST
7
12
3
13
4
14
5
15
6
9
2
10
3
6
11
4
7
4
3
2
1
6
5
4
3
2
1
8
7
6
5
4
3
2
1
4
8
12
8
8
7
6
5
12
11
10
9
8
7
16
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
16
15
14
13
12
11
10
9
ZL CONNECTOR
Contact
Material: Housing...PA 6, UL94V-0, white
Retainer...Glass-filled PA 66, UL94V-0, ivory
Circuits
Voltage
rating
Current
rating
Receptacle housing(for pin contact)
Q'ty /
bag
500
12.9
12.4
18.2
500
8.2
21.0
10.45
29.7
Q'ty /
bag
ZLS-02V
(Used with both
housings with 2
and 4 circuits)
9.4
10A
6.2
300V
Retainer
Q'ty /
bag
ZLP-02V
16.2
ZLR-02V
2
Plug housing(for socket contact)
Q'ty /
bag
500
Q'ty /
bag
Q'ty /
bag
ZLP-06V
8A
500
12.9
Q'ty /
bag
12.9
8.8
21.0
Q'ty /
bag
ZLP-08V
500
29.7
3.3
Q'ty /
bag
ZLS-08V
21.2
6A
8.2
31.2
300V
21.2
ZLR-08V
1,000
500
12.4
17.5
21.2
29.7
8
Q'ty /
bag
ZLS-03V
16.2
26.2
16.2
300V
21.0
12.9
ZLR-06V
6
8.8
500
8.2
12.4
18.2
29.7
1,000
6.4
16.2
9A
Q'ty /
bag
11.7
300V
ZLP-04V
21.2
4
11.2
ZLR-04V
1,000
500
12.4
17.5
8.2
3.3
8.8
21.0
RoHS compliance
3
ZL CONNECTOR
Contact
Q'ty /
bag
6A
200
3.3
Q'ty /
bag
ZLP-16V
51.2
5A
8.2
21.0
12.9
Q'ty /
bag
ZLS-16V
200
200
29.7
8.8
41.2
Q'ty /
bag
41.2
300V
1,000
12.9
ZLR-16V
16
Q'ty /
bag
ZLS-12V
200
12.4
17.5
29.7
Retainer
Q'ty /
bag
ZLP-12V
41.2
300V
31.2
ZLR-12V
12
31.2
Current
rating
41.2
Voltage
rating
31.2
Circuits
12.4
17.5
8.2
21.0
1,000
3.3
8.8
RoHS compliance
Note: 1. ZL connectors with any number of circuits can be used either panel mounted or free hanging. See "Panel layout" for the panel dimensions.
2. Contact JST for special products.
4
很抱歉,暂时无法提供与“ZLP-04V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.84230
- 50+0.67382
- 150+0.58958
